FS (NJ): JDM 00-04 Legacy HID Headlights Adjustable Beam Height - SOLD
5 Attachment(s)
SOLD
JDM OEM 00 -04 Legacy HID Headlights with electric adjustable height HID Ballast is attached to the unit along with the height adjusting motor. You need to get a height adjusting switch, but they not hard to source along with plug and wiring. Condition: - Slight crack on the edge of outer lens cover by the turn signal(Pictured), was glued and fixed, you can swap the lens cover from your headlight if it bothers you. - Other wise good shape Asking $190 now asking $175 shipped, my 00 GT is gone, don't need them. |
Your pictures need to be uploaded directly to the site as linked photos are not authorized. Edit your first post, go advanced and select the paper clip (manage attachments). From there you can upload the pics from URLs or your computer.
okay got pictures up my bad
$175 shipped
How/where do you source plugs from to plug them in?
thanks Ben |
Are these HID hi/lo or HID lo only and then halogen on the highbeam. Are the top corner lenses amber or clear? It's difficult to say if the lenses are amber or if it's just the amber bulb reflecting off the housing.
if you think it is too pricey, i can splice the wire the USDM plug on for a couple bucks. |
still have it? and how much for the splicing included so that i can just plug n play. It fits onto my 3rd gen legacy L rite?
$200 shipped, fits gen 3 just wondering does the L have a high and low beam bulb?
yea it does have high n low beam bulbs.. i will have to get back to you because i mite be purchasing other headlights for 125. if that doesnt go thru well then ur up next.. lol
My 03 L SE Wagon only has one bulb. Might want to double check what you have just to be safe.
these are dual bulb, low HID Halogen high
these will work on single lamp headlights as well FYI, i have these great lights glws
| All times are GMT -6. The time now is 02:37 PM. |
