Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Blizzard’s 2010 Legacy GT Journal (http://legacygt.com/forums/showthread.php?t=171231)
Blizzard 09-29-2011 08:28 PM
http://i32.photobucket.com/albums/d5...ps07e7613f.jpg
Just wanted to have a thread dedicated to my car’s progress and thought maybe it would help others with their car modding decisions. I am going to try and keep track of everything from modding to oil analysis and everything in between.
Here is a list of mods / oem add on’s and other misc fixes. Everything listed in normal font is already on the car. Things listed in bold I've bought or I'm in possession of but still need put on the car.
Engine
Pro-Tuned by Mike @ Innovative Tuning in Buffalo via Cobb Accessport V3
HKS Intake Inlet - 70999-AF001
Racer X TMIC - Swaintech BBE Coated
Invidia Catted Downpipe
Magnaflow Catback - Modified (3 Inch Flat Flange)
Suspension
KW V3 Coilovers
Tanabe Front Strut Tower Brace - TTB156F
GT Spec Rear Strut Tower Brace - GTS-SUS-1425
Tanabe Undercar Brace - TUB156F
Whiteline 22mm Rear Sway Bar Kit - BSR49XZ
AVO Poly Rear Sway Bar Endlinks
AVO Front Lower Control Arm Caster Bushings
Powerflex PFR69-515 Rear Diff Bushings
Whiteline Front Contol Arm Bushings W0506
Whiteline KCA326 Rear Control Arm Camber Correction
Whiteline W0568 Rear Trailing Arm Bushings
Whiteline KCA313
Whiteline 24MM FSB
Brakes
Hawk HPS Pads
FastWRX Stainless Steel Brake Line Kit
Drivetrain
Southbend Stage 2 Daily Clutch / New OEM Flywheel
Removed - Clutch Masters FX100
Removed - Group N Transmission Mount – 5 Speed
Removed - TIC Transmission Crossmember Bushings
Exterior
Rally Armor Mud Flaps
Subimods Silver Powercoated Hella Supertones with Stainless Hardware
Subimods 08+ WRX Supertones Bracket
AZP Installs Supertone Harness
C&C Car Worx Front License Plate Mount
C&C Car Worx Rain Guard Deflectors
Bayson R S204 Front Lip
Lighting
Polarg Pure Yellow H11 Fog Light Bulbs
Polarg Hyper White Wedge LED Bulbs for License Plate
Roof Rack Setup
Thule Rack with Aero Bars
Thule Fairing
Summer – (2) Green Rockymounts Euro Pitchfork Bike Attachments
Winter – Rockymounts LiftOp 4 Ski Rack
Wheels
Summer:
18x8 Alt Sektor 1 Piece Forged Monoblocks (ET45)
949 Racing Lightweight Grey Aluminum Valvestems
245/45-18 Bridgestone RE-11
Winter:
17x7.5 Flat Black Drag DR-35’s (ET38)
Kumho KW19 215/55-17’s
Gorilla Neochrome Lugs
Interior
UltraGauge OBDII Scan Tool
Proto Tuning Accessport Holder
Prosport Dead Pedal
Blendmount Radar Detector Mount
Hardwired Escort C65
Husky Custom Fit Floor Mats
OEM Add On
Subaru STI Pedal Kit
Subaru Tweeter Kit
Subaru Trunk Nets
Subaru Foglight Kit
Subaru STI Short Shifter
Misc / Fixes
Stainless Steel Strut Tower Nuts - M8x1.25
Kartboy Stock Length Poly Exhaust Hangers (12mm)
Fumoto Drain Valve (F-108)
Intercooler to TB Couplers Removed
Rear Debadge
Reese Hidden Hitch
Exide Orbital ORB75DT-108 Dry Cell Battery
Other Maintenance and Fluids
Air Filter:
Wix 49012
Brake Fluid:
ATE Super Blue
Transmission:
OEM Factory Fill - 0 to 29K
Subaru Extra S -29K to 47K
Mag1 Syn GL-5 75w-90 - Current
Oil Analysis
Factory Fill - OEM Subaru Filter - 3,609 - No Analysis
Torco SR-1 5W-40 – OEM Subaru Filter - 7,610
Torco SR-1 5W-40 – Purolater PureOne Filter - 11,227
Castrol Syntec 0W-30 - Wix Filter - 14,916
Pennzoil Ultra 5W-30 - Wix Filter - 18,525
Quaker State Full Syn Euro 5W-40 – Purolater PureOne Filter - 21,745
Castrol Syntec 0W-30 - Purolater PureOne Filter - 25,317
Quaker State Full Syn Euro 5W-40 – Purolater PureOne Filter - 28,956
Quaker State Full Syn Euro 5W-40 - Purolater PureOne Filter - 32,729
Quaker State Full Syn Euro 5W-40 - Purolater PureOne Filter - 36,378
Quaker State Full Syn Euro 5W-40 - Bosch Distance Plus Filter - 40,251
Castrol Syntec 0W-30 - Purolater PureOne Filter - 44,267
Castrol Syntec 0W-30 - Mann ML1014 - 48,274
Castrol Syntec 0W-30 - Purolater PureOne Filter - 52,580
Pennzoil Ultra 5W-30 - Purolater PureOne Filter - 56,633
Fuchs Titan Super Synthetic 5W-40 - Purolater PureOne Filter - 60,383
Fuchs Titan Super Synthetic 5W-40 - Purolater PureOne Filter - 64,133
Castrol Syntec 0W-30 - Purolater PureOne Filter - 67,883
Quaker State Full Syn 5W-30 - Magneti Marelli Filter - 70,384
http://i32.photobucket.com/albums/d5.../NewestUOA.jpg
Dyno Graph
http://i32.photobucket.com/albums/d5...87958762_o.jpg
Blizzard 09-29-2011 08:29 PM
Some additional pictures:
http://i32.photobucket.com/albums/d5...rSnow2copy.jpg
http://i32.photobucket.com/albums/d5...A3B99E28-1.jpg
Blizzard 09-29-2011 08:30 PM
http://i32.photobucket.com/albums/d5...79/photo15.jpg
Reserved 3
acumenhokie 09-29-2011 08:38 PM
Have your cargo nets popped out yet? Mine did within the first week. I've already modified the hook piece (part that connects to the rear bumper) with the extra hooks from when I installed the nets in my wife's Forester. The screw has a nut backing so you know it's not going to pull out.
Magic Marker 09-29-2011 08:52 PM
My trunk cargo nets haven't popped off and I have stuff in them and sandwiched behind them and the trunk wall.
Blizzard 09-29-2011 08:56 PM
Nope mine have been fine.
I usually keep a half quart of oil behind one just in case. In the past I've also put a heavy box of 150 shotgun shells behind it before when I've gone target shooting and it never popped off.
ChasWG 09-30-2011 12:32 AM
Well this is good to hear about these cargo nets. I just order a set from Subarupartsonline.com and they should get here soon. I plan on using them a lot!
Nice write up on your car! A great way to keep track of stuff that you've done and/or want to do. I did one for my car in the photo forum. Basically a photo essay of my car's mods starting with an unmolested image a couple days after I got it up to a recent image with the new Swift Sport springs installed.
CL21376 09-30-2011 04:59 AM
Nice write up of your car so far.
Interested in any feedback you have on these mods:
Also, FYI, my cargo nets haven't came out and I have them stuffed pretty full, including a quart of oil :lol:
schnacko23 09-30-2011 06:33 AM
Blizzard, our cars are at least going to look very similar pretty soon. I too have the Rally Armor mud flaps, on order is a accessport, RSB, and a fewother goodies..going to have a local guy fab up a custom exhaust with MR cans. My roof rack is on order as well. Need to carry my snowboard in the winter and kayaks and bikes in the summer. Were you the one with a hitch as well? Before next spring I have to order and install that as well
Blizzard 09-30-2011 07:07 AM
Oh cool. Yup I have the Reese Hidden Hitch that isn't well... hidden :lol:
I use it to tow my 4.5ft x 10 ft aluminum trailer for my snowmobile.
Not a very good picture at all but you get the idea.
http://i32.photobucket.com/albums/d5...egacyhitch.jpg
VejaD 09-30-2011 11:46 AM
Do you scrape at all with the hitch? I was thinking about getting it, but from what I read on here, most people scrape going in/out of their driveways.
Blizzard 09-30-2011 11:58 AM
Nope I've never scraped with it. The car is also at stock ride height right now though.
Fibonacci 10-01-2011 05:26 PM
Are there any previous threads on that HKS intake inlet?
...scratching my head trying to figure out what you did with it.
Blizzard 10-01-2011 07:10 PM
It replaces the airbox silencer. Looks like this.
