Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Headlight Blacked Out (Small Writeup) (http://legacygt.com/forums/showthread.php?t=131251)
DeltaSniper 02-16-2010 04:03 PM
Writeup
we baked the headlight at 230 degrees for 5 minutes to pry them apart, since this headlight is enormous we jammed open the oven door using a glove in order to keep it from touching the headlight and melting it
http://img713.imageshack.us/img713/3069/img0104cpc.jpg
use a screwdriver to move the sealant, there are a few screws that hold the headlight together so remove those first before baking. After baking you have to loosen the tabs/clips which hold the headlight together as well
after prying them apart you should see the assembly in 2 pieces, the reflector part
*Note i removed the amber lens on the turn signal (just some simple unscrewing), you may have to change your bulb after this because the bulb light is yellow, not orange when you remove the amber lens*
http://img40.imageshack.us/img40/8869/img0091cv.jpg
and the headlight cover/chrome trim (the headlight cover was unscrewed in this photo)
http://img689.imageshack.us/img689/4882/img0093bl.jpg
when you paint it you are to leave the reflector part alone for obvious reasons, to see how i painted it i put painters tape around the area i did not want paint on and then used paper towels and taped the towel using electrical tape to the painters tape (dont let the electrical tape touch the chrome so you dont peel the chrome off)
it is recommended to use the least amount of tape possible to reduce the chances of the chrome peeling off
http://img705.imageshack.us/img705/8759/img0095n.jpg
after painting it should look like this (retrolite used chalkboard paint for mine)
http://img713.imageshack.us/img713/2...g0100cgbgk.jpg
http://img689.imageshack.us/img689/7643/img0101us.jpg
let the headlight sit for a few minutes (or a few hours to let the paint dry, retrolite used a heatgun to speed up the drying time) peel off the tape and the paper towels that covered the chrome that you did not want to be painted on
if you want to remove the amber on the side, it is a simple push out part that is held by tabs
http://img641.imageshack.us/img641/2508/img0092j.jpg
paint this to your liking and put it back on the headlight after you paint the headlight, be sure to remove the bulb behind it because you dont want that to be shining behind the amber
to put the headlight back together (which you should know how to) just reassemble the headlight and bake it at 240 degrees for 3 minutes or so then just stick the reflector part and the chrome trim part back together as you assembled it
*note that these times posted for the oven are specific to the oven i used, other ovens may vary due to the difference in heating element style and the fact that my door was jammed open with a glove to keep it from touching the headlight, rule of thumb is to slowly heat up the headlight until the sealant is soft enough to pry apart/strong enough to hold together
Optional
you can paint your projector shield and fold the squirrel finders to improve your cutoff while doing this mod
the squirrel finder is the rectangular tab sitting underneath the hole on the shield, fold this down (slowly, dont break it) and just paint the shield to your liking
http://img97.imageshack.us/img97/4042/img0096it.jpg
I am not responsible for any damages you may incur doing this to your headlight, do this at your own risk!
as you can see, the chrome peeled off my projector ring so i ended up having it painted black as well (the pictures above shows that i put tape on the projector ring and covered the painters tape with electrical tape to make sure that the painters tape did not have any gaps in between them and to prevent overspray)
http://img19.imageshack.us/img19/7693/img0115nf.jpg
http://img196.imageshack.us/img196/6412/img0117jg.jpg
http://img705.imageshack.us/img705/647/img0118ca.jpg
sorry for the amateur writeup as it is my first :P
Ride 02-16-2010 04:19 PM
That is sweet! Looks much more agressive.
Red Razor 02-16-2010 05:11 PM
Looks great! Did you take any pics while the headlights were apart?
Did you put them in an oven to heat up the sealant?
BobGee 02-16-2010 05:51 PM
Looks Awesome. I like the way you colored it.
Blizzard 02-16-2010 05:55 PM
Goes really well with that car color.
Noeladams 02-16-2010 05:57 PM
+ for effort! I like how it came out!
LosAngelesLGT 02-16-2010 06:00 PM
Sexy
DeltaSniper 02-16-2010 06:37 PM
when i have the time i will produce the "how did i do it part" all i really did was help a bit and watch retrolite (brandon) from toronto subaru club do it (he does this a lot)
the headlight did not actually fit in the oven so he put a rag to jam the oven door open to keep the glass door from touching the headlight so far no condensation issues and i will be following this closely, this is only some rough work, i will be returning to him in the summer for something that will look a lot better than this as i will be getting rid of the chrome and painting it with something else
MY10_3.6L_Oz 02-16-2010 06:40 PM
Why didn't you blacken them out as the GT's have them....why not buy GT lamps???
DeltaSniper 02-16-2010 07:47 PM
explanation is above
and i dont want to spend 3 grand getting JDM headlights which are illegal lol
Ant35 02-16-2010 11:53 PM
Finally somebody does it! I'm not quite sure if I like the style you went for. I'm hoping to see some more examples before I do it myself.
portishead 02-17-2010 12:20 AM
I kind of like it, but kind of don't. I'll give you credit for being the guinea though.
naimouasta 02-17-2010 12:55 AM
i'm just curious to how/why the chrome was peeling off. i think it would have looked perfect if you didn't paint the projector ring/shroud. also if you take note of the jdm headlights, the border around the reflector for the highbeam is also left chrome and unpainted. also looks like you used a flat black paint. might just be lighting but most pictures i've seen for the jdm lights, the black is glossy and not flat.
http://i39.tinypic.com/2r7bl9j.jpg
not judging or anything, just details i'm pointing out. definately A for effort, good job. please post pictures of the cutoff when you get a chance to.
MY10_3.6L_Oz 02-17-2010 04:12 AM
"if you didn't paint the projector ring/shroud"
Agreed, now they look 'hacked'...I dont understand why they would be illegal??...whats wrong with the headlamps we have and you guys get??
DeltaSniper 02-17-2010 05:45 AM
the chrome peeled off because it was a victim of subaru's cost cutting lol, this has been a problem ever since the previous generation (read their blackout writeup)
no worries though i will paint that ring around the projector soon maybe in a few months
IMO the idea of me painting the area around the highbeam reflector looks better than JDM, its only the projector ring which i missed
the pics look flat black but its closer to a slight gloss, its because my car is very dirty :p
http://i13.photobucket.com/albums/a2...y/IMG_0103.jpg
