Subaru Legacy Forums
-   Cosmetic/Electronic (http://legacygt.com/forums/forumdisplay.php?f=118)
-   -   FS: "Switchback" LED Turn Signal Bulbs (video demo, sale!) (http://legacygt.com/forums/showthread.php?t=159272)
Diode Dynamics 04-05-2011 03:01 PM
Subaru Legacy GT LED Turn Signal Bulbs! Same-Day Shipping! Switchback Options
From the factory, turn signal bulbs are powered by standard incandescent lights that light up amber in color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off, increased brightness, and true, vibrant color. By replacing the bulbs in your Legacy GT, you can achieve this modern look!
The installation is 100% plug-and-play, just replace your factory bulb. The bulb may blink faster since it uses less power, and your vehicle thinks the bulb is out- to fix this, please see "hyperblinking" section below.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
Brightness
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Resistor Option: Some vehicles may have fast-blinking issues when LED bulbs are installed as turn signal replacements. We offer resistors to remedy this issue for a nominal charge. Alternatively, we offer plug-and-play flasher modules to regulate the flashing speed.
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Subaru Legacy Front Turn Signal LED Options
Subaru Rear Turn Signal LED Options
Any questions, feel free to ask via email (contact@diodedynamics.com), Post or shoot us a PM!
Thanks,
Nick C.
Diode Dynamics
JaeGT 04-05-2011 06:46 PM
so this should be compatible with 08 turn signal bulbs which are 3457? and your flasher module would be a direct swap for the 08 one? i'm itching to pull the trigger on these. this is a great deal
blaze741 04-05-2011 07:50 PM
too bad my lights aren't cleared, otherwise I'd jump on this. But with my anber reflector still in there, I wonder how it would look. hmmm.
Diode Dynamics 04-05-2011 10:06 PM
This is compatible, but at this time, we don't have the flasher that is compatible. Please use the resistor kit. Thanks!
blongo804 04-05-2011 10:49 PM
These are pretty sweet and definitely considerable once I get some other things done that need to be. Good luck with the sales! We'll be in touch one day. :)
JaeGT 04-06-2011 02:57 AM
sweet. just made the order on your website. can't wait to install these! :cool:
Originally Posted by Paul J. McCain (Post 3336763)
Correct on both counts! Thanks!
Diode Dynamics 04-06-2011 03:48 PM
Shipped out today :)
JaeGT 04-06-2011 04:17 PM
Got shipping info this morning! that's fast :)
oops. sorry, meant shipping label xD. will take pics and vids once installed
blaze741 04-06-2011 05:30 PM
pics pics!
metsfan999 04-06-2011 10:44 PM
whats the difference between using the flasher module and load resistor kit? why is the resistor kit more expensive than the flasher module? once i get an answer, im pulling the trigger on these bad boys!
Diode Dynamics 04-06-2011 10:49 PM
You will need the resistor kit for the Legacy, as the flasher doesn't fit this vehicle. As for price, the resistors are simply a more expensive part. Thanks!
JaeGT 04-06-2011 10:52 PM
I asked about the flasher module for my 08 LGT and you said they were a direct swap... now you're saying the opposite? :confused: i already ordered the bulbs with your flasher module... what do i do now? -_-;;
Diode Dynamics 04-06-2011 10:57 PM
I'm sorry, I misspoke, please PM or email me your name and I'll send out a resistor kit immediately. We will have the correct flashers shortly but right now do not have the type needed for direct swap in the Legacy.
Diode Dynamics 04-07-2011 12:52 PM
OK, we have the correct flashers listed, they will be available on Wednesday. Thanks!
RIPjeep2002 04-07-2011 01:22 PM
Just ordered the bulbs and resistors for my new headlights! Can't wait
Edit......Paul got my confirmation email and it says flasher module......what I need is just the in line resistor kit, not the flasher module replacement. The order is from unc148@msn.com
