Subaru Legacy Forums
-   Intake and Exhaust (http://legacygt.com/forums/forumdisplay.php?f=73)
-   -   Anyone have a 3" DP to stock CBE? Need help tracking down exhaust noise. (http://legacygt.com/forums/showthread.php?t=184692)
paintpollz 04-26-2012 08:53 AM
Trying to find other humans with my setup. I have a divorced perrin DP thats mated to the stock CBE. I have exhaust drone, and I'm trying to pin it down, before I start ripping apart the entire exhaust system.
Its like unecessary drone between 2500 and 3800 rpm. Anything above that or below it, it sounds normal. It sounds like its coming from the drivers side of the car, but that might just be because I'm sitting on that side. I'm pretty sure its a different noise then the growl that the Dp makes at WOT, as the noises together are different sounding. Gotta figure out a way to track it down. Its tough because I never noticed it when I swapped in the perrin Dp, but that could just be because I wasn't paying attention.
stock headers, stock up, catted divorced perrin DP to stock CBE. If you guys could give me places to start, that would be great. I originally thought it could be a rotten gasket somewhere, but Lardo had that happen and said the noise was terrible all around. This is just bad between 2500-3800 rpms.
spec.B Dream 04-26-2012 11:10 AM
No issues at all with mine. I've ran both an ERZ bellmouth catless, CNT bellmouth catted, and currently Invidia divorced catless. I've had some leaks from time to time but replaced all gaskets and tightened up everything and was good to go. You sure it isn't a leak?
robitrice 04-26-2012 12:47 PM
i have a catless perrin DP and have zero drone i can hardly hear my car honestly. sometimes it is just the mind trick playing games on you. Inspect your resonator in the stock mid pipe for any holes or damage as well as the mufflers. I find it interesting you have a drone with the stock catback cause like i said i have the same setup and its hardly audible imo. Did you get a new donut gasket for the DP > CBE with a 3" adapter?
paintpollz 04-26-2012 08:58 PM
yep. new gaskets, donut and all. good call on the res
paintpollz 04-27-2012 11:35 AM
if in fact the sound was unique to the drivers side of the car, what could that possibly be?
robitrice 04-28-2012 05:37 AM
exhaust manifold? most of the exhaust is on the passenger side until the the dp meets the cbe where it is in the center.
paintpollz 04-28-2012 10:09 AM
ya shit thats what i figured.
paintpollz 07-27-2012 11:18 AM
bump.
noise is driving me goddman crazy. Can't really hear it 4000rpms or over. Anywhere between 2500 rpms and up, especially when I'm going up a slight incline or under any sort of load, its most noticable.
I'm thinking about replacing these gaskets. both UPs, both exhaust manis, and crossovers. I know the turbo to DP is ok, and the DP to MP is fine, because I replaced them all when I put the DP on, and with the stock CBE I used a fresh donut, adapter, and fresh 3" gasket.
I'm thinking I could have a rotted gaskets, otherwise, I don't know what else this exhaust noise could be coming from.
any more ideas?
cypher0117 07-27-2012 11:49 AM
do your mufflers rattle if you shake them?
BarManBean 07-27-2012 11:56 AM
Are you positive that you put the adaptor, donut, and 3" gasket in the right order at the DP-to-CBE connection?
You should have a normal 2-bolt (3") gasket up next to the DP, then the adaptor with the protrusion facing towards the rear of the car, and the donut gasket with the tapered end towards the rear of the car. Just trying to make sure here.
If that's the case, tighten the shit out of that connection just to rule it out for sure before you do everything else. Tighten each bolt a little bit at a time.
paintpollz 07-27-2012 01:10 PM
I don't think you can mess that up, but, I did install it in the correct way that you are mentioning. I torqued it pretty hard, hard enough where the stock cbe flang is bending all the way into the adapter
Max Capacity 07-27-2012 01:22 PM
Take the mufflers off and drive the car. See if the sounds still there.
Sorry I just found this thread, you should have emailed me. My wagon is catless, stock exhaust from the DP back, with 2 washers between the Y pipe flange and the mufflers.
No drone.
Some have said the exhaust tips may be to short also, they may need to be further past the bumper.
My Spec has stock exhuast less mufflers, no drone. The tips on the muffler deletes extend a bit further then stock.
paintpollz 07-27-2012 02:03 PM
No drone.
I would have emailed. It doesn't sound like its coming from the back of the car though. its more towards the engine. I guess the best way to figure out what's going on is to get it on a lift and see if air is coming out of any part of the exhaust
BarManBean 07-27-2012 02:08 PM
That sounds more like you tightened it WAY beyond where it should be. I would imagine you at least have a bit of a leak there. Mine bends a very slight bit matching up to the Cobb DP, but nothing like you are saying if yours is in fact touching the adapter :eek:
paintpollz 07-27-2012 02:19 PM
I mean its not flat against, but it bends towards it for sure.
I gotta get the thing on a lift and feel for air sneaking out while its running
