"Bullet Proof" TMIC Kits
CONTACT ME DIRECT HERE WITH ANY QUESTIONS: bptmic@gmail.com
Hi everyone! For those of you who read this post http://legacygt.com/forums/showthrea...rx-158870.html you already know what this is. For those who haven’t read it, if you are still running you 05-09 LGT or 08+ WRX with the stock TMIC I highly recommend taking the time to read through the thread. This modification has been around for some time now as an alternative to those looking to beef up their stock intercooler (either for durability or for increased boost levels) for a reasonable price—not everyone has the cash or the need for an aftermarket TMIC in order to meet their needs. One of the problems with the kit up until now is that the fabrication of the metal pieces required for the kit is difficult, time consuming, and potentially dangerous to those without a reasonable amount of experience in cutting metal. While my second attempt and making my own kit was successful, the first attempt ended with a pile of bent metal and bloody fingers. With SeeeeYa’s permission (Thanks, Jeff!), I have been looking at some scenarios to get a number of kits fabricated professionally by a machine shop and I believe this will prove to be the solution to providing these kits to those who need them at a reasonable price. I’m pretty confident that the machine shop is set to produce some kits for me, and I’ve been given the go ahead to move forward with this as a homebrew vendor to supply them. Two kits will be available:
To confirm, here’s what will be included in the kit:
Where can I get the tool to tighten the stainless steel zip ties??? A few choices: NAPA Autoparts, Amazon ( , or I prefer ). I also think that some Autozone's rent them for "free" (you pay for it, then return it when you're done through their rental program). I’ll keep a running list of those interested going here for now. If you have been added to this list mistakenly please let me know. Here's the list so far:
UPDATE (7/24): after a hiccup with the first shop, material has been dropped off at shop #2. UPDATE (7/31): machine shop has pushed the completion date for the millwork back to 8/10. Assuming this date holds true, the first kits will be in the mail on the 11th of August. UPDATE (8/13): All the material is in hand and the first 8 kits are ready to go. As soon as I have the banding tools for the zip ties to include with these kits they will go out! UPDATE (8/14): First kit shipped out, 14 kits sitting on the shelf ready to go :) UPDATE (9/26): My current stock of material has all been cut into kits and will likely be sold out shortly. Three kits remaining at the moment before I have to look at the possibility of another production run. Thanks for the orders, everyone! VERY IMPORTANT CAVEAT: The term "Bullet-Proof" when used in referring to this kit is not meant to imply that installing this kit will make your OEM TMIC impervious to high speed munitions fired from any sort of projectile weapon, device, machine or similar. This kit is only designed to prevent boost pressure from causing end tank separation, and nothing more. DISCLAMER Neither I nor the original designer of this kit can take responsibility in the case of damage to anything on your vehicle that results indirectly or directly from the installation of this modification. If you doubt your capacity, do not undertake the installation of this modification; ask for help or have it installed by someone qualified. |
bump for a good deal.
I'm the proud recipient of the first Barman kit and am very pleased to report that it shipped quickly and works like a charm. Might need to do a little filing on the corners, but all-in-all a great, cheap way to ensure the life of the stock IC. |
This saves me all sorts of trouble. Add me to the list, kit #2 please. Thank you for putting together this package!!
I should also mention that I would like for someone local to test the kit with the zip ties if possible prior to shipping all the remaining kits. Local means the Northern Virginia area. Let me know if you are interested in testing fitment / installation.
where do you get those 33'' ss zip ties if u dont mind me asking
Thanks BMB for getting this done!
I may have read this in the original thread and forgotten, but why is there only one short piece (for the front passenger corner) and not four (one for each corner)? |
Thanks for the explanation. I'm in for Kit #2.
Come on gang let's get a couple more commitments! I'm going stage 2 this weekend and need this to get me through until I'm ready to go with a PW TMIC (or the Grimmspeed if it's the right setup for me and is released in the near future). Cheap way to reinforce the OEM TMIC without the hassle or need for tooling to DIY!
I hope this kit is still available next march. I hate not having money!
maybe BMB will do a layaway plan for poor people
Doesn't this kit work for more than just the 05-09 LGT? I seem to remember SeeYa doing it on his current generation WRX. Would it be worth reaching out to some of those owners as well?
| All times are GMT -6. The time now is 11:16 AM. |
