Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   What turbo to use 09 LGT (http://legacygt.com/forums/showthread.php?t=187309)
trepetti 06-10-2012 07:48 AM
I need to know what is the stock turbo on my 09LGT, along with some suggestions on a modest size upgrade.
I had the oil feed pipe on my 09LGT crack. I have all the piping /gaskets, but the unanswered question is 'Has the turbo been starved of oil and do I need to replace it'?
I am running a stage 1 tune and have no intention to go any more, except maybe a new intercooler and bigger injectors.
Any help is appreciated.
Thanks
cypher0117 06-10-2012 08:28 AM
I just had the same question about my 05. I found this:
http://legacygt.com/forums/showpost....76&postcount=3
Code 06-10-2012 08:51 AM
Intercooler is reccomended if you go past stage 1
Injectors will only be needed if you get a larger turbo or e85. At that point you should have already done: down pipe, fuel pump, clutch.
If you get a larger turbo, depending on how much peak boost you'll be running, you should also be considering: ebcs, bov, intake, suspension/brake mods to keep her rubber-side down
IMHO you should spend a few days searching this site, then come back to This thread and ask some more detailed questions.
RabidWombat 06-10-2012 10:51 AM
Pull the turbo check for shaft play.
Stock turbo: VF-46
Mild upgrade: BNR 16g (tune required, downpipe recommended, no other mods needs)
Modest upgrade: 18g/VF52 (tune, downpipe, possibly injectors)
fahr_side 06-10-2012 11:40 AM
http://legacygt.com/forums/showthrea...st-178684.html
dr_sharp 06-10-2012 05:45 PM
I had my oil feed line crack and the turbo was fine. But I lost almost no oil at all before I discovered the leak. This happened around 10k miles and the turbo was still running strong at 80k miles when I upgraded.
dr_sharp 06-10-2012 05:47 PM
Originally Posted by Code (Post 3931687)
you should also be considering suspension/brake mods to keep her rubber-side down
:lol::lol::lol:
well worded
Max Capacity 06-11-2012 08:17 AM
I'd go with a vf52 and get it tuned. If you haven't upgraded the DP it's a go time to do it.
Also if you can, remove the studs in the up pipe and replace them with good bolts. I got my bolts and nuts from the dealer. It's much easier to install the turbo and new oil return line, hint, hint, hint.
Use anti-seize compound on the nuts and bolts.
