Subaru Legacy Forums
-   Cosmetic/Electronic (http://legacygt.com/forums/forumdisplay.php?f=118)
-   -   Subimods Hella Horn Bracket & Harness - Easy install for your Supertones! (http://legacygt.com/forums/showthread.php?t=189754)
Subimods 07-20-2012 01:32 PM
"The Original"
http://www.subimods.com/media//original_bracket.jpg
http://www.subimods.com/media/catalo...m/img_9658.jpg
[SIZE=3][COLOR=black][SIZE=2][B]
Use the link to purchase the new lower priced bracket:
http://www.subimods.com/subimods-com...s-bracket.html
[SIZE=2][COLOR=#000000][B]Subimods Hella Horn Harness kits are also available to make things Plug & Play
PM us for a combo deal on Bracket, Horns and Harness!!!
THE ORIGINAL, with over 10,000 Brackets Sold, THIS IS PROVEN!
Subimods.com is proud to offer the 'One and ONLY' Hella Supertone Horn Bracket for your Subaru! Designed from scratch with various designs and quality construction, we are releasing our exclusive horn bracket. Designed for an EASY install of your Hella Supertone Horns and to dress up the 'not so pretty' front grill background. This bracket takes all of the guessing and extensive time trying to figure out if your horns will end up centered, lop sided etc. This bracket takes all the fuss, all the trouble, all the headache right out of the question. Go with a product that you know will work the first time! Search online, search the forums, and see for yourself, the Subimods Hella Horn Bracket is proven! With thousands of over-satisfied customers, you too will see why this part is so popular!
Do not forget our Hella Horn Wiring Harness Kit, designed to make your Hella Horn install a breeze! We also offer different powder coated colors for the Hella Horn. Why waste your time disassembling the horns and sending them out yourselves? We've done the hard work for you! Both of these additional products can be found in the Related Products section!
Product Details:
  • - Constructed of Billet Aluminum
  • - Powder Coated Black
  • - CNC Machined IN HOUSE (Not out sourced or from another "online facility")
  • - Quality bends for reinforced rigidity
  • - Sets horns in perfect mounting position
  • - Installs in minutes!
  • - Patent Pending!
  • - Contact for additional powder coated colors!
Fitment:
  • - 99-01 RS/GC
  • - 02-07 Impreza
  • - 08-12 Impreza (must bolt in second bolt hole to prevent hood latch from rubbing)
  • - 05-12 Legacy
  • - Forester
There have been a lot of questions as to how you install the Hella Supertone Horns/Bracket/Harness so we have gone through and made a detailed How-To Guide to help out our customers :D
These are step by step and very easy to follow. Main reason for this is because the 08+ Impreza platform needs the bumper to be taken off, this scares some but it really isn't that big of a job to do!
We hope this simplifies the install for everyone.
Thanks, Subimods
Installing the Hella Supertone Horn Kit with Subimods Wiring Harness and Mounting Bracket 2008-2013 WRX/STI
Subimods Hella Horn Bracket Mounting Guide
Subimods Hella Horn Wiring Harness Information Guide
Notes:
  • - Get the original Hella Horn Bracket from Subimods.com! Need a set of Hella Horns? Add them below!
  • - Choose your Hella Horn Color!
  • **Additional time may be required on powder coated parts, so allow 1-5 days, this is a rare case and due to a high volume demand!**
NOTE: Our Hella Horn harnesses are designed to work with a standard 5 pin relay. Our harness will power the horns with a 4 pin relay but will cause the relay to stay engergized even when the car remains off causing battery drain. We can not guarantee that the relay supplied with your Hella Horns is a 5 pin relay as is required with our harness, so we have now included with every harness a standard 5 pin relay that is needed to make our harness work properly.
Subimods 07-22-2012 07:26 PM
to the top!
iahtnoob 07-22-2012 07:45 PM
do you sell the 5 pin relay separately as I'm sure the harness that I purchased from you more than a year ago came with the 4 pin relay?
Subimods 07-23-2012 09:45 AM
Yes we do sell relays, shoot us a pm and we can discuss the matter a bit more.
Thanks!!
Manchito 07-24-2012 09:59 PM
have you received my pm ? :lol:
Subimods 07-25-2012 01:38 PM
Got it, to the top for a great install and better quality.
Subimods 07-30-2012 12:22 PM
to the top!!
Subimods 08-02-2012 12:40 PM
Easiest install for Hella Supertones!
Subimods 08-03-2012 10:19 AM
Original Hella Super Tone Bracket and Harness available here.
Get yours TODAY!!
Subimods 08-04-2012 09:16 AM
to the top!
Subimods 08-06-2012 09:54 AM
Monday everyone, we are here all day.
Subimods 08-07-2012 09:38 AM
Let us know if anyone needs anything!
Subimods 08-08-2012 10:10 AM
to the top!
Jollyred 08-08-2012 02:32 PM
Do you have any pictures of the install?
Subimods 08-09-2012 02:22 AM
I will post some for you in the morning!
