FS (NH): 2008 Spec B $25k many miles, many mods - SOLD
7 Attachment(s)
Year, Make and Model: 2008 Legacy GT Spec.B
Color: Quartz Silver Metallic Miles: 94,xxx Transmission: 6MT Title: Not in hand Lien: St. Mary's bank Location: Hudson, N.H. VIN: 4S3BL696283217845 Seller's email address: libertyb78@gmail.com Asking Price: $24,000/b.o. I really don't want to do this, but I must. My wallet is on fire, and i'm pretty sick of it. I lose, you gain.....you know how it goes. any specific info, just PM me. Vehicle is now roadworthy, and kickin' ass! Mod list: Engine: (note all rotating assy has been balanced) 99.5mm Wiseco forged pistons Replaced block w/ 11k 2011 STI block Eagle Connecting rods Nitrided Subaru crank New STI main/rod bearings STi 11mm oil pump Moroso oil pickup BNR HTA68 Turbo (300 miles on rebuild, and balanced by BNR) Subtle solutions alternator cover Gates racing Timing belt Custom stainless oil line setup w/ FP inline filter for turbo Deatschwerks 850cc injectors Racer-x FMIC Forge recirc BPV TGV Delete Grimmspeed 3-port EBCS SPT Short Ram Intake SPT Turbo Heat Shield SPT Battery hold down Invidia Quad Tip Catback Perrin Lightweight Crank Pulley Perrin Catless Divorced Wastegate Downpipe Group N Engine Mounts NGK One Step Colder Iridium Spark Plugs LFR7AIX ACT Streetlite Flywheel FMS Uppipe (welded cracks, rewrapped) Secondary air delete Wrinkle red Valve covers AEM 1 gal. water/methanol injection/aem filter Transmission: Group N Trans Mount Group N Pitch Stopper Group N Trans Crossmember Bushings Group N Rear Shifter Bushing Perrin Front Shifter Bushings ACT 566 ft.lbs. Pressure plate ACT full face sprung clutch disk Techna-fit stainless clutch line Amsoil 75w90 Severe gear Suspension: Perrin 25mm Front Sway Bar Perrin 25mm Rear Sway Bar Perrin Adjustable Rear Lateral Links (Camber) Kartboy Front and Rear Endlinks SPT Chassis Underbrace STi Front Strut Brace Tein S.Tech Springs Whiteline rear diff insert lock down bushing Wheels/Tires: Black Powdercoated Rota Torque 18x8 +48 Bridgestone Potenza RE050A 215/45R18 Brakes: 2007 STi Brembos F&R rear brembo adapters Cross drilled/slotted/powdercoated rotors Techna-fit Black coated SS brake lines ATE Super blue fluid Grimmspeed master cylinder brace Interior: Stock Navigation 12" TC Sounds LMS-R DVC Subwoofer JBL GTO 600.1 Amp DEFi -20Hg to 30 psi boost guage AEM UEGO afr guage AEM water/meth 1000cc flow guage AVO 52mm dash pod JDM/EDM center console Rewrapped Shift knob in black alcantara with cherry blossom red stitch Exterior/Lighting: Taillight Smoked Lamin-x Overlays Tinted Rear Reflectors "Roll-pan" Blacked Out De-chromed Taillights De-Spoilered De-Mudflapped Rear Windows 20% Tint Baked Headlights Painted Inner Housings Diode Dynamics 4300k HID Kit Yellow Fog Bulbs Redline Tuning hood struts Liberty Badge JDM Stanza Type II Trunk Lip Spoiler JDM Double L badge overlays Body color matched Fog light covers Ravspec CF grill |
Please insert the missing information in the template I added to your OP and some interior shots need to be uploaded, not linked to Photobucket, to the site. Also, links to adds on other sites (i.e. Craigslist) aren't authorized.
Youre not going to sell this saying many miles, many mods.
wtf, people.?
When i posted you had nothing but, i hate to have to do this its for sale, and a couple pictures.
Oh, gotcha. :lol:
Wow...that's alot of mods on the car. Should be worth it.
Thanks. Good news today. BNR said the turbo inspection went well. No issues found. Now waiting on its return.
Beautiful car!!
Reassembled, and driving today. still smokes a little. dropped price for further repairs. $23k
And to update yet again......I pulled the engine again, and found a crack in cylinder #3. After lengthy discussions with a few engine builders, a mechanical engineer, and another machinist, I/we have discovered the problem resulted from faulty boring procedures. I won't get into it, because it really doesn't matter anymore. I have gotten a 11k mile STI (2011) engine block at stock bore (99.5), bought new 99.5 wiseco pistons, and will be reassembling all this junk when I get the parts back from being balanced. Items being balanced will be, crank pulley/sprocket, crankshaft, rods, pistons, flywheel, clutch disk, and pressure plate. while in this process, I have disassembled/cleaned both heads, lapped all 16 valves in, readjusted all the valves, and replaced all intake/exhaust valve seals. I will also be getting the tune adjusted for the new buyer. reasons for the tune adjust is because two exhaust gaskets were leaking, both tgv seals were leaking, all the valves were slightly out of adjustment, and I believe the cracked cylinder was present prior to the tune. I have blown over another $1k in parts to fix this thing, so the price will be going back to the original $25k.
More info on the JDM/EDM center console swap?
My money says he's not gonna sell now... this new engine is going to rip!
| All times are GMT -6. The time now is 01:24 PM. |
