Subaru Legacy Forums
-   Member Classifieds - ARCHIVE (http://legacygt.com/forums/forumdisplay.php?f=86)
-   -   FS: (CO) 2005 OBP Legacy GT Limited full part out (http://legacygt.com/forums/showthread.php?t=189329)
Money 07-13-2012 04:28 PM
20 Attachment(s)
Ok, let's try this again. My last thread got deleted because I didn't upload the 250 pics of each and every part I have listed so I will start that process now.
2005 Subaru Legacy GT Limited sedan
Obsidian Black Pearl w/ tan leather interior
VIN: 4S3BL676354204515
5EAT transmission
85K miles
Wrecked direct front into a pole, also damage to passenger rear door/trunk. No suspension damage whatsoever.
All parts located in Denver, CO. All parts are OBO.
If it isn't listed, I don't have it. Please read through the parts list, including the SOLD parts list, before posting your WTB.
I have multiple pictures of most everything. Instead of searching through the attachments to find your part, just PM me and I'll send it to the pics I have.
Parts List:
Interior
-Accelerator pedal assembly w/ plug- a must if you are doing a drive by wire motor install- $35 shipped
-Brake pedal assembly w/ sensor- $40 shipped
-Automatic shifter assembly- light scratches- includes the cable that runs to the actual transmission- $60 shipped
-Combination switch- left- $30 shipped
-Combination switch- right- $30 shipped
-Rear trunk latch cover- the plastic piece that hides the latch in the trunk- $25 shipped
-Heated seat switch w/ pigtail- $45 shipped
-Center console w/ cupholder assembly, armrest (not the extended one) and storage box w/ 12v socket- $80 shipped or PM me if you want specific pieces
-Complete sunroof assembly- sedan only, includes glass, motor, track, interior cover- $200 local only or will split up depending on what you need
-Window switches- Drivers master sold- $20 shipped each for all others
-Tan inside door panels- $40 each w/ out switches (all available) local only
-Blower motor- $80 shipped
-Heater core/ A/C assembly- $80 shipped
-Complete dash panel w/ passenger airbag intact- $100 local only
-AT shifter surround w/ ashtray- light scratches- $50 shipped
-Dash vents, chrome tabs included- (both sides available) $25 each shipped
-Drivers kick panel- $30 shipped
-Power mirror switch- $25 shipped
-Wood grain center console trim pieces- $30 shipped
-Dome light- $5 buy it with something else and I'll throw it in
-Tan visors- $40 for the pair shipped
-AT gauge cluster 85K on the odometer- $80 shipped
-Rear foam spare tire cover, OEM jack kit- $40 local only
-Interior fuse panel- $35 shipped
-Map light and sunroof switch assembly- $35 shipped
-Interior door panels (door cards)- Tan- no switches- $40 each or $150 for the set local only
Exterior
-Fog light trim piece- drivers side OBP color- all tabs intact- $30 shipped
-OBP hood scoop- very nice condition- $65 shipped
-Hood scoop ducting- $20 local only
-Rear window- sedan only- professionally removed, no damage to defog elements, no tint- $100 local only
-Door glass (passenger front available)- no tint- $45 each local only
-Door shells (passenger front available) exterior handle included- $100 for shell- $150 for shell w/ glass and window motor/regulator local only
-Rear bumper beam and foam “absorber”- $75 local only
-OBP sideskirts- $50 each or $75 for the pair local only
-Fuel door w/ gascap OBP- $25 shipped
-Engine cover- broken on the top passenger side, great for someone looking to trim one for a big top mount or FMIC- $20 local only
Mechanical
-5EAT transmission w/ torque converter and flex plate- $600 + shipping OBO
Code TG5C7CWABA-Z1
5spd automatic
1st 3.540
2nd 2.264
3rd 1.471
4th 1.0
5th 0.834
final reduction 3.272
85K on this unit, diff fluid looks great trans fluid doesn’t smell burnt and is clear. One of the rear mount bolts is broken from the wreck- shouldn’t make any difference, but it’s pictured below. I did get the wheels spinning on this car up on jack stands, the trans shifted fine through all 5 gears both in “D” and in the manual mode. The trans was obviously working fine when this guy rammed a pole, I don’t see any reason it would not be in useable condition now.
-Turbo front crossmember with steering rack- no outer tie rod ends- $150 OBO local only
-Rear subframe w/ rear swaybar- $50 local only
-K&N air filter should fit ’05-09 LGT’s and ’08-up WRX’s and STi’s- $35 shipped
-A/C pressure sensor- screws into the a/c line- $15 shipped
-Front ABS sensor- $25 shipped
-Automatic Trans computer- will need to be installed/mated with an ’05 trans from what I have read- $100 shipped
-ABS computer- drivers front airbag blew- not sure if these need reset or not- $50 shipped
-Battery cable- from battery posts to starter- $30 shipped
-Battery cable- from battery to alternator, p/s- $25 shipped
-AT only starter- $80 shipped
-Underhood fuse box-$30 shipped
-P/S pump- $100 shipped
-Knock sensor- $40 shipped
-Coolant crossover pipe- $25 shipped
-Upper engine coolant tank- $45 shipped
-Window motor w/ regulator (all available)- $65 each shipped
-ABS pump or distribution block- $80 shipped
-Brake master cylinder w/ reservoir- 15/16”- $50 shipped
-Power brake booster- $45 shipped
-Complete fuel pump assembly w/ sender- $125 shipped
-AT driveshaft- used for 6-speed conversions- $50 local only
-Windshield wiper motor assembly- $60 shipped
-Windshield wiper arms- $30 for the pair shipped
-Complete front clip wiring harness- everything forward of the b-pillars included w/ connectors- $200 shipped
-Drivers front CV joint- $60 shipped
-Rear CV joints- $60 shipped each
-Rear strut assembly- 85K on chassis, these look stock, no leaks, includes struts, springs and tophats- $150 for the pair shipped
SOLD PARTS LIST
-A/C compressor- $80 shipped-- SOLD to lucas569
-Dash endcaps- SOLD Rester5350
-Front lower control arms, great to install a bushing kit and not have any downtime on your car- $100 shipped for the pair-- SOLD to TeriyakiBBS
- Front door wiring harnesses-- SOLD to flander
-“Subaru” door sill plates- $40 for the set of 4 shipped- SOLD to fullmonte77
-OBP rear emblem panel from trunk- stock lettering- $80 shipped-- SOLD
-Factory 6 disk radio/HVAC controls- $90 shipped-- SOLD
Money 07-13-2012 04:34 PM
20 Attachment(s)
More pics since I can only upload 20 at a time.
Money 07-13-2012 04:39 PM
20 Attachment(s)
More.
Money 07-13-2012 04:43 PM
12 Attachment(s)
Don't worry, it's almost over. :)
2009 specb 07-13-2012 06:51 PM
Now that is a part out. goods luck with the sale!
dustdown 07-15-2012 04:04 PM
pm sent
flander 07-15-2012 06:14 PM
Do you have the front door cords. The wiring that goes to the mirrors from the kick panel area. I'm interested in both of them.
Money 07-16-2012 07:33 AM
The door cards (the interior door panels)? Yes, I have them but I'm not shipping them.
The door wiring harness is one complete harness that runs through the rubber grommet in the door jamb and plugs in under the carpet in each footwell. There is no "mirror" wiring, it's part of the whole door harness. I'll sell you the complete door harness for $60 shipped for the pair of front doors.
BLACKeNeD 07-16-2012 09:24 AM
Is the Driverside Kick panel the part that is above your knees?
If so, I will take it if you would consider shipping. I would also take this part, again, if you're willing to ship the parts to 10962
http://legacygt.com/forums/attachmen...1&d=1342218805
lucas569 07-16-2012 09:56 AM
payment sent
OptimumLGT 07-16-2012 07:20 PM
Pic of the rear bumper cover?
Money 07-16-2012 09:02 PM
I have to retake those, they turned out awful. If you are near Arvada or Wheatridge just come take a look at it.
flander 07-17-2012 05:33 PM
payment sent
bman 07-18-2012 11:49 AM
looking for the plastic handle in the trunk that lifts the carpet to access the spare. got one?
BraddA 07-19-2012 10:03 AM
Didn't see it listed but thought I'd ask: cargo cover/trunk mat?
