5MT Creaking
this has been happening for a while now, ever since i got my clutch replaced because of a bad TOB
when ever the clutch is let out a creaking noise is heard from the tranny engine area of the vehicle, almost like your stepping of a creaky wooden floor. it seems that when any amount of torque is applied to the transmission it creaks. could this be a symptom of a bad tranny mount, or engine mount :spin: or is the end insight? :lol: any other idea? 5mt NA Leggy 64,000 miles around 14,000 on the clutch |
Sounds like throw out bearing you might be able to pull back the boot and spray some lubricant like lithium grease straight down on the sleeve of the transmission and on the clutch fork itself.
When they replaced the clutch they probably didn't lubricate the clutch fork and center of the transmission where the TOB rides. |
It is typically not advisable to spray lubricant towards your clutch disc.
i'm glad to see you don't think my tranny is gonna fall out one day. |
@downtoearth i don't mean to jack your thread or anything, but i guess it would be helpful to you too.
not a problem, wasn't getting much attention anyways :(
Stiffer motor/trans mounts help reduce the jerkiness, but it's caused partially by engine management. There have been some that have tuned it out, though. |
alright, thats what i guessed. this guy at my work has a new wrx and he tells me that he thinks he has a bad tranny. especially during 5th also. he's even considering trading it in for a honda. i'll let him know about what you said. thanks
Yep. Subaru's have been doing that for the whole 23 year history of the EJ engine.
What, a Subaru 5mt that sounds like a bucket of rocks when you lift off the gas...why I never hear mine when I have the radio turned up to about 14.
Hence why I coast a lot on the back roads |
downtoearth, this type of sound is also heard from the clutch pedel itself. Underneath the dash were the clutch rod goes through the firewall is a spring. I would get this occasionally and putting some lube around this spring and it's contact points to help reduce the noise. Check to see if this sound is coming from the firewall underneath the dash.
I hear that in my 08 gt too! It gets so annoying! Don't know what it is! Hopefully our trannys are okay!
| All times are GMT -6. The time now is 12:54 PM. |
