Subaru Legacy Forums
-   Transmissions (http://legacygt.com/forums/forumdisplay.php?f=79)
-   -   WTF? Transmission wonít separate from engine. Need help ASAP! (http://legacygt.com/forums/showthread.php?t=129914)
jipedersen 01-28-2010 04:30 PM
Okay, I am in the middle of replacing a clutch on a friendís 05 Legacy GT Wagon and having some serious issues. I am doing the move the transmission back method. I have a transmission jack along with a engine hoist to support the engine. I have spent numerous hours now trying to separate the tranny from the engine. I tried everything from different amounts of force on the tranny jack and the engine hoist. I had a heavy duty ratchet strap pulling back on the tranny while I pried with a bar. Absolutely nothing, not even the slightest gap yet. Oh and I did down load the service manual so I knew I had all the bolts out!
Finally a 1am on the second night of wrestling around with it we decided to give up and I released the ratchet strap. All of a sudden a small gap appeared in the seam! Enough to get a screw driver in there and we kept tapping larger ones in and then finally the pry bar fit. We managed to get about a ľĒ gap and thatís it. I pried the crap out of the thing on the bottom and top of the case and nothing.
What the hell? I donít want to wreck anything.
Has anyone else had this hard of a time and if so how did you get it apart? Am I missing anything? Please anyone?
rao 01-28-2010 06:15 PM
It is a PITA and there is no way around it. Obviously double check that you really have all of the bolts out and everything out of the way. What happens is that corrosion builds on the dowel pins and they seize to the bellhousiing.
Good luck.
jipedersen 01-28-2010 06:40 PM
Good luck.
Sooo, if I REALLY get after it can I mess something up like bend the input shaft? Could it be that the pilot bearing is seazed up on the input shaft?
Thanks
BarryT82 01-28-2010 08:23 PM
It was a pain to remove the engine from the 5EAT in my legacy a few days ago. I used a small screw driver and a hammer to start out and after it opened up I used a pry bar.
Ridgeracer 01-29-2010 12:56 AM
Good luck.
I'm with this guy. Same thing with mines....damn dowel pins. Use a good screwdriver and go around it nice and easy.
lucas569 01-29-2010 01:55 AM
yup had to use a fricking pry bar on mine, just go around the whole tranny. what a nightmare this was don't even want to remember this! lol
JoeFromPA 01-29-2010 05:01 AM
From what I've read rao/unclemat/underdog post on this very subject, they weren't worried about bending the input shafts. Just trying everything under the sun (I'm assuming you've already soaked everything in penetrating fluid?)
lucas569 01-29-2010 05:31 AM
trust me the transmission can take a beating!
you need a pry bar, what we did was use flat head screwdrivers to get some room in there... pry it all the way around, repeat with thicker screwdriver. Then once you get enough room to get the pry bar in do the same process... we had it separated like 1"-2" and it still wouldn't crack off!
i could see in and look at the whole pressure plate! just gotta wiggle it off little by little....
your lucky if you got a trans jack, i had my back on the tar! lol
wait til you get in and you need a damn T-50 torx "plus" for the flywheel no one stocks it! hope you have one, the fw aint coming off with out it!
http://legacygt.com/forums/attachmen...6&d=1222276408
rao 01-29-2010 06:43 AM
Thanks
Of course you can bend the input shaft, damage the bellhousing, etc. You have to use some common sense.
It is not likely to be the pilot bearing - unless you have a real mess on your hands.
Underdog 01-29-2010 06:50 AM
I didn't pull the transmission back, but took the engine out instead, so my experience isn't 100% applicable here. However, rusty dowel pins were the main source of my frustrations and it wasn't until we had opened the gap enough to fit a pry bar in there that things really started moving.
Since you have already backed the transmission off a bit I would wager the pins aren't what is holding you up. Are you sure you've disconnected the shift linkage and the pitch stopper?
derffred 01-29-2010 06:52 AM
Same thing happened to me when I did my clutch, the bottom studs ending up bending from trying to shake the Trans out so hard lol. Now, about 15K miles later, my trans makes a ton of noise on accel, decel, and when the clutch is disengaged.. who know how it came about. have fun, don't mean to scare you =]
jipedersen 01-29-2010 03:06 PM
Hey guys, thanks for all your replies. It is slightly comforting to know several others had this issue and were able to succeed. I do have everything disconnected and out of the way. It's just extremely stuck I guess. The only thing I can think of that I don't have that might help is that specialty tool that is shown in the service manual. It is a support bracket that bolts to the engine and then ties back to the firewall where the transmission support bolts in at the top. Anyone use one of these or know what I am talking about. I figure it's got to stabilize the engine a great deal while I am shaking and pulling on the transmission. Maybe it might make all the difference. I dunno. Well, I'll be back at it tonight. wish me luck.
rao 01-29-2010 03:10 PM
That tool is helpful but not necessary. You do want to play with the angle of the engine and transmission to make sure the transmission is relatively straight; especially when you are putting it back together.
Good luck.
thunderdan 01-29-2010 04:48 PM
got to ask did u remove the starter. i know from my buddys exp that one of the bolts for the starter is longer and that what stopped his trans from spliting all the way
blk_wagon.GT 01-30-2010 12:47 PM
mine went out without problem . . .lil bit of moving it to the sides. it was a major PITA to put it back . . and you dont really need t50 plus to take out FW. . just put some blue painters tape on t50 and use some PB blaster on bolts.. . .
