Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   funny noise turned out terribly (http://legacygt.com/forums/showthread.php?t=153761)
jmorris6689 01-18-2011 09:50 AM
funny noise turned out terribly (400whp build thread)
Well last week my car was running really lean due to my ebcs so i replaced it it still wasent running good. Now my motor is blown and my turbo. So i am now building my engine fully forged internals, and adding a nice amr cxr500 turbo on it. Ill post a build sheet up later. Im hoping for a safe 400whp on pump.
underpowerd 01-18-2011 04:37 PM
bummer, in for detail of the build when you do it.
best luck.
jmorris6689 01-20-2011 12:14 AM
here is my current list of parts and mods to the car and this list will be growing:
hawk hps+ pads on front and rear
DBA 4000 slotted front and rear rotors
Magnaflow CBE
invidia catless dp
Greedy Up pipe
DW 850cc injectors
DW 300lph fuel pump
rallitek skid plate
Killer B oil pick up
CP pistons 100mm oversized 9:1 compression custom coated
Acl race bearings
tein s tech spring
AVO front mount
STi intake manifold
GS power division 272 cams
Gs power division billet springs and retainers
Ported b25 heads
AMR CXR 550 turbo
Open source tune
ARP head bolts
Custom tgv deletes
Grimmspeed ecbs
STi nitrite treated crank
2011 STi connecting rods
Perrin turbo inlet
perrin cold air intake
NGK one step colder spark plugs
GSC springs and retainer kit
Gates kevlar timing belt
GFB bov vent to atmosphere
ACT 6 puck
ACT streetlight fly wheel
Kartboy sts
polished and ported stock heads
bored cylinder walls
wrx pedal set
avo grill
STi boost gauge
New avcs system
Gfb manual boost controller
Group N motor mounts
and a lot of headaches
jmorris6689 01-20-2011 09:46 AM
http://sphotos.ak.fbcdn.net/hphotos-...7_986356_n.jpg
Stewy612 01-20-2011 10:57 AM
i dig it dude!!
jmorris6689 01-20-2011 02:25 PM
^brett?!
jmorris6689 01-20-2011 05:51 PM
the tear down
http://sphotos.ak.fbcdn.net/hphotos-..._6091692_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._7390545_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._7987200_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._1291186_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._3008762_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._5891700_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._1044212_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._2459454_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._6132584_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._6342519_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._8329578_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._3059596_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._5715302_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._2154564_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._5370101_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._1839154_n.jpg
jmorris6689 01-21-2011 12:39 AM
the parts
http://sphotos.ak.fbcdn.net/hphotos-...5_594704_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._3057668_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._7085387_n.jpg
jmorris6689 01-21-2011 12:42 AM
checkin out the block tomorrow at the machine shop
ouch1011 01-22-2011 12:12 AM
So, what was the failure? I'm recovering from LASIK (yesterday) and can't stare closely at the pics, but I'm guessing ring lands? What was the failure of boost control? Too much boost? If so, I'd say a boost gauge should be on your list as well. IMO anytime you start modifying an engine, a boost gauge should be on the list, since you never know when you'll start having issues with boost creep, vacuum lines blowing off, boost controller failures, etc.
Good luck on the build. I'm actually kind of keeping my eyes on this for the sti engine that will be going in my 98 LGT.
jmorris6689 01-22-2011 01:17 AM
i have a sti boost guage the failure was the turbo it self and the ringlands
NSFW 01-25-2011 02:08 AM
Subscribed!
Gambit 01-25-2011 04:29 AM
Any reason why your changing the manifold?
ehsnils 01-25-2011 04:47 AM
Red Manifold = STi manifold.
Doesn't it look sexier? :p
And it's a bit different so the flow may be better. At least that's something to hope for.
compsurge 01-25-2011 06:59 AM
So how easy are these engines to work on? I may need to be rebuilding my bro's at some point/ swapping a built shortblock with his current heads.
Would probably end up doing a similar setup with the cxr500 and internals.
