Headers--Equal or unequal Length
The PROS and CONS of unequal vs. equal length headers..What does everyone think?
Search in the Exhaust forums - plenty of debate on this topic there.
el for people who want the most power
uel sound of efficiency:) |
uel ftw! gotta keep that subie rumble :)
The general consensus among those who have done headers before is get a quality set of EL, or stick with manifolds and save your money. The real gains are with EL, UEL is just perpetuating factory inefficientcy.
You should wrap them as well. |
Im going equal length so I dont crack my 2 and 4 pistons again. Oh and the slightly added power. And so people will think my outback is N/A.
Unless you're going equal, don't waste your money.
Couple of threads with good information: http://legacygt.com/forums/showthrea...si-126076.html http://legacygt.com/forums/showthrea...di-187709.html |
^huh? not sure what kind of gains you speak of with UEL besides gain of exhaust loudness.
OP I have Tomei EL headers, which by the way are a work of art. i dont have a base dyno but after installing them i put down 347 ft-lbs on stock injectors turbo and motor. some dont like the way they sound (sounds like a smoothed out boxer) but I for one love it. You wont get much HP gain from headers either way you go, but you will get a bit more torque out of EL |
I put down 347ftlbs also. Stock block, turbo, injectors. Also I was running a old ass tune from infamous which I wasn't tuned for the header or the tmic at the time. Wonder what I'll put down now that I'm running a tune for the header. Well it was tuned for the tmic and now I run a fmic but meh. |
| All times are GMT -6. The time now is 12:25 AM. |
