Perrin turbo inlet and sensor?
What does everyone do with this? I cant see any way with the kit to make these two go together. HELP please.:confused:
http://i433.photobucket.com/albums/q...7-21153952.jpg |
Found out what it is.
PCV Diagnosis Connector | P1491 Positive Crankcase Ventilation (Blow-by) Function Problem | detects BLOWBY |
It may detect blow-by in some country, somewhere. Here in the states (and in Japan) it's just a fancy piece of plastic that does nothing but provide a passover for the wiring harness plug on it. You can just leave it as it is and tie it off to the side, or unclip it and run a wire across from one plug to the next.
Regards, Paul Hansen www.avoturboworld.com www.facebook.com/avoturboworld |
read the directions it came with.
It does not sense anything. It just makes sure it's plugged in. I had same problem.
| All times are GMT -6. The time now is 02:07 PM. |
