Subaru Legacy Forums
-   Intake and Exhaust (http://legacygt.com/forums/forumdisplay.php?f=73)
-   -   Racer X (itsme) FMIC install (http://legacygt.com/forums/showthread.php?t=131072)
itsme 02-14-2010 12:58 AM
Hi, all I'm still here. The reason the pictures are down is Photobucket. After being free for 7+ years they decided to charge for pictures on 3 party sites. I was thinking they would start at $100, maybe $200. Nope they shoot straight to $400 a year. So, I got off my butt, and made install instruction on my website. Racerxengineering.com. It's updated to the latest version of the kit and fixed all the grammatical errors and confusing language. (I hope. LOL) I'm going into my 8th year and thanks for all the support over the years. I will still be around to answer questions. Have a great day
Bryan
6/12/10 update: The kits are now in stock and ready to ship. No waiting for GBs. http://legacygt.com/forums/showthrea...html?p=2983710 PM me if you want one. Bryan
5/27/10 update I have more kits ready to ship the week of June 6. If you are interested let me know. Here is a link to a '08+ WRX. http://forums.nasioc.com/forums/show....php?t=1989627 and I'm now working on a kit that will fit '08+ STi's and LGTs with STI swaps. It's done. Bryan
Update: I just started a new GB http://legacygt.com/forums/showthrea...93#post2838893
First, you have to take off your bumper skin. Put you car on ramps or jack stands to give you more room. You have to move this sensor or it will IC. We tie wraped it behind the bracket. http://i167.photobucket.com/albums/u...n/P1060222.jpg Then remove your factory FMIC and even this black hose. http://i167.photobucket.com/albums/u...n/P1060225.jpg
It should look like this.
http://i167.photobucket.com/albums/u...n/P1060226.jpg
Next, you want to put on the 2.75"to 2.5" coupler. The 81/73 t-clamp goes on the 2.75" end connected TB like this
http://i167.photobucket.com/albums/u...n/P1060228.jpg
Get the "j" shaped pipe with the BOV flange and install it into the coupler on the TB you will need the 75/67 t-clamp here.
http://i167.photobucket.com/albums/u...n/P1060230.jpg
http://i167.photobucket.com/albums/u...n/P1060232.jpg
http://i167.photobucket.com/albums/u...n/P1060231.jpg
You will have to see which work the best for you. If you want to go under, over, or thur the fuel lines with the "J" pipe.
You will have to take off the lower black plastic tray. You will have to cut off the ends and it will look pretty much like this. You have to trim it for the pipes to clear. If you ever go back to stock this will be hidden by your bumper skin. http://i167.photobucket.com/albums/u...n/P1060236.jpg
The tray is held on by 4 bolts. Since you cut the ends of the tray you don't use the threaded welded nuts on the outside. I would recommend you trim the thin sheet metal the holds the welded on nuts. It's a very thin piece of metal in front of the seam and a 1" wide. You can use a hack saw, pliers, tin snips, etc.. to remove. This will help the pipes fit up higher. Now get this 2.5" pipe. This is also the pipe you can cut on the straight section near the top to give extra clearance for the taller batteries. Try it first. Then cut if needed. http://i167.photobucket.com/albums/u...n/P1060234.jpg
http://i167.photobucket.com/albums/u...n/P1060235.jpg
update: If you have the V.3 kit this pipe is already in 2 pcs.
http://i167.photobucket.com/albums/u...n/P1060583.jpg
you connect the 2pcs with the included hump hose like this.
http://i167.photobucket.com/albums/u...n/P1060586.jpg
With this pipe you go from the bottom on the driver side. Go up while twisting. It will clear the overflow tank. You have to get the pipe over this seam weld lip. The pipe goes on the inside of the tow hooks. http://i167.photobucket.com/albums/u...n/P1060237.jpg
http://i167.photobucket.com/albums/u...n/P1060240.jpg
Up top it should look like this. http://i167.photobucket.com/albums/u...n/P1060239.jpg
Now you need a 2.5" coupler and two more 75/67 t-clamps. http://i167.photobucket.com/albums/u...n/P1060244.jpg
http://i167.photobucket.com/albums/u...n/P1060243.jpg
http://i167.photobucket.com/albums/u...n/P1060251.jpg
http://i167.photobucket.com/albums/u...n/P1060252.jpg
The pipes should be on the inside of the tow hooks. Now put the trimmed black plastic tray back on and the 2 bolts that are left. Now take all the bolts off the bumper support (8x12mm and 2x10mm on a '08). Now put the IC behind the bumper beam on top of the black plastic tray. You will need a 2.5" and 2 75/67 to connect the driver side pipes to the IC.
itsme 02-14-2010 12:59 AM
Now the pass. side You will need this 2.25" pipe http://i167.photobucket.com/albums/u...n/P1060248.jpg http://i167.photobucket.com/albums/u...n/P1060249.jpg and the 2.5" to 2.25" coupler along with a 75/67 and 68/60 t-clamp. You will send this pipe from the bottom also. http://i167.photobucket.com/albums/u...n/P1060253.jpg
http://i167.photobucket.com/albums/u...n/P1060255.jpg
With the latest update the install changes a bit. All you need to do is bend up or remove the tab that holds the wire harness below the radiator . Once you do that the pipe will go up inside your tow hook. You need to move the electric fan plug from the back of the shroud for more pipe clearance.
It should look like this from the top.http://i167.photobucket.com/albums/u...n/P1060256.jpg
Now you will need this 2" pipe http://i167.photobucket.com/albums/u...n/P1060123.jpg and a 2.25" to 2" coupler and a 68/60 and 54/62 t-clamp. This pipe you can feed from the firewall back to the front of the car. We didn't even have to take off the K&N heat shield to install. http://i167.photobucket.com/albums/u...n/P1060257.jpg It's kind of hard to see. But, if you look closely the little silver pipe in the lower right corner of the picture is the IC piping and the left of the picture is the end of the pipe sticking up. Also you can see the turbo adapter. You can get a common 2" exhaust gasket or gasket paper and make a gasket and use gasket maker. Now get the 2" 110 deg. elbow and connect the turbo flange to the IC piping. You will need 2x2" couplers and 4x 62/54 t-clamp. Here are more pictures off it installed. http://i167.photobucket.com/albums/u...n/P1060261.jpg
http://i167.photobucket.com/albums/u...n/P1060258.jpg
http://i167.photobucket.com/albums/u...n/P1060259.jpg
Now to install your BOV. The flange is not threaded because Aluminum is soft and could strip. Just use a nut and bolts. We use lock nuts on Mike's car GFB hybrid BOV. You have to take off the bolt that holds the BOV return hose to let the hose meet up with the BOV. http://i167.photobucket.com/albums/u...n/P1060270.jpg
http://i167.photobucket.com/albums/u...n/P1060271.jpg
http://i167.photobucket.com/albums/u...n/P1060282.jpg
For the core mounting. I reinforeced heater hose and cut it in have a groumet for the IC. I put one on the brace behind the core. http://i167.photobucket.com/albums/u...n/P1060275.jpg and then the 2 place where the tanks just touch the back off the bumper on each side. http://i167.photobucket.com/albums/u...n/P1060277.jpg. When you tighten the bumper bolts the rubber hold the core in place. That's it. When you put on the bumper skin you may have to trim the bumper skin about a 3/4" in the opening to clear the IC couplers. Here is Mike's '08 Spec B. with my FMIC install and the skin and fogs on. http://i167.photobucket.com/albums/u...n/P1060279.jpg
http://i167.photobucket.com/albums/u...n/P1060283.jpg
http://i167.photobucket.com/albums/u...n/P1060284.jpg
This is the install using the LGT style turbo and this is the parts that were used.
http://i167.photobucket.com/albums/u...n/P1060206.jpg
When you use a STI style turbo you don't use the turbo flange and use the 6" extendion in this picture. http://i167.photobucket.com/albums/u...n/P1060286.jpg this are the part you use for a Sti style turbo. http://i167.photobucket.com/albums/u...n/P1060209.jpg All the parts come in the kit so you have nothing to buy if and when you upgrade. Have fun, Bryan
itsme 02-14-2010 02:04 AM
Learn more about this kit here. http://legacygt.com/forums/showthread.php?t=126386 Next GB will be in about a month.
atc5 02-14-2010 04:37 AM
really love this kit....thumbs up on a great job putting it together!!!
lordchilly 02-14-2010 09:14 AM
Can We get another GB on the 27th of Feb? My wife would buy it for me on my bday. I'll make her. lol
scoobydoobie 02-14-2010 09:49 AM
Wow, my brain hurts from reading that :lol:
But awesome job on the kit itsme. I told myself I wouldn't buy anymore power mods but I just might get in on the next GB.
itsme/m sprank, do you guys recommend upgrading to a new BPV/BOV with this kit? or will the stock BPV work fine?
Also looks like it should work with the AEM CAI since the pipe goes underneath there. Can't wait to see peoples installed pics on an 05.
itsme 02-14-2010 10:15 AM
The pictures on the GB of the blue car is my '05 5mt wagon w/a 20g http://legacygt.com/forums/showthread.php?t=126381 Only thing is I revised the pass. side pipe so it goes lower now liket the one in the install pictures. All intake will fit except the stock box. Mike(m sprank) is going to try to make the stock box fit when he puts it on his other '08 LGT. He got two kits for his cars.
brooklyngenius 02-14-2010 10:38 AM
awesome write up. I am going to try and make it work with the rear half of the stock box in place as I have a blitz induction cover. i'll take pics as soon as I do it. thanks for the write up.
M Sprank, How do you remove 09 bumper skin?
itsme 02-14-2010 10:46 AM
Don't forget you have pop-its under the fender liner where the bumper meets the fender. Take out all the pop-its top and bottom and pull the skin off the car. You have to use alittle force to get the skin from the fender.
lgtgirl06 02-14-2010 10:47 AM
Great write up Bryan! Thanks!
fonts 02-14-2010 01:19 PM
Very nice.
I didn't pay much attention to the initial posts as I've been happy with my current TMIC and meth. Now I'm beginning to think .......
m sprank 02-14-2010 05:08 PM
10 Attachment(s)
All.
I just finished installing the FMIC on my 2008 5EAT. Not only does it fit, even with my Tru-Cool 4454. but, it also fits with the OEM airbox. Yes you heard right the FMIC fits with the OEM airbox!
I took lots of pix. Especially of what needs to be trimmed for the best possible fit.
Not done tuning yet (on both cars). But the initial results are the same. I can run more boost and timing.
What do you think? Does it fit? Installed in both my 2008's now. One in the SpecB and one in the 5EAT. Yeah buddy!
m sprank 02-14-2010 05:09 PM
7 Attachment(s)
More pix.
m sprank 02-14-2010 05:18 PM
OEM BPV works fine until you go larger turbo. Both my BPV's are using the original springs still. I have the lighter spring for the GFB, but have not needed it yet. Will need it for the 68HTA.
To remove the bumper skin you must remove a bunch of popits. Hard to explain in words. The 4 clips for the grill need to be released. The 4 popits around the grill need to be removed. 1 popit in each front fender well need to be removed (behind tire). 6 popits under the front of the car need to be removed. 1 popit hidden in the fender well lining right at the edge of the fender and bumber skin need to be removed (both sides). Pull the edges out of the track (fenders) pull from the front. Once it is off, remove the fog light wires. Be careful the skin scratches easliy.
I think that is all of the popits. Off the top of my head.
