Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   EJ25D Clip Location [PICS] (http://legacygt.com/forums/showthread.php?t=192218)
taylormac1993 08-30-2012 05:46 PM
I found a little clip that doesn't seem to go anywhere underneath my intake manifold on the passenger's side. It's a little single connection clip. Below is a picture of me holding the clip, followed by the location of the clip panned out.
http://img195.imageshack.us/img195/8...9702134844.jpg
http://img31.imageshack.us/img31/9825/ballss.jpg
Anyone know where this goes? It's the last thing I have to do....
broknindarkagain 08-30-2012 08:05 PM
Coolant Temp Sensor
SpecBamf41 08-30-2012 10:24 PM
plus 1, does your temp gauge work, if it still does its for the ecu, in which case idk how the car would run well at all or not over heat in traffic.
taylormac1993 08-30-2012 10:59 PM
Well I haven't started the car yet. I want to make sure everything's hooked up first... haha. Where is the coolant temp sensor? I can't find where this clip goes anywhere...
DOHCEJ22E1 08-31-2012 01:38 AM
Coolant temperature sensor is on the water cross flow under the manifold (aluminum pipe stretching across the block under the manifold).
Thomistopheles 08-31-2012 02:18 AM
http://i489.photobucket.com/albums/r...B/befef469.jpg
taylormac1993 08-31-2012 11:34 AM
You're my freaking heroes guys. Thanks a million.
broknindarkagain 08-31-2012 08:55 PM
You're welcome
SpecBamf41 08-31-2012 11:47 PM
when i first had everything unpluged i was also worried to start the car. now after you do it a few times i dont even care to look over the bay cause i know if something was left unplugged know damage can be done. you just get a cel and some times the car won't start or run right.
things the need to be plugged in to start are injectors, coil, ignitor, cam and crank sensors, maf. thats all that need for engine to start really, to be driveable just add tps and your on the road with about 5-10 odb codes lol..
these cars are forgiving so dont sweat it, and checking your timing marks, thats about it. and dont start your car without an checking you installed the oil filter.....
Stasis 09-01-2012 07:09 PM
Originally Posted by Thomistopheles (Post 4050420)
Damn that looks good painted, might have to do the same.
LegacyLou 09-02-2012 12:57 PM
Can this sensor be removed with the manifold in place?
Thomistopheles 09-02-2012 03:32 PM
You should be able to get at it.
http://i489.photobucket.com/albums/r...B/6acf6036.jpg
Another shot that shows it better. Everything on my new EJ25D will be painted since I hate looking at oxidized cast aluminum.
broknindarkagain 09-02-2012 05:29 PM
Yes but its kind of a pain. Very tight area to work in.
Stasis 09-02-2012 05:31 PM
Awesome. I want to paint it definitely although have no way of getting it the right torque when putting back on -_- grrrr
