Track Day with the Outback!
Had fun passing all the WRX's and STI's
The cars very heavily modified. It's got a IAG Built engine, and performance exhaust, suspension, and brakes etc. The car sill looks very stock looking, needless to say there were some surprised STI owners. http://dalenet.com/track/6.JPG http://dalenet.com/track/7.JPG http://dalenet.com/track/8.JPG http://dalenet.com/track/9.JPG |
Here's the complete mod's list if you're interested (please don't ask how much it cost, I really don't want to think about it). Most of the engine mods were after my turbo blew and screwed up my engine. So I decided when I got it fixed, to get it built right!
Power: (313WHP 300WTQ) Manley Platinum Forged Pistons 99.5mm Manley Steel H-Beam Rods ACL Race Bearing Set Blouch 380XT Turbo Perrin Turbo Inlet Hose Subaru SPT Intake with Heatshield AVO Top Mount Intercooler Forge Recirculating Blowoff Valve Grimmspeed 3-Port Boost Controller Deatschwerks 650cc Top-Feed Injectors Walbro 255lph Fuel Pump Invidia Catted Downpipe AVO Outback Cat Back Exaust Killer Bee Oil Pickup Air Pump Delete STI Engine Mounts Cobb Accessport V2 RalliTek Shifter Bushings Custom Pro Tune by Jorge Handling: RalliTek Front and Rear Sway Bars MOOG End Links BC BR Coil Overs 2004 STI BBS Wheels (Rota Torque Wheels for Track Days) Michelin Pilot Sport A/S Tires 225/55-17 (Hankook Ventus 245/45ZR-17 for Track Days) Brakes: Wilwood Superlite 4 Piston Calipers Front Slotted and Vented Rotors Stainless Steel Braided Brake Lines Hawk HPS Brake Pads (Hawk DTC-30 Front Pads for Track Days) ATE Super Blue Brake Fluid Interior: STI Gauge Kit STI Titanium Shifter Knob Billet Aluminum Pedal Set Redline Leather Shift/E-Brake Boots Painted Fake Wood to Match Car Exterior Rubber Floor Mats Exterior: 30% Front, 50% Rear Tinted Windows Utility: 2 Yakima High Roller Bike Racks 1 1/4 Hitch |
That's a buddy of mine in the Sti. It was his first ever HPDE event. :lol:
Awesome ! - great to see the OutBack taking it to the track. I often find many are surprised mine is as quick as it is...and it is barely more than stock.
5eat?
Here's a you tube clip if you're interested. |
Agree, just didn't see that in the specs.
I'm curious. But why the built motor?
Seems like an awful lot of engine and turbo to only make 313/300. Are you still breaking it in?
I would like to know more about your coilovers. (I am curious because I have the Megan Racing ones) Are they the Outback specific? What spring rates did you go with? Did you cut down or take off your rear bump stops? What setting did you use for the track? (clicks from full hard) What setting do you use on the street? (clicks from full hard) Lastly, what is your overall impression with them?
I have done a few track days in my Outback as well. I am about the same ride height as you. For track I use I went 5 or so clicks back from full hard all around if I remember correctly....it's been awhile. I usually go full soft for street use, 32 clicks back from full hard. But after my last auto x event, I left my set up the way it was and it's working OK on the street. (20 clicks back in front and only 12 clicks back in the rear) I find that the Megan's quick bump reaction is harsh, but the slow bump is nice. Overall if the road is smooth, like most race tracks and auto x events the coilovers work really well. When the roads have lots of small bumps though, the Megans struggle. |
video is sick.
go OB! That looks like a long straight... looks fun!
Oh yeah, are you running the stock top hat's up front or camber plates? How much negative camber are you running up front?
Since I am using the stock top hats, I had to use aftermarket camber bolts to get -1.5 degrees of camber. That seems to work out OK. Also, for alignment I am running just a hair of toe out up front. In the rear I wanted zero toe, but the lame ass tech said he could not get it to go to zero....so I have a hair of toe in. It bugs me because I know that is making my car push in turns, so I have to compensate with higher tire pressures in the rear and setting my coilovers stiffer in the rear. I did have an alignment done like 3 years ago where the tech was able to get zero toe in the rear, so I think the place I went to just did not know how to do it or something. Sorry for the 20 questions....I just don't see many other Outback owners tracking their car so I would like to get your input. |
Well I've got a fairly conservative tune and not running a fmic. The reason for the built motor is my last Turbo blew and pretty much wiped out the internals of my engine. |
| All times are GMT -6. The time now is 07:21 PM. |
