Subaru Legacy Forums
Subaru Legacy Forums (
-   Second Generation Legacy (1994 - 1998) (
-   -   sound familiar ? (
Lsnaple 04-12-2012 01:11 PM
sound familiar ?
97 legacy gt
2.2 block
Stock 2.5 heads
Just blew the headgasket. I haven't done this before but I have a retired machinist friend to help. Also going to take his time to go ahead and throw on a cheap turbo set up. What headgasket do I get? I would assume something for the 2.5 heads but want to make sure.
I'm searching but I would like to get this back together soon.
Lsnaple 04-12-2012 08:12 PM
Better yet, could I buy any complete gasket sets?
nick.cfrancis 04-12-2012 08:37 PM
Just buy the OEM gaskets from the stealership or a parts house. They are a revised design that won't fail again. After going through all the trouble to get the engine out, you don't want them to fail again.
SpecBamf41 04-12-2012 09:13 PM
your going to turbo a stock block?
Lsnaple 04-12-2012 09:59 PM
Sure, nothing big just like a td04.
gergeek 04-13-2012 12:40 PM
Oh boy here we go again another person wanting to turbo there N/A car...haha well through all the posts i have read turboing your car is going to decrease reliability and alomost everyone on this forum will say dont do it. Might as well do a motor swap to a wrx or sti motor, since they are built for turbos. .....You can try checking Fred Beans Parts, they seem to have stuff for pretty cheap. Good luck
LJ08GT 04-13-2012 03:18 PM
DONT turbo that motor!! Do a WRX SWAP!!!
ALWAYSDRIVEN98 04-13-2012 03:46 PM
Just curious, how many miles were on the car?
Lsnaple 04-14-2012 07:10 AM
Did I say anything about reliability? Did i say anything about oh can i turbo my car? Read again. 2.2 block and 2.5 heads, decreased compression over stock and is fine for a small turbo setup. Its been done plenty of times. Read over on rs2.5.
All I asked was what headgasket.
Kennyfvholla 04-14-2012 02:56 PM
You will need the head gasket to match the bore of the block and NOT the heads. I'd buy an OE or Felpro gasket set that is designed for your specific block.
Also, you would have no problem running a TD04 if you wanted. And, in order to run the turbo setup you will need a turbo crossmember, WRX/STi ECU and harness, and you will need to have the stock and WRX/STi harness' merged...
You'll need more than that, but those things are the most important things you'll need to take care of.
monkeyposeur 04-14-2012 10:03 PM
No, don't do it! Just get a JDM front clip from ebay. Di'int your read the turbo sticky? :p
Lsnaple 04-23-2012 06:37 PM
Ok guys I'm going to order my stuff tonight, and I don't want to forget anything. Head gaskets, valve cover gasket kit, cam seals, rear main seal, oil separator plate, intake manifold gaskets, and exhaust manifold gaskets. Any O-rings or other gaskets in the head I'm forgetting? Is there a gasket for the breathers on the valve covers?
I replaced the timing belt and components, water pump, thermostat, front main seal, and resealed the oil pump about 20k miles ago, so I'm going to wait a while to do that again.
I will be adding a turbo to my hybrid engine, maybe not right now, but I would like to go ahead and swap the crossmember while the engine is out. For you guys that went turbo, what crossmember did you use, and did you need anything else to make it work?
