Subaru Legacy Forums
-   Tuning (http://legacygt.com/forums/forumdisplay.php?f=84)
-   -   Tune now or after? (http://legacygt.com/forums/showthread.php?t=177035)
DW1324 01-01-2012 06:34 PM
Tune now or after?
Alright so I installed a erz/cnt catted dp and a gimmick motorsports cbe last weekend. And now the mod bug is gnawing me to death already. I want to replace to the factory bov.
I am currently using the Cobb stage 2 91 ots map.
Should I wait to get the tune after the bov or will installing one after a tune screw it up? And in regards to a tune, does anybody know of a trusted local Colorado tuner?? If not I'm willing to get a tune from infamous. Thanks guys much appreciated.
ShadowImg 01-01-2012 06:36 PM
Why do you want to replace the factory BPV?
DW1324 01-01-2012 06:48 PM
Well I would like to run a 50/50 bov. I know a protune will help my car a enormous amount. But I have a few problems with boost and I don't know if it is just the ots map or if it's my bov. In second gear only no matter how light I throttle it my boost will basically hiccup at close to 3000 rpms and at wot it does that at 3000 and about 5200. And even with the later rpm tapered boost when I shift my car will throw you forward bad. So I figured a 50/50 bov would help with the surge during shifting. Or a tune could fix it. Either way it would be nice to fix.
ShadowImg 01-01-2012 06:53 PM
It's not your BPV. The stock BPV is good well beyond the capabilities of the stock turbo, and is even fine for like a VF52 or BNR 16g. Your hiccup is probably from the tune itself, as it's pretty common (search for things related to hesitation). You'll find a lot of info on it.
The 50/50 will really not do anything good for you, as the car runs a nice full recirc setup.
http://legacygt.com/forums/showthrea...on-150687.html
ShadowImg 01-01-2012 07:01 PM
I should also mention, that big "pull" forward you're getting on shifts is likely from the suspension. They squat pretty hard in the rear under acceleration, so when you combine that with lifting off to shift, you get a pretty rough toss forward.
My understanding which may be 100% incorrect -- check with smarter people than I, is that the Legacy is set up a bit undersprung in the back to keep the ride a bit more comfortable, and the car is also intended to dive forward a bit in order to brake flatter (which is why the stock rake is a bit to the rear).
I had RCE Tarmac 1s on my 08 LGT for a couple years before getting my 09 spec.B -- it was so much softer in that respect I thought I was going to throw myself through the windshield the first time I did a real hard 2-3 shift.
cryo 01-01-2012 10:55 PM
You have quite a few local options I pmed you about, personally I think the stock bpv does a great job in most cases but that's a choice. Hope this helps.
Dave
PutnamCO 01-01-2012 11:26 PM
I am running 22psi on my stock BPV, and it's doing just fine.
I personally found it much easier to get a road tune than to do an e-tune. It's reassuring to know that if I have questions/problems, my tuner a short drive away, not thousands of miles away. Plus, having had a boost leak at the start of my last tune, it's nice to have someone to help fix those problems.
Cryo is very highly regarded by other Coloradans http://legacygt.com/forums/showthrea...ew-176203.html
I was tuned by Eric from Torqued Performance, and would highly recommend him as well.
Legend 01-02-2012 03:29 PM
+1 for stock BOV (also use it at 22.5psi)
+1 for a tune
+1 for Cryotune
Blake 01-02-2012 03:41 PM
+1 for a tune
+1 for Cryotune
This
PutnamCO 01-02-2012 05:32 PM
DW1324, you might consider upgrading your fuel pump and injectors to run a stage II E85 tune. Definitely best bang for your buck assuming E85 is available in your area. Where in Northern Colorado are you?
DW1324 01-02-2012 05:52 PM
I would love to run E85 but I have no idea of any station close to me. I live in Milliken. Its just a few miles south of Greeley.
KCwagon 01-07-2012 07:17 AM
E85 stations
Try this website:
http://e85vehicles.com/e85-stations.html
m sprank 01-07-2012 02:08 PM
No tuning needed for a BOV/BPV.
