Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   Second Gen. Aftermarket Parts and Upgrade Guide (Superceded) (http://legacygt.com/forums/showthread.php?t=147261)
Zues Marine 10-08-2010 11:55 AM
Second Gen. Aftermarket Parts and Upgrade Guide (V.2)
This is a guide I’ve been throwing together representing the aftermarket support for second generation (1995-1999 USDM and 1993-1998 JDM) Subaru Legacy/Outback.
while everything hyperlinked is fully compatible with your 2nd gen, keep in mind that it is only a guide to give you a better idea of what to look for..
Bolt Ons
Upgrades
DIY Guides
Suspension:
Springs
H&R (-1.5”, -1.25”)
RS☆R (-1.25”,- 1.25”)
Eibach (-1.2”,-1.2”)
Struts
KYB GR-2 – 10% Stiffer than OEM Struts
KYB AGX – On-Car Adjustable Damping
Coilovers
K Sport Kontrol
Ground Control
KW Suspension Variant
JIC Racing
Raceland
Rear Suspension Spacers – Cures the ‘saggy butt’ look after lowering your car, 3/8” Recommended.
Front Strut Tower Bar – Reduce body flex by providing extra stiffness between the strut towers.
disclaimer*- make sure to purchase MY93-01, or any with low-profile brackets.
Rear Strut Tower Bar -Especially effective in wagons
Front Swaybar – Reduce body lean and increase body roll resistance by upgrading to larger sways.
Rear Swaybar
*In order to use 93-01 Impreza RSB, you will need to modify your fuel tank
Front Endlinks - increase swaybar effectiveness by upgrading to endlinks with less flex than the rubber OEM.
Whiteline
K4RT3OY
Bushings - help reduce drive train flex, eliminate chatter, missed shifts, etc.
Control arm - lower inner front
Control arm - lower inner rear
Steering - rack & pinion mount
Sway bar – link (Front)
Control arm - lower inner & outer
Differential - support outrigger
Differential - mounts in cradle
Sway bar – link
Sway bar - link assembly
Sway bar - 18mm
Sway bar - 19mm
Sway bar - 20mm
Sway bar - 22mm
Sway bar - 24mm
Sway bar - 25mm - (Tribeca FSB)
Trailing arm – front
Trailing arm - rear
Shifter Bushings - Improve shift feel and responsiveness on your vehicle by eliminating the soft rubber factory bushing
Front / Rear
Transmission Crossmember Bushings - These bushings can take the torque and vibration of high-performance street and race use
Sway bar Mounts - Super rigid forged light weight alloy mounting.
Rear Sub-frame Locking Bolt Kit - These bolts lock out the rear diff. sub frame bushings to maintain alignment under extreme conditions.
Aluminum Control Arms - Reduces your un-sprung weight and deflection under hard cornering resulting in improved handling
Control Arms - Lighter weight aluminum control arms from GC chassis imprezas bolt right up
Castor Kits - Adds caster to the front wheels giving the car more turn in response
GTSpec
Whiteline
Perrin
Braking:
Rotors
Brembo Slotted , Front / Rear
Stoptech Cryo Treated
Pads
EBC Greenstuff – Designed to reduce heat and dust, best for daily driven cars
EBC Redstuff – Designed for a mixture of track and daily driving
EBC Yellowstuff – Used primarily in heavily raced and tracked vehicles
SS Brake Lines - Improves pedal feel and response
Speed Bleeder - Allows brake bleeding to be easily done by only one person
Master Cylinder Brace - helps prevent flex among the master brake cylinder by adding more holding points to it
Performance:
Cold Air Intake – the Ebay intake was dyno proven at about a 6hp gain over similar Cosmo Racing ($200+) intake systems
MAF Adapter – You’ll need this to affix the cone filter to your MAF
Muffler - Anything works here
Borla UEL Headers - Not recommended due to the thin walls and chances of cracking
Borla Replica Un-Equal Length Header – Bring out the boxer rumble and free up a few HP. Much better reports than original Borla’s
OBX Equal Length Header – Sacrifice some of your rumble for more performance gains.
Header Heat Wrap – Keep the exhaust hot and the valve train noise muffled.
High-Flow Catalytic Converter – Increase exhaust flow
Camshaft Grinding - Low end gains and high end gains depend on how you want them grinded
Spark Plug Wires -
Lightened Flywheel - Reduce weight and inertia for better engine response
- Get quicker throttle response and more horsepower and torque. Reducing rotating mass results in better performance.
Grounding Kit – Smooth out idle and ride, reduce noise, and free up some HP.
Engine Management – Optimize engine performance by controlling aspects such as fuel mixture and ignition timing.
Port and Polished Heads - Reduce the restriction in the engine's intake and exhaust chambers to allow more air into the system, gaining power.
Engine Pitch Stop - A mount that’s stiffer than stock will reduce the amount of forward and backward movement the engine has.
Roll Center Adjuster – For lowered cars, this replaces ball joints ad returns the control arm angle closer to stock to help bring roll center closer to CG.
Phenolic Intake Manifold Spacer - Greatly reduces the transfer of heat from engine to intake manifold thus reducing heat soak. Every 5 temp. drop = 1% power gain
- Less sway and flex in engine components helps put more efficient power down to the ground.
Transmission Mounts - Transmission Mounts Make the transmission more solid. They will give you better feel for your transmission and easier shifting.
4EAT / 5MT
Transmission Oil Cooler – Improve overall performance, and lengthen the life of both the fluid and tranny
Engine Oil Cooler - Reduces oil temperature for extended engine life
Short Shifters -
Kartboy (with bushings)
TWM
Interior:
Gauge Mods
Backlight Color Change
Carbon Fiber Gauge Face Mod
Gauge Swap
Seating
-seat belt latches will need to be swapped out for the ones that you already have
97-01 2.5RS
02-03 WRX
04-07 WRX
08-09 WRX
04-09 STi
Steering Wheels
-02 JDM WRX airbags are plug and play 03 JDM some have same problem as the 03 usdm(read below)
-All 02 WRX steering wheels will be plug and play with your airbag connector, 03 WRX air bags have a different connector but will physically fit in. You can splice out the the connectors but at your own risk and not recommended.
-To use your cruise control you will need to swap the modules in the steering wheel.
02-03 WRX
WRX Center Console Swap
Custom Door cards
STi ‘Blue’ Carpet
Carpet/Headliner Dye
Floormats
A-Pillar 2-Gauge Pods – Fits 52mm gauges
Custom Shift Boots
Exterior:
Chrome Turn Signal Bulbs – Flash Amber
JDM Wagon Tail Lights
JDM Wagon Smoked Tail Lights
JDM Sedan Tail Lights
JDM Projector Headlights
JDM Projector Headlights - Black
JDM Projector Morette Headlights - Very Rare
JDM Sidemarkers - Amber
JDM Sidemarkers - Clear
JDM Front Bumper - GT-B
JDM Front Bumper GT-B Limited
JDM Window Visors
JDM Aero Splash Guards – Takes place of mudflaps
JDM Sedan Rear Window – Rear Wiper
JDM L7 Grille
JDM RFRB Grille
JDM Power Folding – Folding also found on 1995 ‘L’ Model Legacys
JDM Ganador Side Mirrors
JDM Projector Fog Lights
JDM Flush Door Trim
JDM Clear Sidemarker Part Number: F-01 HM6-112
Zues Marine 10-08-2010 11:56 AM
Upgrades
'90-'98 Auto Transmission ‘Power Mode’ Mod ('99+ Important Info!)- Enable the TCU to use a different shift map making the transmission much more responsive and fun to drive at the cost of 1-2 MPG.
Coil Pack Upgrade –(*Important Info!) Provide a more complete combustion with a powerful spark in your ignition system which translates into more power and better MPG.
WRX Brake Swap – increase braking power with 2pot calipers and larger, 11.5” diameter rotors from the Impreza WRX
Outback H6 Rear Brake Swap - Note: OEM 05-09 LGT Rotors are ventilated and wider, providing an extra boost to this upgrade (290x10mm vs 290x18mm)
Rear Wiper Upgrade - A stylish new look for the wagon's rear wiper
Do It Yourself Guides
Fogs on w/ Parking Lights
Independant Fog Lights
HVAC Bulb Change
Cluster/HVAC LED bulb sizes
Power Steering Pump Rebuild
Gauge Cluster Color Change
Adding Projectors to OEM 2 Piece Housings
4EAT Diff lock switch and Handbrake mod - "Torquemada Lite"
Wagon Spoiler Install Template
DIY Grounding Kit +Proof of concept tread
Lifting a newer subaru
OEM FOG Switch wireup
4EAT to 5MT Swap Link Dump:
http://www.surrealmirage.com/subaru/...lectrical.html
http://www.subaruoutback.org/forums/...-plz-help.html
http://www.legacycentral.org/library...lectronics.htm
http://www.rs25.com/forums/f105/t863...nual-swap.html
http://legacygt.com/forums/showthrea...ap-158323.html
http://legacygt.com/forums/showthrea...on-136840.html
subikid90 10-08-2010 08:39 PM
You need a whole JDMness section lol. Nice list!
WESTcoast 10-08-2010 09:25 PM
great list man, I would like to help add some stuff such as sterring wheel selection and to add/change the seating, wrx changed its seats for the 04-09 models, they look just like the sti ones but they are all black same direct bolt on like all the other subaru seats. I will have these installed next week and I can take a picture for you.
Can you make a Steering wheel section as people would might like to upgrade to wrx steering wheels or sti steering wheels or even the jdm steering wheel if u can find the clock spring for it.
Canyonero 10-08-2010 10:09 PM
make this a sticky!!!!!
Zues Marine 10-09-2010 12:43 AM
yeah, im doing everything but this is what i have so far.. im building it in Word and just copy-pasting onto here.. so more stuff will be coming
Lookatmyrust 10-09-2010 11:18 AM
this is awsome... add a brake section!! and tire faq. and links to the other stickys. also add a bulb guide. and more piggy back options
98quiksilvergt 10-09-2010 12:03 PM
Great job bro!! All those strut tower braces fit? I will need to change my rear strut mount studs to longer ones. I have the 3/8 spacers on there. I thought I was looking at 100 each for those bars!!! You are the man dude!
DelawareBlueHen724 10-09-2010 02:55 PM
I gotta find someone who will make a cold air intake for me. As far as exhaust im definately getting those hi flow cats and borla replica headers. Really gotta make that boxer engine rumble
Canyonero 10-09-2010 03:11 PM
Cosmoracing.com has cold air intakes for our cars. you might have fitment issues from what i heard on this board though.
98quiksilvergt 10-09-2010 11:04 PM
Just ordered me some strut bars!!!!
Baddog 10-10-2010 01:49 AM
I would go with SRI. Idk if CAI would be better for our 2.2 N/A engines.
Canyonero 10-10-2010 10:11 AM
im running the 2.5 in my outback wagon but i'm running a K&N drop in filter which is working out great so far. but i do intend to upgrade to a short ram....
