Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   Steering issue......... (http://legacygt.com/forums/showthread.php?t=157330)
98sc00byGT 03-08-2011 09:32 PM
When i go to turn it is easy then it gets to a point on the wheel where it gets hard...i am not leaking any power steering fluid and it just doesnt feel right...it is so hard... i do not know where to start
Baddog 03-08-2011 09:40 PM
Try bleeding the Power steering pump
98sc00byGT 03-08-2011 09:41 PM
how do you go about that
worknlikeadog 03-08-2011 11:27 PM
you stab it in the heart
98sc00byGT 03-09-2011 06:01 AM
really.......
98sc00byGT 03-09-2011 01:05 PM
still have no idea what to do
Trbulnt 03-09-2011 06:43 PM
Follow me.....http://lmgtfy.com/?q=How+to+bleed+a+power+steering+pump
98sc00byGT 03-09-2011 08:02 PM
ok i did that now still does it...
broknindarkagain 03-09-2011 08:53 PM
Originally Posted by 98sc00bygt (Post 3303600)
...it is so hard...
.......am i the only one that saw that? lol
your pump may be dying. Are you running stock size tires? If you're running oversize tires / rims, your wheels may be scrubbing and hitting something
98sc00byGT 03-09-2011 09:56 PM
lol yes you are the only ones and yes stock tires but how does a pump die if it has full fluid and has never been low, could it be the rack?
broknindarkagain 03-09-2011 10:00 PM
it could be the gears in your rack binding up, but its likely the pump. They wear out over time, just like any other part on the car. I would start with the pump since its the cheaper and easier thing to do. you can lift up your car and shake down the front end to see if anything has any play. if the gears in the rack are worn out, then you will have lateral movement on the tires when you shake them.
does the pump make any noise when it gets "really hard" lmao
98sc00byGT 03-09-2011 10:14 PM
nope no noises when it gets hard
broknindarkagain 03-09-2011 10:18 PM
best thing for you to do is take it to a Sears auto and ask for a steering and suspension eval. its free. This problem is impossible to diagnose over the internet.
98sc00byGT 03-09-2011 10:20 PM
What do they do when i would take it there?
broknindarkagain 03-09-2011 10:26 PM
Check out the ssteering system and tell you whats wrong with it
Sent from my Android powered HTC HD2
