Subaru Legacy Forums
-   Member Classifieds - ARCHIVE (http://legacygt.com/forums/forumdisplay.php?f=86)
-   -   Whiteline Rear camber adjusters. - CLOSED (http://legacygt.com/forums/showthread.php?t=169216)
Mr. Cakes 08-31-2011 05:56 PM
KCA399 is a rear camber adjustment kit designed to provide a camber adjustment range of +/-1.0 degree from base settings. Each kit replaces rear upper control arm outer bushes with specially engineered low compliance polyurethane bushes & on-car adjustable insert mechanism. For ease of operation & to achieve best results - camber adjustment can be performed live on car during wheel alignment procedure.
Brand new in the bag $40
mk6933 08-31-2011 07:26 PM
Is that all the need to adjust my rear camber? If so, I will take it.
SpecBGuy 08-31-2011 07:31 PM
it only can go -1.0 on camber? dont people usually want atleast -2.0? if you can adjust more then -1.0 i got second dibs
dmanaenk 08-31-2011 08:03 PM
^On RCEs I had like -1 of camber in the back with stock hardware, so this should yield you -2.0.
You'd probably need a press to install this. Will see what this goes for, since I think I got one laying around somewhere too.
thisisthenewsic 08-31-2011 10:42 PM
you will get negative camber from lowering the car. so just like said above. it will help you pull out another degree of negative =]
Mr. Cakes 09-01-2011 02:10 AM
they are a must if you are running a low car or want to adjust camber in the rear, you will need a press to install them but they are pretty easy, i have installed a few sets and they really do help out.
thestratomaster 09-01-2011 04:27 PM
wish these were for sale about 2 weeks ago :(
mk6933 09-01-2011 09:57 PM
Can you help me install them too. I will pay you. I'm local :)
CentralScrutinizer 11-01-2011 12:50 PM
Ygpm
Flubyux2 08-12-2012 10:11 PM
Still available?
