Subaru Legacy Forums
-   Vendor Classifieds (http://legacygt.com/forums/forumdisplay.php?f=31)
-   -   Killer B Subaru Oil Pick Up's & Oil Pan's (http://legacygt.com/forums/showthread.php?t=138056)
FredBeansParts 05-20-2010 07:26 PM
Fred Beans Parts is now carrying The Killer B Oil Pick Up Tubes & Oil Pans!
The Killer B Ultimate Oil Pick Up uses a 1/2 inch thick double bracket, 3X OEM oil pickup tube thickness and a brace between bracket and oil pickup tube to further strengthen the assembly.
http://www.fredbeansparts.com/media/...iller_b2_2.jpg
The Optional Oil Pan holds an extra quart of oil, a 25% increase in capacity over your OEM Pan.
The Ultimate Oil Pan is CNC formed aluminum sheet to make the pan, but KB does stop there. There are (2) 1/2”NPT drain ports in the CNC machined Billet Aluminum drain block. Fixed Aluminum baffles, that are an improvement over the OEM design to streamline the oil flow to where it needs to be, at the pickup! All the components are TIG welded and you’ll see the welds are extremely high quality. No internal moving parts to wear, stick or fail and Header friendly! The design is based on the oem EJ25 pan so it should work with any header that works with the OEM pan.
If you are a Fred Beans Parts Forum Member ( http://forum.fredbeansparts.net/index.php ) - we will extend extra low pricing to you!!!
CONTACT A SALES REP FOR PRICING
Fred Beans Parts also offers you the OEM Replacement Engine Oil Pan Bolts, & Engine Oil Dipstick Tube O-rings
( which are not included with the Killer B components )
Ultimate Oil Pick Up Specs:
-3D CAD Designed and Track tested
-All CNC manufacturing Processes
-TIG welding throughout
-3X Thicker Tubing, 1/8” Thick Bracket
-New O-Ring Provided
-Fits ALL EJ25, & EJ20 Motors (with EJ25 Pan)
-OEM Spec. Screen Filter
Aluminum Performance Oil Pan Specs:
·-3D CAD Designed
-1/4” Billet Aluminum Flange
-1/8” thick CNC Laser cut pan
-CNC Formed
-TIG Welded
-2 Drain Plugs: (1) OEM Tap & (1) 1/2” NPT Tap
-Comes with ALL Hardware
-All Pans Fit and Leak Tested
-No Moving Parts
-Header Friendly
-25% Increase in Capacity
-Streamlined Flow-Through Baffles
-Powder Coat Finish Available
-Retains OEM Dipstick
FredBeansParts 05-20-2010 07:28 PM
Fred Beans Parts own Legacy GT Tech Specialist ( give it up for Rick Wood ) has installed this in his own LGT, so feel free to ask for any specifics or details you may want to know about this product, or the installation process.
Underdog 05-21-2010 05:44 AM
I haven't installed the oil pan yet... maybe on my next motor? :icon_twis
http://img94.imageshack.us/img94/9122/img7812c.jpg
http://img94.imageshack.us/img94/5555/img7811c.jpg
GTTuner 05-21-2010 07:22 AM
IMHO, the problem with the OE pickup is how crappy it fits. 9 out of 10 times it needs to be bent to line up properly with the oil pump hole and the bracket in the block. This stresses out the area right at the oil pump.
FredBeansParts 05-24-2010 07:06 AM
Get your KillerB at FBP!
http://www.killerbmotorsport.com/ind.../image1699.jpg
FredBeansParts 05-26-2010 07:32 AM
Bump!
FredBeansParts 06-02-2010 12:08 PM
Bump. There are a lot of motor rebuild going on these days... I hope no one is rebuilding them with the OEM ticking-time-bomb of a pickup in there!
FredBeansParts 06-03-2010 05:50 PM
Bump!
bignickgt 06-07-2010 11:07 AM
How much are they?
FredBeansParts 06-07-2010 11:16 AM
PM me your zip code and I'll get you a shipped price quote. :)
BAC5.2 06-07-2010 11:34 AM
Also interested in price for each, and whether the pan fits with skid plates or not.
FredBeansParts 06-08-2010 02:00 PM
Bump!
FredBeansParts 06-10-2010 09:16 AM
Bump for the KillerB.
tsunami 06-10-2010 09:43 AM
price shipped to 20707?
FredBeansParts 06-10-2010 09:46 AM
For both the pickup and pan sir?
