Subaru Legacy Forums
-   Infamous Performance and Tuning (http://legacygt.com/forums/forumdisplay.php?f=111)
-   -   Filtered Turbo Oil Supply Line Kit (w/ Instructions) (http://legacygt.com/forums/showthread.php?t=173373)
m sprank 10-30-2011 02:34 PM
2 Attachment(s)
The all new Filtered Turbo Oil Supply Lines
Taking orders now.
$175 delivered.
IP&T Filtered Turbo Oil Supply Line Kit
For those interested in a full ACVS replacement kit, I have those too. Specific for 05-06 and 07-09. $220 delivered.
IP&T Complete Filtered Turbo Oil Supply Line and ACVS Replacement Line Kit
http://legacygt.com/forums/attachmen...1&d=1319748838
Instructions attached.
m sprank 10-30-2011 02:35 PM
Pix of the prototype
Bracket used is not the production piece. It is something I made quickly to hold filter until bracket was ready.
Used an Xo2 FMIC (original WRX modified for LGT) to show how even with a poor fitting FMIC the kit is serviceable and usable.
http://legacygt.com/forums/attachmen...1&d=1319111897 http://legacygt.com/forums/attachmen...1&d=1319111897 http://legacygt.com/forums/attachmen...1&d=1319111897
FiftyTwoEighty 11-05-2011 10:15 AM
That fills the gap in the market quite nicely. How many washers did you need to use to get the line to clear at the banjo fitting at the turbo? I'm using two for my FP line as long as the connector is perfectly parallel to the turbo housing. It would be nice if someone came up with a banjo fitting that would clear the housing without stacking washers. Just my two cents and I don't need to tell you what that is worth.
Infamous1 11-05-2011 11:11 AM
It sounds like you need this kit, I will let Mike explain though :)
m sprank 11-05-2011 03:56 PM
Single washer at the turbo. No stacking. I had a long necked banjo fitting made so that the AN connection is not hitting the turbo housing. I tried to "correct" all the "issues" reported with the FP line. Then take it a few steps farther.
01rs25 11-05-2011 06:43 PM
Installed this today, everything went as planned with the exception of the oil filter bracket. I ended up having to use some electrical tape as the bracket wouldn't tighten enough to keep it from moving.
Overall a great product! I'm very happy with my purchase!
m sprank 11-06-2011 10:14 AM
What would not hold? We have installed several of these at the shop now. No issues. Brackets grab filter tight prior to "bottoming out". All "should" be identical as they were cut on a water jet.
If something is "off" I will replace it.
goneskiian 11-07-2011 02:24 PM
I got mine on Saturday. Thanks Mike! Looking forward to getting this and my 16G installed.
Should I be putting some kind of sealer on the threads between banjo's and lines and filter and lines? Yes, I'm very new to this.
Also, what would you use to clamp off the coolant lines. I'll be installing the turbo without changing oil and coolant.
Thanks!
m sprank 11-07-2011 08:14 PM
No sealant should be necessary.
I use clamps designed for cutting off flow thru hoses. You can get a cheap set (couple bucks) at harbor freight.
aj2four0 11-11-2011 02:16 PM
Any chance you have pics of the full avcs replacement? I'm beating my head against a wall figuring out exactly what I should do here.. a few pics would be worth a thousand words I'm hoping.
m sprank 11-11-2011 05:46 PM
Sorry. It mimics the OEM line, except I left slack up front to come into the ACVS straight (front of motor to back). I have two cars at the shop with the manifolds off and oil lines going on. I will snap a pic tomorrow and post up for everyone.
m sprank 11-12-2011 03:08 PM
Pix of the pre-air pump ACVS line routing. Sorry about rear of motor, crappy cell phone pix.
http://legacygt.com/forums/attachmen...1&d=1321135610 http://legacygt.com/forums/attachmen...1&d=1321135610 http://legacygt.com/forums/attachmen...1&d=1321135610
FiftyTwoEighty 11-12-2011 04:36 PM
Consider me to be corrected. :)
Does the filter element allow for adequate flow?
m sprank 11-13-2011 11:18 AM
Tested at 6 gallons per minute.
iNVAR 11-13-2011 06:00 PM
I want one of these for when I replace the turbo, but not ready to buy just yet... Can you just do me a favor and give me (and the forum) a heads up in this thread if you are going to stop producing them so I can grab it?
