Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=115)
-   -   Subimods Coilover Specials: BC Racing, ISC, Tein, Cusco. Receive a $25 Gift Card (http://legacygt.com/forums/showthread.php?t=186587)
Subimods 05-29-2012 11:42 AM
Hey Legacy GT, were looking to bring some great deals on coilovers, check below for the item specific deals on all of the name brand coilovers you have come to know. If you don't see something here pm us.
ISC N1 Coilovers:
Purchase a set of ISC Coilovers and Receive a $25 Dollar gift card
All coilovers come with a 12 month warranty to put your mind at ease, if our product fails in any way in the first 12 months we will pay all postage, labor and parts costs to fix the issue in minimal time. If our product fails after that initial 12 month period we will replace the product at trade price! We never stop looking after our customers.
The N1 coilover can be lowered approximately 3 inches lower then standard ride height, this along with a spring rate setup to suit your car improves handling and stability dramatically. we make packages for track/rally/drag and of course street, to help our customers out even more we give them the option to pick there own custom spring rates at no extra charge.
32 Step Damper Adjustable
* Precise control damp valve
* Operates smoothly on all road surfaces
* Expansion/Suppression of shock adjustment
Pillowball Uppermount
* Adjustable camber allows more/less on road track for all conditions
Piston Rod Design
* High rigidity steel piston rods
* Meets with race/sport standards
Sports Spring
* Made from high quality SAE9254 steel
* Tested over 500,000 times on compression inspection with less than 5% deformation.
Ride Height Adjustable
* Full length height adjustable
* Bound adjustable with separate spring locks
* High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminium Bracket
* Made from T6061 aluminium alloy by organic shaping to lighten weight and increase handling performance
* Specifically anodised surface to prevent inside corrosion and surface rust
* On various models camber can also be adjusted via the bracket as well as the camber tops
Single Cylinder Design
* Larger cylinder and piston design to advance driving stability and dexterity
Spring Rate: Street Sport 8k Front / 6k Rear
Racing/Drift: 10k Front / 8k Rear
BC Racing BR Coilovers
http://enjukuracing.com/images/BCcoils.jpg
Purchase a set of BC Coilovers and Receive a set of rear extenders FREE!!!
PM for pricing
Cusco Comfort ZERO-2E coilovers are recommended for those who want a sporty ride and increased handling without giving up daily driving comfort on their luxury vehicle. Height is double adjustable and the dampening force is adjustable allowing you to fine tune the suspension feel to your liking. As with all Cusco coilovers, rust proofing and the highest quality materials ensure your performance suspension will keep performing for years to come. Cusco's pillowball top hats will provide maximum feedback from your suspension and reduce play in the coilover assembly keeping your alignment truer in turns. Camber is adjustable via the front plates as well. The ZERO-2E are compatible with the Cusco e-Con digital damping force controller. The spring rates can be altered, contact us regarding custom spring rates.
<LI style="MARGIN-LEFT: 15px">Spring Rates: F: 8kg/mm, 448lb/in R: 8kg/mm, 448b/in <LI style="MARGIN-LEFT: 15px">Upper Mounts: adjustable pillowball front, non adjustable pillowball rear <LI style="MARGIN-LEFT: 15px">Adjustability: Height, Preload, 5 Step Dampening Adjustment <LI style="MARGIN-LEFT: 15px">Adjustability Range: F: -50mm to 0mm / R: -45mm to -0mm <LI style="MARGIN-LEFT: 15px">E-Con Compatibility: Yes
Tein Type Flex coilover suspension kits are designed to turn your 05-09 Legacy GT into the superb handling machine it should be without sacrificing too much comfort. Tein incorporated separate height and preload adjustments, which allows you myriad adjustments for all road, autocross and track conditions. Tein's twin-tube dampers are made for outstanding reliability and longevity. The Tein Flex damper kit includes pillow ball upper mounts and is compatible with the EDFC, for maximum performance for the streets.
Subimods 05-30-2012 07:58 AM
We are here all days guys, pm or call us to place an order or just inquire
Subimods 05-31-2012 08:55 AM
Subimods 06-03-2012 05:49 PM
To the top !!
Subimods 06-12-2012 08:05 PM
Bump for in stock items and ready to ship
Subimods 06-14-2012 12:36 PM
To the Top for some great coilovers
dpgriffin 07-01-2012 05:54 PM
need a set of coilovers for my 2012 2.5i. want to try and keep as close to oem ride if not better. whate the best set as well as best price. ive been looking everywhere just comes down to best deal. thanks please pm me
Subimods 07-18-2012 10:31 AM
To the top!
Subimods 07-20-2012 10:11 AM
Also check out the KW Variant 3 Coilovers for 2010+ owners!
Subimods 07-22-2012 07:27 PM
BC,ISC,KW,TEIN, and more all in stock ready to ship to you.
Subimods 07-26-2012 01:30 PM
to the top!
Subimods 08-01-2012 02:37 PM
to the top
Subimods 08-02-2012 12:19 PM
all in stock ready to go to you!
Subimods 08-03-2012 10:09 AM
Just got another few LGT BC's in today!
Subimods 08-06-2012 10:00 AM
in stock and ready to ship
