Boost Target at higher altitudes?
So I live up in Salt Lake City, UT around 4600 ft. I am running Cobb Stage 1 93 Octane on my 2010 GT and I notice that in Live Data under "Boost Target" it's only 15.1psi. Now when I read the map notes it says the boost target is 17.0psi +/- 1psi. Does anyone know if the ECU adjusts the boost target based on barometric pressure? I can't see why it would, since, as far as I understand, the boost target is XX psi ABOVE ambient pressure.
correct. Boost pressure is gage pressure, not absolute pressure. If it were absolute pressure and you were running 15.1psi, your pressure would be 29.8psi since atmospheric pressure is 14.7
1 Attachment(s)
Cool, thank you for your help guys, I think I understand this a little better. Does anyone know the reason behind this? Maybe since the ambient air isn't as dense, the turbo would have to work harder and flow a higher CFM of air to achieve the same boost target above atmospheric pressure?
How much boost should you be getting with out mod or access port? Cant seem to find it and i did search forum
^^I am not exactly sure on this but I thought it was in the 12 range...
I must be shifting in wrong place when im accelerating it looks like around 10 is th hightest i ever go but i don stay in the log i did of it was very ip and down. Was weird.
Thank you Types4, this has had my mind in knots trying to figure it out. Kind of a bummer that not only does it drop 2psi atmospheric, but another 2psi from the turbo so you lose 4 pounds of absolute pressure. I can't imagine how these cars feel at sea level with 93 Octane.
| All times are GMT -6. The time now is 02:57 PM. |
