Turbo Inlet hose
I was about to finish up my turbo install last night, but I decided my stock inlet hose is to messed up from me acting like a caveman when I took it out. Just was curious which one I should go with. If this is a common topic I appologize in advanced, but I did a quick search and didn't see a whole lot. Thanks in advanced.
OEM replacement ($90). Don't bother with aftermarket.
Do not, under any circumstances, go with a GMS. It is terrible fitment from what I've read. |
The stock ones tear pretty easily. If you're going to swap turbos a few times more you'll tear another stocker, and it's worth going aftermarket for durability. I just ordered a Perrin for this very reason... mine is torn and I expect to test more turbos. Stay away from junk like GMS, FMS etc. as compsurge mentions.
I'm thrilled with my Perrin. Easy install great fitment. A lot if them cave in but I've yet to see that with Perrin.
I have an AVO inlet we'll be installing with the new turbo i'm going with. Will comment back with impressions. :)
perrin works great for me. i wouldn't risk using oem they tear easy. like chinese condom.
FWIW, my new OEM replacement felt much sturdier at the turbo end than the unit that came off the car with ~100k on it. With proper care taken when torquing the worm clamp, I don't expect any issues.
Thats because the oem degrades with time and heat cycles.
OT
Any good install diys on the inlet? |
I just had a perrin put on my 08 Gt and it is nice and mated up rather well with everything. I did hear if you are looking to push over 20psi the perrin may collapse. I dont know how true that is but is something to look into.
If you mount the turbo on the up pipe without the studs, it's much easier to install the turbo without damage to the inlet hose. The bolts are the same ones that hold the up pipe bracket to the block.
http://i185.photobucket.com/albums/x...i/DSCN4783.jpg Oh, I also went with a stock inlet hose. |
| All times are GMT -6. The time now is 05:25 PM. |
