Subaru Legacy Forums
-   Intake and Exhaust (http://legacygt.com/forums/forumdisplay.php?f=73)
-   -   Exhaust Install (http://legacygt.com/forums/showthread.php?t=161262)
xero287 05-02-2011 02:25 PM
Exhaust Install
So, my Invidia DP is currently connected with one spring bolt to the stock midpipe, can't seem to get the other one in. I have the 3-2.5" adapter with the donut in and I thought it was necessary to have the spring bolts for the donut. My question is: Can I just use the bolt and nut from the spring bolt w/o the spring, and if not where can I buy a longer spring bolt. I tried searching, but it seems like most manufacturers either don't sell them alone or are discontinued.
TIA
cabin 05-02-2011 05:22 PM
Put the spring in a vise and put 2 zip-ties through the coils. As you compress the spring, snug the zip-ties down. This should get you enough slack to get the nut started. Once you get the nut started a couple turns, cut the zip-ties and pull them out.
This method worked great for me the other day.
Drift Motion 05-02-2011 05:30 PM
that's some awesome info right there!
xero287 05-02-2011 05:31 PM
Oh wow, that sounds like a great idea! Thanks.
mwiener2 05-02-2011 05:42 PM
The spring bolt is meant to replaced with a standard bolt when you use that adapter. Snug it all down good and tight, but don't destroy the donut gasket in the process.
I like the zip-tie thing. I gonna try that.
xero287 05-02-2011 05:46 PM
Isn't it supposed to flex somewhat though?
mwiener2 05-02-2011 05:51 PM
The catback that goes with that 3" downpipe doesn't flex at that joint. If you let flex, it will leak.
xero287 05-02-2011 05:56 PM
Hmmm, so...if I eventually get a 3 inch midpipe that'll just be a direct install with no donut or adapter correct? And I'd just use bolts instead of the spring bolts right?
xero287 05-02-2011 05:58 PM
So, spring bolts arent necessary at all then right? can I just use the same bolts without the spring?
mwiener2 05-02-2011 06:04 PM
Your aftermarket downpipe replaces the factory down and mid pipe. Unless you bought a 2-piece aftermarket downpipe, there are a few out there. You would need to get a matching catback. Just use regular bolts with a flat gasket.
You'll probably run out of threads before it became tight if you use the spring bolts without the springs.
xero287 05-02-2011 06:07 PM
Hmm, thanks for the very helpful info. I'll just go to home depot and pick up some bolts tomorrow. I can cancel my appt with subaru to put in the spring bolt then lol. I got one in but the other one refuses.
mwiener2 05-02-2011 06:10 PM
Just for the sake of posting.... there are aftermakret springbolt kits. Vibrant makes some.
xero287 05-02-2011 06:14 PM
https://www.dwperformance.com/Pages/...ileId=VIB10112
Isnt the diameter too small??
mwiener2 05-02-2011 06:19 PM
i never measured.. they also make a few different kits
xero287 05-02-2011 08:16 PM
Just cut the spring in half I'll try that tomorrow.
