Edmundu's Turbo Lives (AVO 450 tune)
Yes, I've been sitting on this turbo for about 2 and a half years. It was the last of Edmundu's huge part out thread so I got it. After we made the deal, he noticed that there was a crack in the turbine housing. He had a new and upgraded turbine housing shipped to me and I had that ported and coated. For the next year, I gathered parts for the upgrade. Here is my current setup.
-AEM CAI -Invidia catted dp -Grimmspeed coated EWG uppipe and dump tube -Tial 44mm EWG -Cobb IWG bracket (short) -Ported and coated stock manifolds -Grimmspeed ported crosspipe -Perrin mid and y pipe. -Prodrive mufflers (stock mufflers until spring) -RacerX fmic -GFB hybrid BOV -APS solid turbo inlet -JDM TGV deletes ported -DW 1100cc sidefeed injectors (true flow is over 1200) -AVO fuel pump -AVO 450 BB turbo ported and coated Tuning Necessities -V1 Accessport/ECUflash -Streettuner Advanced tuning software -Hybrid tuning setup ftw. ;) -Innovate LC1 WBO2 sensor. -Grimmspeed 3 port boost control solenoid and MBC (hybrid boost control) Drivetrain ACT heavy duty street disc clutch OEM wrx flywheel TSK3 snout sleeve Group N tranny mount Group N motor mounts Agency Power pitch stop mount Brakes -DBA slotted rotors -Hawk hps brake pads Suspension mods (coming soon) As the car sits, all parts above have been installed and the car is running, however not fully tuned. An updated base map needs to be flashed to the ecu before we go any further. I can tell you that at only 14psi, this thing pulls hard and its street manners are actually more mild than the stock vf40. Not nearly as punchy with smooth power delivery throughout. At least that's what the butt dyno tells me. ;) This thread will be updated as the car gets further tuned. I'll be posting logs as they come available as well as dyno graphs. This weekend, we will be working on completing a 93 octane winter tune. Springtime will add an E85 tune to the equation. Explicit Motorsports will be working on the tune assisted by member qikslvr. Qikslvr has helped me immensely get to this point so I'd like to thank him publicly for his efforts. Stay tuned (bad pun) |
Looking forward to some results! Good luck.
Subscribed
That should be fun. :)
subscribed
Would like to see the avo450 graph I run the 500
Miss Edmundu! He was a great source of information and help on here. Nice to know a part of him lives on...LoL! In for results.
Are you using avo's braided oil feed with the stock hardpipe off the head or a custom line?
I'm trying to adapt the infamous filter kit to my avo 380 and was wondering about oil restrictors and what others have done if anything |
subscribed for graph
http://img72.imageshack.us/img72/4052/datalog24.pdf
My numbers aren't really ideal but I'm going for broke in the spring |
Sweet!
wow...in for graph I bet its slow.
nice, I also have the Avo450
getting 15mpg on 93 w/ 850 injectors |
Couple updates. The turbo won't boost past spring pressure because there's a pig sqealing under the hood. Tomorrow, I'm hoping to get out there and track it down. The tuner says it sounds alot like a coupler for the piping. Hopefully it's just that. Maf scaling was erratic so that had to be completely rescaled. Some adjustments in the advanced timing brought the surge even more under control so it's even less noticeable. Boost is all over the place but not over 15psi because of the leak. :( We are remaining completely knock free, though.
We've switched over to open source tuning since windows 7 was causing erratic readings with the v1 streettuner software. We might go back to the streettuner eventually. Hopefully I'll have some logs to post pretty soon. No point in posting anything now. |
| All times are GMT -6. The time now is 02:16 AM. |
