Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Exhaust and stock DP (http://legacygt.com/forums/showthread.php?t=184652)
stevekem 04-25-2012 03:55 PM
I'm looking to give my new LGT some growl.... I am on tight budget and I have to keep the cat on due to emissions here in PA.
If I keep my stock DP right now, what would be the loudest exhaust I can put on that will give me some growl?
I was gonna do the Hogzaust mod, but my flanges are corroded pretty bad...
I was looking between the Indivia Quad tip, Magnaflow and Borla CBE systems right now, which one would be loudest on a stock DP?
I looked at the exhaust page already and heard the tones for the different systems, but I wasn't sure which ones if any were using the stock DP.
Nrw 04-25-2012 04:02 PM
Loudest would be unbolting the stock cans
stevekem 04-25-2012 10:10 PM
What about a GMS CB with ERZ Catted Downpipe? I seen some comments that the quality and fitment is not that great, anyone here running this setup care to chime in?
Will I absolutely need a tune if I use this setup? Everything else is stock....
G5892 04-25-2012 10:34 PM
Youll need a tune for the downpipe. If you just get the catback, you wont need a tune.
stevekem 04-26-2012 04:03 PM
I decided to go with a GMS catback for now... I'd like to eventually do the up/down pipe, but will save that for later since I'm kinda low on cash :)
laff79 04-26-2012 04:52 PM
check out the CNT quad tip cbe.
499 shipped
stevekem 04-26-2012 08:51 PM
Thanks, but I actually already ordered the GMS so....
499 shipped
seabass07 04-26-2012 09:28 PM
A friend of mine has a cobb dp and no mufflers. It actually sounds good. A bit of drone, but not that loud, even on the throttle. Not even close to ricey.
stevekem 04-27-2012 07:15 AM
You would think it would be pretty loud with no mufflers. Maybe it's something with the DP that's keeping the sound down, well I guess it would have to be.
LieutenantDan 04-27-2012 07:23 AM
It's called a turbocharger
