Introducing the EFI Logics built and tuned "Subacabra"
I have been on this thread for a while and have one page dedicated to my car but, seeing as it has undergone a MAJOR revamping I felt it necessary to create a separate page for the new setup. It started out as a 2006 Legacy Spec B. What it is now is well beyond what I had originally envisioned for the car. Enough of the talk on to the pics and mods:
Engine: AMS 750R Rotated kit retrofitted w/ precision 6466 4" intake STI manifold swap EFI logics custom FMIC Invidia race ELH Top feed conversion Perrin top feed fuel rails Top feed TGV deletes ID 2000 injectors Tial Q BOV EFI logics custom fuel system including SX power regulator, Marren fuel dampener, radium engineering dual external Bosch 044 Surge tank and various fittings Aeromotive 340lph pusher fuel pump Accessport v2 protuned on 93 octane and E85 461whp 457wtq Full speed density tune on 93 and e85 (new numbers to follow) Efi logics custom side exit exhaust Blitz FATT Turbo timer AEM tru boost controller Mishimoto X-line radiator All exhaust components swaintech coated (header, up-pipe, turbine housing, downpipe and ewg dump tube) EFI Logics stage 4+ motor: JE Billet FSR pistons JE proseal head gaskets AEBS sleeved block with custom water jackets and o-ringed K-1 crankshaft balanced Manley H-plus rods w/ ARP 625+ hardware Killer b oil pick up Killer b windage tray Killer b oil pan ARP block bolts ARP 625+ head studs ACL main and rod race bearings Supertech +1mm intake and exhaust valves Supertech dual valve springs Supertech titanium retainers Cosworth S2 camshafts 278/274 Custom bowl blending mild porting Gates racing timing belt ATI harmonic damper Modded sti 11mm oil pump water pump new pulleys etc NGK iridium 1 step colder plugs VR1 race oil Wheels and Suspension: Tein Flex coilovers Tein edfc Perrin 25mm FT and RR swaybars Whiteline steering rack bushings Whiteline Ft and rr Front control arm bushings Whiteline Roll and bump steer kit Whiteline ft and rr diff bushing kit Whiteline rear control arm bushings Enkei NT03 18x9.5 +40mm H&R 5mm spacer in ft ARP hardened and extended studs Muteki R35 extended open ended lugs Drivetrain: 08 sti transmission 08 sti r180 rear end 08 spec b driveshaft 08 spec b rear axles ACT 6 puck extreme clutch kartboy short throw shifter Lathewerks stainless steel shift knob kartboy shifter bushings TIC pivot bushings Stoptech Front BBK DBA rear rotors Hawk HPS pad all around Driveshaft shop custom front axles Im sure there are things I missed but, that is the grand scheme of it. On to the photos: http://i79.photobucket.com/albums/j1...4/IMG_1069.jpg http://i79.photobucket.com/albums/j1...4/IMG_1083.jpg http://i79.photobucket.com/albums/j1...4/IMG_1076.jpg http://i79.photobucket.com/albums/j1...4/IMG_1075.jpg http://i79.photobucket.com/albums/j1...4/IMG_1074.jpg http://i79.photobucket.com/albums/j1...4/IMG_1044.jpg http://i79.photobucket.com/albums/j1...4/IMG_1042.jpg http://i79.photobucket.com/albums/j1...4/IMG_1051.jpg http://i79.photobucket.com/albums/j1...4/IMG_1053.jpg http://i79.photobucket.com/albums/j1...93213827_o.jpg http://i79.photobucket.com/albums/j1...91918045_o.jpg http://i79.photobucket.com/albums/j1...84047816_o.jpg http://i79.photobucket.com/albums/j1...95850046_o.jpg http://i79.photobucket.com/albums/j1...44/e85dyno.jpg much more to come. I will be updating this page as I attend events and shows...stay tuned |
I saw this on their FB page earlier, so badass
Over 200 hp increase over less than 1K rpm difference, did I read it right? Just curious 2.5GTBX, is it hard to control when the boost comes around 3.5K rpm?
Its not hard to control you just have to be paying attention. It can definitely catch you off guard if you are not expecting how hard its gonna hit.
A build after my own heart.
All I can say is wow... proper name "subacabra", must be a monster.
I love those wheels. Weren't the 18x9.5 et40's a limited run?
Beautiful car, incredible build! What a fantastic powerband - most impressed by the early torque!
BEAST! EFI was saying on their FB page that your next mods are engine internals?
Side exhaust is not for me but everything else is.
Stock internals? |
Wowsa those are some crazy numbers. Beautiful Spec-B.
now all you gotta do it try and sell it for $40,000
I love EFI logistics. They make the most badass cars ever.
My buddy saw this when he was getting tuned there last week. Sounds like a monster. Interesting shifter setup though. Whats the deal with the extended shifter?
| All times are GMT -6. The time now is 09:44 PM. |
