isc coilovers
has anybody tried them? saw the group buy for them and saw that importimage was carrying them, but i have yet to see any reviews on them.
my friend Chad has a set coming so we'll do a comparison between our cars :)
what setup are you running?
Bilsteins + pinks with Cusco sway bars F&R
Yeah mine should be here today. Waiting for the UPS man so show up. I plan on getting them installed on Weds. Then I will be writing up a review. I'll put them on the softest settings first and do some around town driving and whatnot. Then will put them on the stiffest and go to an autox.
I've ridding in Franz's car and liked his setup and could tell the car handled better than my stock spring struts on the track, so it will be nice to compare the 2. I'm running Perrin 22mm bars front and back on the stiffest settings with stock links and the AVO zero offset LCA bushings. FYI the ISC's will be the street sport versions, 6/8. Hurry UPS man hurry... |
Interested to see how these coilovers work out, as i'm contemplating a set. Aside front front and rear sways, what supporting mods are good with coilovers?
LCA bushings because they're known to tear, end links so the added stress doesn't blow the stockers, and maybe rear camber/caster links (can't think of the car guy term offhand) so you can dial in your alignment as desired.
I got the coilovers the other day and they are pretty nice looking. They seem to be pretty well built. Nice packaging and everything is already to go. The instruction manual was kinda lacking, but does give you the information that you need.
I just didn't get time to put them on yet, since I was waiting for a new up and gaskets to fix my exhaust leak. But, I should have them installed next Weds. So I will update then. |
Mine will be here Monday thanks to AJW Performance. Should have them installed by Wednesday evening, review and pics will follow.
Got the ISC's installed check out the review here, http://legacygt.com/forums/showthrea...18#post2947218
tobey457 please post up your pics and review. |
Just by throwing numbers down and guessing while setting up my coilovers, somehow I got my coils set so that my ride height F/R is even at about 1 3/4" fender gap on the first shot. I was shocked that I got them even, and that close. Car looks 100% better, but I want about a 1" - 1 1/4" gap so I will have to adjust my ride height more tomorrow. Didn't get to drive it too much, and the noises made me think it might be better to wait and push them once I get the noise fixed... but my initial thoughts are that the ride quality feels good, body roll is reduced, and the steering wheel just feels more alive and connected. Once I get the noises fixed, the ride height adjusted, and some seat time I will post up my review and pics. |
Yeah I know what your talking about with the noise. I notice it when I back out of my garage. But I don't have things set like I want and I figure the springs have to settle first. I think your right on the preload I didn't have my springs very compressed so I know they are a little loose.
additional noise is pretty normal for coilovers with metal pillow ball mounts. Sometimes, greasing the top of the springs can help reduce binding and reduce the noise. It's one reason why helper springs are used.
In talking with Andrew at AJW it sounds like they had a batch where the top hats were on super tight, and I think I got the worst set of the bunch. In his experience, loosening that top bolt can take care of most of the noises, then tighten it back down to a somewhat normal tightness. I can not BUDGE that top bolt on either front coliover, I've damaged two allen wrenches trying to do so... any suggestions? I understand that coilovers might be prone to more noises, but these are far beyond any acceptable level IMHO. I've owned several sets in the past and can't remember hearing a peep from any of them. I'm hoping mine are defective... that sounds weird! |
| All times are GMT -6. The time now is 03:18 AM. |
