Subaru Legacy Forums
-   Walkthroughs :: Performance Modifications (http://legacygt.com/forums/forumdisplay.php?f=37)
-   -   How to: Installing your Fast Motorsports FMIC (http://legacygt.com/forums/showthread.php?t=166614)
jblackwell1 07-23-2011 04:35 PM
Contact Joshua at Import Image Racing to order yours today. Hes been great helping me so far and ships really fast.
Continue my most up to date build log here: http://mwsubies.com/index.php?topic=17.0
I would set aside about 4-6 hours for the full job, sadly i dont have an engine right now so i couldnt finish today but will finish the complete how to once i run the piping. :lol:
Tools:
Full Set of metric sockets and ratchet
Cutoff wheel or sawzall
flat head screw driver
Drill
Angle grinder
http://i36.photobucket.com/albums/e2...0Build/052.jpg
Step One:
Remove grill -2 bolts and 2 clips
Step Two:
Get the bumper off, there are about 10-12 clips holding the bumper on and a couple bolts. There are 3 or 4 on each side of the car holding the bumper to the wheel well cladding and one on each side holding it to the actual fender. As well as a few on the bottom across the front including a bolt or two.
http://i36.photobucket.com/albums/e2...0Build/009.jpg
Step Three:
Once you have removed the front bumper and grill, you will need to remove the actual bumper structure and foam from the car. There are 4 bolts on each side of the bumper and you also need to remove 4 10mm bolts on each side on the bottom of the headlights to be able to lift the bumper structure up and out of the way.
http://i36.photobucket.com/albums/e2...0Build/011.jpg
http://i36.photobucket.com/albums/e2...0Build/019.jpghttp://i36.photobucket.com/albums/e2...uild/021-1.jpg
Step Four:
Reattach the 10mm bolts that still have mounting points that you removed from the headlight mounts. Now get out your FMIC mount and finger tighten it to your car, we will tighten this down later. Two bolts on the bottom one on the top.
http://i36.photobucket.com/albums/e2...0Build/063.jpg
Step Five:
Get out your cut off wheel and remove the 2 tabs that stick out across the front lip of the core support. The one in the center needs to be cut off almost directly in the middle of the bolt hole and the one of the left just needs to be trimmed flush with the rest of the lip.
CENTER CUT:
http://i36.photobucket.com/albums/e2...uild/034-1.jpg
LEFT SIDE CUT
http://i36.photobucket.com/albums/e2...uild/027-1.jpg
Step Six:
Get out your intercooler and begin to line it up to bolt on the new FMIC mount that is supplied. Unless i was just unlucky the bolt holes are off about 1/4 of an inch side to side and front to back. This is where you will use your drill and angle grinder to enlarge the holes for proper mounting. This took me about 4 tries to get it perfect. I suggest getting larger washers then are supplied with the bolts because of the larger mounting holes. (I also put some lock washers on)
http://i36.photobucket.com/albums/e2...uild/032-1.jpg
Step Seven:
Once you have your mounting holes lined up go ahead and mount the intercooler loosely, we will again tighten this later. Now laydown under the car and check that the bottom mounts line up, mine did perfectly and insert the two bolts and washers supplied with the kit and tighten these down. Make sure that the intercooler has clearance from the lip of the core support and is not touching.
http://i36.photobucket.com/albums/e2...0Build/050.jpg
http://i36.photobucket.com/albums/e2...uild/037-1.jpg
Step Eight:
Once we have the bottom mounts tightened down go ahead and tighten the top mounts. Also go ahead and tighten the mount to the car, again making sure everything is level and there is no rubbing. You have successfully mounted the front mount and are ready to begin running your piping.
http://i36.photobucket.com/albums/e2...0Build/041.jpg
This is where i will have to stop for now until i get my black piping and have an engine to run the piping to, i will finish this how to as soon as i am completely done.
jblackwell1 07-23-2011 04:36 PM
Step Nine:
NOTE: DO NOT FULLY TIGHTEN ANY CLAMPS UNTIL PIPING IS COMPLETELY RUN
Grab the two Uish shaped pipes and they are going to be the first pipes on either side of your intercooler. A quick test fit will clearly show which goes where on the first pipe for each side. Make sure to place clamps very loosely on couplers before connecting everything. Also to make it easier on yourself make sure that the coupler is pushed as far as it can go onto the I-C and the pipes are pushed in as well. If not you will be too wide and hit the fog light casings.
Clamps have a 10mm nut and will need a wrench or deep socket to tighten.
http://i36.photobucket.com/albums/e2...uild/007-4.jpg
http://i36.photobucket.com/albums/e2...uild/008-3.jpg
Step Ten:
From here the actual pipes that are used may differ from my set up because of turbo, intake manifold or other modifications.
Be sure you have all couplers and clamps you need and begin to piece together the rest of your intercooler piping. Upon having your completed routing of pipe begin at the intercooler and tighten all clamps down using a 10mm deep socket or wrench. Some connections may require a flat head screw driver. Be sure to properly tighten all clamps to avoid leaks.
http://i36.photobucket.com/albums/e2...uild/012-5.jpg
http://i36.photobucket.com/albums/e2...uild/020-5.jpg
http://i36.photobucket.com/albums/e2...uild/025-4.jpg
Step Eleven:
Attach your stock or aftermarket BPV/BOV.
Make sure you have the appropriate gasket, which should be replaced in most cases. Reattach, I used my own hardware here, and make sure all hoses are reconnected and tightened down to prevent leaks.
Insert picture here
Step Twelve:
Now that the engine bay and full FMIC and piping is complete and tightened we need to tackle trimming the front bumper to fit. You will be removing more than you think needs to be removed. From the center of the center brace of the bumper you will cut 14 inches in each direction. And will end up with ~3 inches of depth in the bumper after trimming surrounding the I/C and tapering down from the center. I recommend you use painters tape to test fit where the FMIC lines up on your particular application. Here are some pictures of the trimmed bumper and final fitment.
http://i36.photobucket.com/albums/e2...uild/008-4.jpg
http://i36.photobucket.com/albums/e2...uild/009-4.jpg
http://i36.photobucket.com/albums/e2...uild/005-5.jpg
http://i36.photobucket.com/albums/e2...uild/014-6.jpg
http://i36.photobucket.com/albums/e2...uild/015-6.jpg
Step Thirteen:
Reattach bumper using any and all screws, clips, and bolts required. Some places will no longer be able to be used so be sure to use as many mounting points as possible. Double check all of your work, if you want to make a leak tester for the piping as seen here.
http://i36.photobucket.com/albums/e2...ure_tester.jpg
Any questions or issues please let me know so i can modify or clarify.
lieutenantcolumbo 07-23-2011 07:28 PM
Well done. Nice post JB. Import Image Racing should give you a rebate for your contribution.
I like the idea of an FMIC but just can't get past the bumper beam issues. I imagine I'll eventually end up w/ either an ITSME or AVO (minimal trimming) but I wanna see how much heat soak a little water/meth can offset before I commit.
jblackwell1 07-23-2011 07:31 PM
As I mentioned in my build thread, id love if i could have kept it but its not a huge factor not keeping it. Once i get the car back on the road for a while ill probably fab up a different mount that gives more protection, but for now this will do.
IMPORTIMAGE 07-24-2011 08:02 AM
great write up, columbo your right! blackwell, check your paypal. great pics/info. thankfully we'll have that motor issue taken care of with your new built Vigilant motor :)
thanks for the support and we wish you the best on your Fast legacy journey
sumfoo1 07-25-2011 08:42 AM
HMMM still on the fence with intercoolers etc. lol...
kabuby12345 08-05-2011 09:05 AM
This has got to be finished by now. WE WANT MORE PICTURES!!!!
jblackwell1 08-06-2011 01:19 PM
ended up trading out my intercooling piping so once i get it back ill have a finished write up.
IMPORTIMAGE 08-09-2011 08:05 AM
Heck yes...black it is ;)
sumfoo1 12-23-2011 08:00 AM
need more info on legacy fitment!!1
jblackwell1 12-30-2011 07:28 AM
it should be done completely in 2 weeks. parts and school have gotten in the way but everything should be good to go by the end of this week and final assembly of motor and FMIC will take place.
Ohitsspencer 01-04-2012 10:18 AM
Looking forward to the rest of this install. Planning on picking one up soon.
vtbimmer 01-11-2012 11:36 AM
Not sure what hardware came with your kit but I caution if the intercooler mounting bolts are M8x1.25x40mm they are TOO LONG!! They will bottom out and strip the helicoils in the intercooler. Buy 4 M8x1.25x30mm. These will work! The only issue I have run into so far but would have been nice to know prior to trying to tighten. This will save some headaches.
mumblinaviator 01-11-2012 12:10 PM
^Thanks for that. I'm planning the install for early spring, so i may have to grab these before hand.
jblackwell1 01-11-2012 01:18 PM
mine were fine. I also double washered them so that might be why.
