Subaru Legacy Forums
-   Member Classifieds :: Full Vehicle Part-Outs (http://legacygt.com/forums/forumdisplay.php?f=112)
-   -   FS (NJ): 92ss Legacy Turbo TW / WRX, SS Partout (http://legacygt.com/forums/showthread.php?t=187540)
sqc151 06-13-2012 06:36 PM
sqc151's ongoing for sale thread.
17 Attachment(s)
Location: Wharton NJ. (please search where it is before posting)
you dont have to pm me if i still have a part. I always update the first post.
if its listed i still have it.
I have a ton of stuff. If you want a picture of something PM me.
No Shipping of large/heavy items.
ENGINE
rob tuned jdm ecu - 450
(I got this ecu from Rob last year and paid almost 500 for it with the converter)
(these are the options)
- tuned for td05-16g turbo @ 18psi
- 550 sti inj
- 255 fuel pump
- 06 tmic
- cel knock indicator - yes
- launch control - yes
- launch control rev limiter - 6500
- launch control speed disable - 2mph
- boost cut - off
- max boost - 18psi
- speed cut - off
- rev limiter - 7100
(I will not take less than 450 for it, I bought it and never used it)
05 LGT throttle body - 300
2.2 closed deck block w/internals - 600
2.2t complete heads - 200
td05h-16g turbo- 450
vf11 turbo - 60
ams 3" muffler - 200
turbo exhaust manifold - 100
catless dp w/ o2 sensor - 100
catless up-pipe - 80
turbo intake manifold w/ diamond coilpack - 60
92-94 fuel rails for 550 inj - 20
06+ wrx tmic w/ y-pipe, bpv and blue samco hose - 100
02-05 samco tmic black hose kit (new) - 150
(2) bpv flange - 30 each
megan engine/trans/pitch mounts (new) - 200
stainless fuel Lines w/ fittings - 50
jecs maf - 40
k&n filter (new) - 40
wrx coolant tank - 40
ss alternator - 80
red fmic hoses - 50
oil filter cooler - 20
wrx starter - 50
wrx power steering res - 20
sohc turbo timing covers - 20
turbo chimney - 20
DRIVETRAIN
05+ LGT 5sp trans (no 3rd gear) - 300
91-94 5sp turbo trans w/ xmember - 400
5sp exedy clutch w/ flywheel - 150
6sp racing clutch w/ flywheel - 200
4.11 open rear diff - 40
91-94 manual driveshaft - 20
f/r ss axles - 20 each
5sp trans mount - 20
5/8" f/r wheel spacers - 20
2 hubcentric rings - 10
BRAKES/SUSPENSION
wrx caliper brackets - 20
wrx stock springs - 40
wrx front swaybar w/endlinks - 50
wrx control arms - 80
ss control arms - 60
ss hubs - 40
ss front brake kit - 150
ss rear brake kit - 100
INTERIOR
02+ wrx momo steering wheel - 100
2 gauge pillar pod - 10
05 LGT center gauge pod - 40
89-91 gauge cluster w/145k - 20
aluminum manual shift knob - 40
cargo tray - 20
93 ss mint front seats - 60
91 ss front seats - FREE
EXTERIOR
91 EDM electric leveling headlights/corners - 300
91 tail lights - 50
1st gen legacy mudflaps - 40 a set
sqc151 06-24-2012 08:44 PM
bump.
sqc151 06-27-2012 06:39 PM
bump.
sqc151 06-30-2012 10:03 AM
bump.
sqc151 07-01-2012 08:59 AM
bump.
sqc151 07-08-2012 10:47 AM
bump.
mr_hicksta 07-09-2012 08:04 AM
You're missing an awful lot of pictures. If you have an item listed there needs to be a picture.
sqc151 07-09-2012 09:51 AM
After reading the rules and SBT checking it. Bulk pics was fine cause I have so many parts.
mr_hicksta 07-09-2012 10:13 AM
Didn't know SBT had blessed off on it.
Carry on ;)
sqc151 07-09-2012 12:15 PM
ill get more bulk pics up tonight.
sqc151 07-14-2012 10:15 AM
bump.
joelwatts 07-14-2012 10:53 AM
Boo for no shipping. Free bump
sqc151 07-14-2012 10:56 AM
Keep reading, if it fits in a usps flat rate box ill ship it. I just won't ship the large objects.
And I can only ship to the 48 states. Will not ship to canada because of customs. (Took me 9 months to get a part)
joelwatts 07-14-2012 12:19 PM
The x-member wont fit in one of those boxes.
sqc151 07-14-2012 12:30 PM
Because shipping it cost to much
