Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=115)
-   -   StopTech CyroStop & Powerslot Rotors, DBA Street & 4000 Series Rotors - ON SALE! (http://legacygt.com/forums/showthread.php?t=174059)
Emnotek 11-10-2011 02:04 PM
Let us know which rotors you need, front and/or rear, also include your zip code and we'll PM you the total shipped. You won't believe how low our prices are! All of the following rotors are in stock ready to ship!
Legacy GT Brake Pads & Rotors - CLICK HERE
StopTech Power Slot Rotors - click here
StopTech Power Slot Slotted rotors for the 05-09 Subaru LGT help reduce brake fade by releasing the boundary layer of gases that can build up between the pad and rotor surface and, consequently, inhibit performance. This is how Power Slot rotors make a big difference in your Subaru's braking performance: The exclusive StopTech Power Slot Vac-U-Slots machined into the rotor "wipe" brake pads clean, evacuate gases, and shed heat from your rotors to provide fade free braking stop after stop. StopTech Power Slot Plus rotors are manufactured to the highest tolerances of safety and quality. Slotting, unlike drilling, will not compromise the structural integrity of the rotor; drilling weakens a rotor and may cause stress points that can lead to cracking and failure. Drilled rotors also lose considerable surface area compared to slotted rotors, which means a smaller surface area for pad-to-rotor contact. StopTech Power Slot rotors are designed using the highest quality OEM replacement blanks. All machining is done in-house to StopTech Power Slot's application specific tolerances to ensure optimum quality control. The final touch is a military-spec cadmium plating that gives StopTech Power Slot rotors their bright silver finish and protects the rotor from debris. This eliminates 'rusty rotor syndrome' and enhances the look of custom wheels.
http://www.eurosportdesign.com/image...edium/3065.jpg
StopTech Cryo-Stop Rotors - click here
StopTech Cryo-Stop rotors for the 05-09 Subaru Legacy GT are a cryogenically treated, smooth faced, premium rotor casting. They use the same premium rotor castings as a StopTech Powerslot slotted rotor but do not have the slots machined into them to help reduce costs. This rotor option is meant to bridge the performance and price gap between basic replacement rotors and slotted performance rotors. StopTech Cryo-Stop rotors are not designed or intended to outperform their slotted counterparts. Cryo-Stops will outperform and outlast OEM replacements because they are a cryogenically treated, premium rotor casting. Cryogenic treatment is a one-time process in which the rotor is quickly cooled to -300F and then slowly brought back to ambient temperature. StopTech’s cryogenic treatment process permanently changes metallurgy, resulting in a denser, stronger rotor able to withstand substantial braking forces for long periods of time; up to three times as long as an untreated equivalent rotor. In addition to the cryogenic treatment Cryo-Stop rotors have an electrostatically applied finish designed to withstand 400 hours of saltwater exposure without rusting. This electrocoating (E-coating) finish, provides long lasting corrosion protection in the critical hat and cooling vane areas. So now your rotor will not only perform for a longer time, but they will look good longer too.
http://www.eurosportdesign.com/image...edium/3064.jpg
DBA Street Series Brake Rotors - click here
DBA's entry level, enhanced performance rotor, the Street Series, offers improved braking straight out of the box. DBA's Street Series slotted or drilled and slotted rotors improves pad bite and assists to reduce brake fade by evacuating gases created when pads contact the rotor. DBA Slotted Street Series are the perfect replacement rotor for the performance conscious street motorist.
http://www.eurosportdesign.com/image...edium/3062.jpg
DBA 4000 Series Brake Rotors - click here
The DBA 4000 Series rotor is a mid-level brake rotor that has more than enough performance for any street driven car and will work very well on a weekend track toy or autocrosser. DBA 4000 Series rotors feature Thermal Stability Profiling (TSP) for improved heat handling. TSP enhances the micro-structure of the rotor material providing greater thermal stability. Increasing the thermal stability allows your DBA rotors to take more heat, making them more stable under heavy, frequent braking. DBA rotors with TSP will experience improved brake pad and rotor life.
http://www.eurosportdesign.com/image...edium/3063.jpg
email: service@emnotek.com
Legacy GT Performance Products & Replacement Parts
Emnotek 11-11-2011 06:23 AM
Happy Friday... All rotors are in stock ready to ship before the weekend!
Emnotek 11-14-2011 12:25 PM
PM's with questions... In stock ready to ship!
Emnotek 11-15-2011 09:05 AM
Rotors and pads are in stock ready to ship!
Emnotek 11-28-2011 07:44 AM
PM with any questions!
Emnotek 12-08-2011 07:31 AM
bump
Emnotek 12-09-2011 07:26 AM
Happy Friday!
Emnotek 12-12-2011 01:49 PM
Happy Monday
Emnotek 12-13-2011 02:19 PM
bump!
Emnotek 12-14-2011 12:51 PM
Ready to ship.
Emnotek 12-15-2011 06:04 AM
PM with questions
Emnotek 12-19-2011 12:21 PM
Monday bump
Emnotek 12-23-2011 07:42 AM
Hope everyone has a great holiday weekend!
Emnotek 12-27-2011 07:55 AM
holiday bump!
Emnotek 12-30-2011 11:50 AM
Friday Bump!
