my Subaru will beat with a Buick heart!
So next week i will begin swaping in a 1987 buick 3.8L v6 in to my 05 legacy gt.
I thought long and hard about this. Reasons being cost to build 600 hp subaru engine a lot ! at least 6 grand. specs of the 3.8 buick engine 230 ft lbs tq at 1900 rpm no boost 550 ft lbs tq 3800 rpm @19 lbs boost 3.5" stroke 3.8" bore cost of parts motor 200$ crank shaft and connecting in stock form good for 750 hp cost of race roller cam shaft 250$ 450$ for set of weisco pistons 200$ for set of cometic head gaskets Installation : the stock dbw throttle body from the legacy will be used, motor plate will be fabricated, and then mated to the 5eat with rwd/4wd conversion and automation direct plc will be used for full manual shifting. Mega squirt fuel management. 12 36# lb/hr injectors and factory buick ignition system. Fed by holset hx 35w turbo. |
interesting concept...
I'm sure it's like 300lbs heavier though. Watch out understeer!
maybe 40 lbs heavier.
How does an iron v6 weigh only 40lbs heavier than an all aluminum h4??? And you're probably gonna need a cowl induction hood to clear that taller engine.
6 grand would be cheap for a reliable 600HP Subaru!
it fits under the hood ..
the h4 is pretty heavy compared to an all aluminum I4. Yes it will be heavier but i'm willing to make that sacrafice. witch is also easily over come by larger rear sway bar. |
sick build idea. I had a 98 pontiac GTP with the supercharged 3.8l making 247whp and 28xwtq, ran a 13.3 great motor to build with. im sure using a zzp turbo kit on it, mated to a legacy body would call for real quick ride.
subscribe
subscribed, this will be interesting. GL
i'm in; lots of pics plz.
subscribed....lots of pictures must be taken
plz |
This is definitely intriguing. I've always loved that powerplant. BTW, where did you find the parts at those prices?
Never would of thought of a Buick motor going into a LGT. Wild concept. Definitely subscribed.
GL with build
| All times are GMT -6. The time now is 04:12 PM. |
