Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   My 2010 Legacy GT Accessory/Mod Tracker (http://legacygt.com/forums/showthread.php?t=158725)
acumenhokie 03-28-2011 07:47 PM
Getting stuff done every week is starting to get hard to track. I need my own thread to report on mods and accessories and keep them all straight.
Car
2010 Subaru Legacy 2.5 GT Limited
Performance
F.A.S.T. Custom Intake Box
F.A.S.T. Custom Exhaust Manifold
TGV Delete
3mm Phelonic Spacers
Turbosmart 40mm EWG
Swaintech White Lightning Ceramic Coated Exhaust
Racer X Charge Pipe
Racer X TMIC with Thermal Coating http://legacygt.com/forums/showpost....&postcount=289
Cobb AP v3
AVO Turbo back Exhaust (post #149)
DW300 Fuel Pump
Injector Dynamics 1000cc Injectors
Synapse BOV
NGK Sparkplugs (1 Step Colder)
Samco Intake and Turbo Inlet with shortened routing
Infamous Performance Filtered Turbo Oil Supply Line Kit
Infamous Performance LWCP
GrimmSpeed EBCS
ARP Head Studs
BNR 20G TD05 http://legacygt.com/forums/showpost....&postcount=289
Crawford AOS http://legacygt.com/forums/showpost....26&postcount=8
Silicon Vacuum Lines
KS Tech 73mm Short Ram Intake Pipe with AEM filter http://legacygt.com/forums/showpost....&postcount=289
Zetronix Flex Fuel Sensor & e85 Content Analyizer
OMNI 4-bar MAP Sensor
OLD Tune @ IAG (300whp/327wtq) http://legacygt.com/forums/showpost....&postcount=303
OLD Tune @ Evans Tuning (340whp/350wtq) http://legacygt.com/forums/showpost....&postcount=318
Current Pump Tune @ Agile (340whp/345wtq) http://legacygt.com/forums/showpost....&postcount=325
Current e85 Tune @ Agile (385whp/385wtq)
Suspension
BC Coilovers (all pics)
Pulled/Rolled Fenders (all pics)
Whiteline Rear Differential Bushings (link)
TiC Cross Member Bushings (link)
Whiteline Adjustable 24mm Front Sway bar
Whiteline Adjustable 20mm Rear Sway bar
25mm H&R Rear Spacers (post #85)
15mm H&R Front Spacers (post #117)
Tanabe Strut Bar
Exterior
Invasion Fabworks custom Alt/Pulley Shroud
Mishimoto Battery Tie Down
Mishimoto Oil Cap
V-Limited Front Lip http://legacygt.com/forums/showpost....&postcount=296
JDM Spoiler (post #3)
Hella Horn Kit in Black + Bracket and Wiring Harness (post #37)
Painted Headlamps (post #172)
Voltz HID Headlight Conversion (post #172)
Moon Roof Air Deflector
Fog Light Kit
Puddle Lights (post #21)
Security Shock Sensor
Gorilla Wheel Locks
Subaru Splash Guards
Gladman Rear Diffuser
Kartboy 12mm Exhaust Hangers
25% Tint (post #172)
Interior
Faux Carbon Fiber wrap on wood trim
DAMD JDM Flat Bottom Steering Wheel
De-badged / Shaved Trunk (post #172)
Prosport Aluminum Dead Pedal (post #50)
Proto AP Holder (post #270)
WC Lathe Works Shift Knob (post #276)
Redline Shift Boot - Napa Perforated Leather with Silver stitching (post #282)
Cubby Hole GPS/Phone Mount
Auto Dimming Mirror with Compass/Homelink
STi Pedal Set (post #50)
Interior Illumination Kit
All-weather Mats
Media Hub
Trunk Tray (post #21)
Cargo Net (post #21)
LED lighting (interior, trunk, license plate, doors)
Custom Vent Gauge Pod (post #191)
Defi Blue Racer 52mm Boost Gauge (post #202)
Defi Blue Racer 52mm Oil Pressure Gauge http://legacygt.com/forums/showpost....&postcount=289
Zetronix e85 Hacker Gauge
LC-1 Blue 52mm Wideband Gauge http://legacygt.com/forums/showpost....&postcount=289
Transmission
RalliSpec REM Treated Gearset
Moore Blast Plates
STi Short Throw Shifter
Group N Trans Mount
ACT SB5-HDSS Clutch (toasted)
ACT SB5-HDG6 Clutch
ACT Streetlite Flywheel
STi Shift Bearing
Clutch Damper Delete
Braking
Hawk Pads
Brembo STi calipers with Custom LGT logo
Centric Slotted Rotors
Mach V Braided Brake Lines (post #178)
Winter Setup
Hankook I*cept Evo 225/45-18
OEM Rims
Summer Setup (post #172)
Hankook Ventus V12 245/40-19
TSW Nurburgring in Matte Gunmetal - 19x8 +45mm
Maintenance
5W40 Motul Synthetic Fluid, every 3,750 miles (last change 44,500, next change: 48,250 miles), (post #204)
Purolator PureOne Filter
Cabin Air Filter changed at 15.5k, again at 29.5k, and again at 41k
Extra S Transmission at 44,500
Differential Fluid changed at 25k
ATE Brake Fluid (DOT4) at 26k
LegacyGT420 03-29-2011 01:37 PM
Pic of JDM Spoiler, please. Where did you get it?
Thanks
acumenhokie 03-29-2011 02:23 PM
Thanks
http://i108.photobucket.com/albums/n.../_MG_1027a.jpg
Purchased from R-rev
PeeterTG 03-29-2011 02:29 PM
Is that "JDM Spoiler" a piece that directly fits the 2010 LGT?
acumenhokie 03-29-2011 02:40 PM
It was installed by the previous owner but my understanding is that it was a direct fit. It does require drilling 5 holes in the trunk lid (4 for screws/nuts and 1 for wires). Will try to remember and take a picture of the trunk lid tonight.
Slider 03-29-2011 03:07 PM
I really like the spoiler, but I already have the OEM US version and don't want extra holes :(
acumenhokie 03-29-2011 05:10 PM
Realized that I totally forgot the Hella Horn Kit I ordered last week. See I knew I needed this thread to keep me straight.
minuccims 03-29-2011 06:49 PM
Aren't your headlights blackened?
Originally Posted by acumenhokie (Post 3327057)
Getting stuff done every week is starting to get hard to track. I need my own thread to report on mods and accessories and keep them all straight. Feel free to chime in with suggestions or ask questions but I've mostly created this thread to keep myself straight!
Car:
Current Accessories:
All-weather Mats
Sun Roof Air Deflector
Fog Light Kit
Media Hub
Trunk Tray
Cargo Net (on order)
Puddle Lights (on order)
Wheel Locks
Current Mods:
Cobb AP
BC Coilovers
JDM Spoiler
HID Headlights
Hella Horn Kit in Black (on order)
Maintenance:
5W30 Motul Synthetic Fluid, OEM Filter every 3,250 miles
acumenhokie 03-29-2011 07:02 PM
Originally Posted by minuccims (Post 3328303)
Aren't you headlights blackened?
doh! Forgot I have painted headlights and an HID conversion. :lol:
minuccims 03-29-2011 07:46 PM
Hey, we pay attention!
ChasWG 03-29-2011 08:37 PM
Great Idea for a thread. Maybe there could be a link members could have to a page that tells all this without each of us having to create our own thread. I've seen it on other forum sites like http://photography-on-the.net and other car sites I've been a part of in the past. It does save space and give other members a chance to see what you have without a having to rifle through a bunch of banter. But the banter around this place is part of the fun! :) I'll be watching your progress acumenhokie!
VejaD 03-29-2011 09:08 PM
:needpics:
I really want to see what some of these look like! Ive been thinking about doing some of these.
coppertone 03-29-2011 10:42 PM
Hella horn kit in black.
Nice mods but where did you find the Hella horns in black from please ?
minuccims 03-30-2011 05:23 AM
Yes, where in black? After getting hit, I'm in for these
coppertone 03-30-2011 07:28 AM
PLEASE PLEASE PLEASE, tell us where you can get these stock colored black.:eek:
