Subaru Legacy Forums
-   Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) (http://legacygt.com/forums/forumdisplay.php?f=12)
-   -   Possible failing water pump? (http://legacygt.com/forums/showthread.php?t=131929)
DavidPHumes 02-26-2010 01:37 AM
Hi all,
I just picked up my 2005 LGT LTD 5MT from the dealer 3 days ago. It has 126k on it but they took it in on trade with what they thought to be minor motor issues. I agreed to purchase the car pending a test drive, so they went about fixing it. Anyway, they put almost $7k into the motor and almost all parts are new. I only paid $9k, so I basically stole it. I digress...
Tonight when I was driving around I revved it up a little higher than I'd have liked (4k) and heard a very distinct whining noise whenever the throttle was applied. I pulled over and popped the hood for a visual inspection - everything looked just fine. No weird smells. Checked the oil and it looked great and was of normal levels. Then I heard it again.... the whining was still there but sounded more like a gargling sound. I immediately thought water pump and had a friend give a second opinion. He agreed. If you touch the outside of the pump on the timing over and have someone rev the engine a little, you can feel it move in a very non linear manner. I'm thinking the bearing in the pump is bad. Do you agree? Everything else is as smooth as silk and power is right where you'd expect.
lucas569 02-26-2010 01:58 AM
let me know if you need one, i have a used one i can send you just pay shipping.
DavidPHumes 02-26-2010 02:03 AM
Thanks. If for some reason the dealer doesn't warranty it, then I will PM you.
Roja618 03-01-2010 12:08 AM
I believe I'm having the same issue, only I can hear it subtly under idle and it increases in sound and pitch when i give any throttle. Confirmation?
JoeFromPA 03-01-2010 04:58 AM
Just throwing this out there, but any chance they may not have burped the cooling system correctly when they did this 7k of work? Could you have some air pockets in there?
I doubt you'd be able to feel it, just wondering :)
GTTuner 03-01-2010 06:36 AM
Check the idler pulley on the ALT belt adjuster. I have seen lots of those noisy.
