Subaru Legacy Forums
-   Wheels/Tires (http://legacygt.com/forums/forumdisplay.php?f=43)
-   -   Spec B Wheels on Regular Legacy GT (http://legacygt.com/forums/showthread.php?t=186462)
blue2.5gt 05-26-2012 01:22 PM
Hey guys,
I recently picked up a set of 07 Spec B wheels. I have an 05 legacy gt 5eat and I am trying to determine the best tire size. I want it to look good, and from the other threads I've looked at, there is no real suspension difference between the normal legacy gt and spec b. The guys at town fair tire recommended I get 215/40 r18 tires as that would account for increase in wheel diameter partially (also says the same in the sticky on top). However I am worried if a smaller tire like this won't look as good as going with the 215/45 r 18. If you were in my position what would you do? Would going with the larger tire (215/45 r 18) other than the speedo change affect performance?
Thanks
Drift Motion 05-26-2012 01:32 PM
225/40/18
blue2.5gt 05-26-2012 01:58 PM
i saw that in the sticky as GREAT for daily driving versus good, but i read that if you put a wide size on like 225 vs 215 you might get a bit of ballooning at the sidewall region. is this true? just trying to be sure i get this right as I am buying new tires, thanks
No DRFT 05-26-2012 02:06 PM
225/40 is ideal for that size.
Drift Motion 05-26-2012 02:07 PM
it's the closest to stock size
and it's a very common size, therefore easy to find
I believe those wheels are 7 inch wide, therefore yes it will balloon just a bit
blue2.5gt 05-26-2012 02:10 PM
thanks for the replies!
@drift motion that was my concern, they have the 215/40r18 available too. if the 225s would look better overall though I could go with those. the ballooning wouldn't really be noticeable right? and the performance would be affected negligibly too?
Drift Motion 05-26-2012 02:17 PM
http://i158.photobucket.com/albums/t...t/DSC_0167.jpg
this is 225 on a 7
It's barely ballooning
there will be minimal performance difference
blue2.5gt 05-26-2012 02:31 PM
@drift motion
oh i see thanks for the pic! so the 225 is normally used on a 7.5 inch wheel? would having the 225 reduce the handling? will there be increased sidewall flex?
i just went to look out at my car with the stock tire size on it and it looks like there is a slight balloon even there. im sure that even if the 225 has more balloon than a 215 would on an 18, it is a smaller overall height versus the 17" as the aspect ratio is lower, so im sure that would help negate the ballooning effect
piening2150 05-26-2012 03:00 PM
http://www.championgmcbuick.com/used...830&vk=2205822
That link is my buddy's 2007 Spec.B that he recently traded in. It has 225/40/18's on the stock Spec.B wheels. Looked and handled fine.
blue2.5gt 05-26-2012 09:49 PM
okay thanks so much for the responses, i think ill go with the 225 then
blue2.5gt 05-26-2012 10:54 PM
for the hankook v12's im looking at according to the pdf on the site it says that the rim width should be at a minimum 7.5" to run the 225. would i have to look at a different tire then?
scoobyscoodle 05-26-2012 11:40 PM
Yea it says 7-8.5" for the 225/45 and 7.5-9" for the 225/40, because it's lower profile so they recommend a slightly wider wheel. I would still go with the 225/40, it should look pretty square and is a better O.D. for your application.
blue2.5gt 05-27-2012 01:20 AM
would the 225/40 look better compared to the 215/40? is there an advantage other than that with the 225/40?
also why does it say in the sticky that 225/40 is better than 215/40 for a daily driver (great vs good)? thanks
scoobyscoodle 05-27-2012 03:09 AM
The 225 is slightly taller than the 215 so your speedo will be closer to what it should be and the bit of extra sidewall will provide a slightly smoother ride. Visually there isn't going to be a huge difference, but the 225 will look a little more meaty.
Garandman 05-27-2012 03:49 AM
Originally Posted by Drift Motion (Post 3913111)
this is 225 on a 7
The stock tire on several years of WRX was 225/45 on a 7" rim.
I never heard the term 'ballooning" in reference to that fitment. Is ballooning the opposite of "Hellaflush?"
