DIY: JDM Headlight Blackout and USDM Light Pattern Conversion
I'm posting this because there is a lot of people swapping out their USDM headlights on the Gen2 Legacy's with the JDM projector headlights. This is great as the JDM headlights provide a much better light and also look fantastic. However, there is a problem with this that a lot of people may not realize and that is the JDM light pattern v.s. the USDM light pattern.
JDM projector headlights' cut-off plates are designed to provide more light to the left side of the road as that is where the road signs are in Japan. This can cause quite a bit of disruption to other drivers going the opposite direction of the JDM projectors as the light is shining directly in their face. Of course, you could always lower the height of the JDM projectors to shine more toward the road, but that only provides less light ahead making night driving more dangerous and basically cancels out the reason projector headlights are in use at all. So, for all you JDM headlight swappers, please consider following this simply how-to/guide/whatever to convert your JDM projector headlights to a USDM light pattern and help keep the US roads safe! NOTE: This how-to assumes your headlights have already been removed from the vehicle. If they have not been removed, search the forums for a how-to as it has definitely been covered more than once. Also, you might want to follow each step on both headlights at the same time to prevent having to paint and wait twice. ;) Tools Required: Phillips head screwdriver Flat head screwdriver 8mm socket w/ ratchet Conventional house oven (I've heard of others using heat guns as well) Aluminum foil Scissors Toothpicks JB Weld Insulated gloves Time taken to complete (Including painting:) Approximately 8 hours. Let's begin!
http://www.soapintheintercooler.com/...ersion_096.jpg
http://www.soapintheintercooler.com/...ersion_073.jpg
http://www.soapintheintercooler.com/...ersion_092.jpg And here's a couple pictures of the cut-off from about 20-25 feet away. Granted, the cut-off seems a little high and/or steep, but you can adjust this to however you see fit when you create your folded foil cut-off. http://www.soapintheintercooler.com/...cut-off_01.jpg http://www.soapintheintercooler.com/...cut-off_02.jpg Also, don't forget to re-align your projector headlights after this as they will most definitely be off by quite a bit. I suggest following the thread at http://legacygt.com/forums/showthread.php?t=54740 to adjust your new USDM light pattern. So, that's it! I hope this helps someone and if anyone has any questions about these steps or would like additional information, please let me know and I'll update this how-to accordingly. |
did you use any kind of sealent to put it back together?
Nice writeup! You ought to post up some cutoff pics. I'm interested to see what it looks like.
Thanks! I'm going to post those tonight (Was out of town for the last few days.) I'll post some pictures with and without the 5000K HIDs in. Not sure how much of a difference it'll be in the picture though. We'll see!
Wow, those look kewl. I didn't use any additional sealant when I put my lights back together either. It's been more than 6 months and still no leaks.
It must have taken some bawls to do that, because those lights looked awesome already. |
It appears you've blackened the high-beam and turn signal reflectors - is that correct? If so, doesn't that degrade the output quite a bit?
Cool. Very nice work on the shield. Makes me wonder what pattersns we could come up with that were better suited to local conditions.
Did you find the OEM/USDM pattern to be symmetric? It seemed that way on our old '97. Sort of: __M__ with a very flat M. |
I want pics of them on the car, please.
Subscribed!
Showing my ignorance..
Do you need to change the patterns on both lights or just the driver's side? |
Thanks.
Got one done and of course got some of the adhesive on the reflector for the high beam, just a thread, but want to get it off. Any ideas on a solvent that won't destroy the chrome on the reflector? |
| All times are GMT -6. The time now is 11:53 PM. |
