Subaru Legacy Forums
-   Exterior/Aesthetic (http://legacygt.com/forums/forumdisplay.php?f=44)
-   -   Factory Fog Lamps replaced with Quad LED setup (http://legacygt.com/forums/showthread.php?t=182756)
allgrownup 03-28-2012 12:08 PM
Edit* Output pictures :)
Hey Guys, I am new to LGT but have been an enthusiast for some time (see new member thread)
I replaced my factory Fogs with Rigid Industries Dually LED's since the Dually draws about half the power of our turn signals I decide to splice a Deutsche connector onto the factory wiring. I didn't expect it to work for whatever reason but it does!
These things are BRIGHT! each light produces about 1300 lumens (rivaling the headlamps)
I chose flood pattern but in retrospect dual spot beams may have made more sense since these things will be utterly worthless in fog or inclimate weather. more of a driving light.
http://i123.photobucket.com/albums/o...LGTFronton.jpg
They fit fine with the stock fog shrouds, I had to drill a hole for each mount but it was relatively painless.
headlights factory low beam
http://i123.photobucket.com/albums/o...2/IMG_1332.jpg
Rigid Industries Dually's+ lo beam
http://i123.photobucket.com/albums/o...2/IMG_1333.jpg
FJuan 03-28-2012 01:11 PM
Interesting, do you have more of a close up pic?
allgrownup 03-28-2012 01:47 PM
http://i123.photobucket.com/albums/o...2/IMG_1320.jpg
http://i123.photobucket.com/albums/o...2/IMG_1321.jpg
I could have moved them farther forward to close that gap, and i might down the road.
http://i123.photobucket.com/albums/o...2/IMG_1322.jpg
Drift Motion 03-30-2012 02:44 PM
wait for output pics!
preferably comparison between stock and these
allgrownup 03-30-2012 03:09 PM
Originally Posted by thburkart (Post 3823921)
looks really good , thanks for posting. do you have the product link? the Rigid Industry site is pretty expansive.
i have two other questions-
- hows it wired? do you need to do anything special to get max brightness?
- im also curious if they'd dazzle oncoming traffic...
https://www.rigidindustries.com/category-s/131.htm
Yes they ruin oncoming traffic in the flood pattern, but the spots aimed low enough shouldn't.
I just used the entire stock system I used the equipped wiring harness on my RS and the output is identical,
I will try and get some good picks up tomorrow of the output
underground000 03-30-2012 04:15 PM
love rigid industries, def one of the best
allgrownup 03-30-2012 04:37 PM
Originally Posted by thburkart (Post 3823993)
cool, that'd be great. not urgent. i recently installed HIDs in my fogs and the output is *** outstanding*** but they keep failing. the bumper area takes a fair amount of impacts and vibration...... and is mounted low enough that it gets submerged from time to time.
$109 huh? i'll think about it!!!!!!!
can you give interested buyers a coupon code?
i bought mine from 4wheel parts they were having a 20% discount not sure if its still going on?
allgrownup 04-02-2012 11:15 AM
added output photos
roll_tide 01-24-2014 01:04 PM
To dredge this back up - how did you mount your lights? To the stock fog light "tabs" or did you make a bracket?
