FS (WI) Brembo Front Brake Setup - SOLD
5 Attachment(s)
Moderator, Please close, Everything SOLD
These are from an '08 STi Bought from another member but never installed, went different route. 1) Brembo Calipers, Pads, Rotors $750.00 Shipped SOLD to scoobydoobie They have been rebuilt and assembled. New seals, dust boots and bleeder valves. Includes New OEM spec brake pads. They are used but in beautiful condition. They have never been installed since the clearcoat was done. Black powder coat w/hi-gloss clear coat to protect the finish. 2) BNIB 5x100 Centric Premium High Carbon Rotors $250.00 Shipped SOLD to scoobydoobie 3) Stoptech SS Brake Lines, Front, 950.47005 $100.00 Shipped Both SOLD to dr_sharp Stoptech SS Brake Lines, Rear, 950.47505 $65.00 Shipped Both for $150.00 Shipped |
Are those centric rotors 5x100 or 5x114.3?
5x100 |
only asked cuz centric 125.47022 is a 5x114.3 rotor, been trying to finally cure my rotora rotor problem
Bump TTT
The rotors appear to be drilled for both. Most manufacturers are reducing part numbers by doing so. My DBA T2 fronts are dual pattern also.
bump
anything else needed to install these on an 05 LGT?
good fukin deal. wish I had waited on my brembo swap
I will take the rear SS lines.
Those are some nice looking calipers. |
^you will also need new bolts to bolt the caliper to the hub. The ones on the sti are different.
PM's replied
Payment sent for F+R SS lines. Thanks!
| All times are GMT -6. The time now is 10:21 AM. |
