Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   BNR Evo 16G -- too much shaft play? (http://legacygt.com/forums/showthread.php?t=184003)
thefultonhow 04-16-2012 07:43 AM
Click to play the video. I think I know the answer already, but I just want to check.
http://i14.photobucket.com/albums/a3...416_093304.jpg
BAC5.2 04-16-2012 07:51 AM
Borked, son.
thefultonhow 04-16-2012 07:53 AM
Would love to hear if anyone thinks differently, but I'll be contacting BNR... :spin:
bmx045 04-16-2012 07:54 AM
your finger would have been enough to check for shaft play
No DRFT 04-16-2012 08:00 AM
Try holding the turbo still. It seems like too much movement to tell.
thefultonhow 04-16-2012 08:05 AM
I don't have three hands, man! :lol:
If other people think I need to keep the turbo more stationary in order to tell whether it's too much shaft play, I can get another video when my fiancee comes home, but for now this is all I have.
BarManBean 04-16-2012 08:14 AM
Why are you pulling on it with pliers? Seems like that's more force than necessary to check for shaft play...not sure though...?
cypher0117 04-16-2012 08:24 AM
It'd be nice if the turbo was still, but it still looks like the gap is changing between the fins and the wall.
thefultonhow 04-16-2012 08:33 AM
So that my big fat hand wasn't blocking the light. :lol: I wasn't pulling super hard, but yes, I probably got a little more of a lever arm than if I were pulling with my fingers. Suffice it to say that there was a slightly, but only slightly, smaller amount of movement with my fingers.
Max Capacity 04-16-2012 08:41 AM
I could be wrong but no movement is ideal. If you have more than a little...Like you said, contact BNR...
Good Luck.
Oh BAC5.2 is pretty good twith this type of thing too...
BAC5.2 04-16-2012 08:54 AM
Sleeve bearings will have some play without oil pressure supporting them. That turbo looks like its got too much play.
Any thrust play?
thefultonhow 04-16-2012 09:08 AM
Originally Posted by BAC5.2 (Post 3848648)
Any thrust play?
You mean in/out? No, not that I could see.
fahr_side 04-16-2012 09:31 AM
Seems to have a bit more radial slop than is healthy but you look to be using a lot of force and the turbo is moving around a lot too. Can you get the blades to touch the housing or even within 0.5mm of touching?
thefultonhow 04-16-2012 10:15 AM
They're definitely getting within 0.5mm. Not sure if they're touching or not.
fahr_side 04-16-2012 10:30 AM
Get in touch with Bryan.
