Subaru Legacy Forums
-   Legacy Photos (2005-2009) (http://legacygt.com/forums/forumdisplay.php?f=16)
-   -   Heavily Modded 07 Spec B (http://legacygt.com/forums/showthread.php?t=117513)
SubyDude555 07-30-2009 05:43 PM
Stealth Monster
My 2007 Legacy Spec B that I've been slowly modding since I bought it in March 2007.
http://i596.photobucket.com/albums/t...ps58fdd49b.jpg
http://i596.photobucket.com/albums/t...psd8d93e70.jpg
http://i596.photobucket.com/albums/t...ps710f68f0.jpg
http://i596.photobucket.com/albums/t...ps25ffd2cd.jpg
http://i596.photobucket.com/albums/t...ps2a14ad65.jpg
http://i596.photobucket.com/albums/t...ps88b67422.jpg
http://i596.photobucket.com/albums/t...ps7c0ea04e.jpg
http://i596.photobucket.com/albums/t...psdc7ee6ad.jpg
http://i596.photobucket.com/albums/t...ps9b5c7b9d.jpg
http://i596.photobucket.com/albums/t...ps4c2c8b45.jpg
Engine Specifications:
  • EJ255 390 WHP 387 WTQ on 92 Octane
Engine:
  • Group N Engine Mounts
  • Unorthodox Racing Light Weight Crank Pully
  • Unorthodox Racing Light Weight Power Steering Pully
  • Gates Micro V Belts
  • Denso Iridium Plugs
  • Zero Sports 71C Thermostat
  • Zero Sports Radiator Shroud
  • HPS Performance Silicone Coolant Hoses
  • Perrin Radiator Hoses
  • Perrin Dual Oil Catch Cans
  • Subtle Solutions Alternator Cover
  • SPT Billet Oil Cap
  • SPT Battery Tie Down
  • Optima Red Top Battery
  • Hella Supertones Painted DGM
  • RPA Hood Dampers
  • Koyo Aluminum Radiator
  • Perrin Radiator Mounts
  • Sti Coolant Expansion Tank
  • STI Radiator Cap
  • Kartboy Pitch Stop Mount
  • Killer B Optimal Oil Pan
  • Killer B Oil Baffle and Windage Tray
  • Killer B Ultimate Oil Pick Up
  • Reservoir Caps Vinyl Wrapped CF
  • Fuse Box Cover Vinyl Wrapped CF
  • Alternator Cover Vinyl Wrapped CF
  • + Battery Terminal Cover Vinyl Wrapped CF
Turbocharger & Induction:
  • Blouch 20G XT (7cm Hotside)
  • Prosport Turbo Heat Shield Blanket
  • AWD Tuning Turbo Heat Shield
  • Tial MVS 38mm VTA EWG (.9 Bar)
  • STI Intake Manifold
  • JDM TGV Deletes Ported and Polished
  • GrimmSpeed 8mm Phenolic Spacers
  • Perrin FMIC
  • Turbo XS RFL VTA BOV
  • Perrin Inlet Hose
  • Apexi Shortram Intake
Fuel & Tuning:
  • Walbro 255lph Fuel Pump
  • Fuel Injector Clinic 900cc Top Feed Injectors
  • Aeromotive Top Feed Fuel Rails
  • Custom SS Braided Fuel Lines & Fittings
  • Aeromotive A1000-6 Injected Bypass Regulator
  • Cobb Access Port 2.0 Tuned by Mike at PIA
Exhaust:
  • Tomei Expreme Unequal Length Headers Wrapped and Coated
  • IAG Performance Custom EWG Up Pipe Wrapped and Coated
  • CNT Performance Catless Downpipe
  • Perrin 3" Mid Pipe
  • Perrin 3" Y Pipe
  • Perrin Sport Tone Mufflers
  • Rallitek Polyurethane Exhaust Hangers
Drivetrain:
  • Exedy Twin Plate Clutch Kit
  • AP Braided SS Clutch Line
  • Motul RBF 600 Dot 4 Clutch Fluid
  • Group N 6 Speed Transmission Mount
  • Cobb 6 Speed Short Throw Shifter
  • Cobb Hardened Shifter Bushings
  • Cobb Hardened Rear Shifter Bushing
  • Whiteline Transmission Mount Bushings
  • Eneos 75w/90 Full Synthetic Transmission Fluid
  • Eneos 75w/90 Full Synthetic Differential Fluid
Brakes:
  • GrimmSpeed Master Cylinder Brace
  • DGM Brembo 4pot Calipers Front
  • DBA 4000 Slotted Rotors Front
  • Hawk HPS Pads Front
  • DGM Brembo 2pot Calipers Rear
  • DBA 4000 Slotted Rotors Rear
  • Hawk HPS Pads Rear
  • Techna Fit 6 Piece Custom SS Brake Line Set
  • Motul RBF 600 Dot 4 Racing Brake Fluid
Suspension, wheels & tires:
  • Sti Front Strut Bar
  • Cusco Rear Strut Bar
  • Jspeed Inner Front Fender Braces
  • Perrin 25mm Front Stabilizer Bar
  • Kartboy Front Endlinks
  • Perrin 25mm Rear Stabilizer Bar
  • Kartboy Rear Endlinks
  • Perrin Rear Stout Mounts
  • Emotion Fukuoka Rear Stabilizer Support Brackets
  • Cusco Front Cross Member Power Brace
  • Cusco Front Lower Arm Bar Type II
  • Cusco Rear Lower Arm Bar Type II
  • Cusco Rear Side Power Braces
  • Cusco Rear Lower Power Brace
  • AVO LCA Front Control Arm Bushings
  • AVO Caster Bushing System [+0.50 caster]
  • AVO Steering Shaft Bushings
  • Whiteline Front Roll Center/Bump Steer Correction Kit
  • Whiteline Adjustable Rear Control Arm Kit
  • Whiteline Rear Toe Lock Bolt Kit
  • Whiteline Front Diff Bushing Kit KDT905
  • Whiteline Rear Diff Bushing Kit KDT906
  • BC Racing BR Series Coilovers
  • 18x8 +48 O.Z. Racing Alleggerita HLT's
  • BF Goodrich 235/35ZR18 g-Force T/A KDW NT's
Interior:
  • Greddy Turbo Timer
  • Greddy Boost Controller
  • Defi Link System
  • Defi Amber Red Boost Gauge
  • Defi Amber Red Water Temp Gauge
  • Defi Amber Red Oil Temp Gauge
  • Defi Amber Red Oil Pressure Gauge
  • Defi Amber Red Exhaust Temp Gauge
  • JCS Pods Dual A-Pillar Gauge Pod
  • Rally Innovations Quic-Trac Harness Bar
  • Corbeau 3 Inch 5-Point Harness x2
  • Shifter Bezel Vinyl Wrapped Flat Black
  • Both Stereo Side Trim Pieces Vinyl Wrapped CF
  • Dual HVAC Double Din Kit
  • Pioneer AVIC-Z120BT Head Unit
  • Polk Audio DXi6500 6-1/2" Front Components
  • Polk Audio DXi6500 6-1/2" Rear Components
  • JL Audio 10W3v3-4 Subwoofer
  • Kenwood XR-5S 5 Channel Amp
  • Tsunami Litewave 1.2 Farad Capacitor
Exterior:
  • Central Composites Carbon Fiber Lip
  • R-Rev Carbon Fiber Grill
  • R-Rev Eyelids Painted DGM
  • R-Rev Carbon Fiber Fog Light Bezels
  • R-Rev Carbon Fiber Rear S Type Spoiler
  • Stanza Carbon Fiber Rear Window Spoiler
  • K2 Carbon Fiber Grill Emblem
  • K2 Carbon Fiber Trunk Emblem
  • Windshield Panel Vinyl Wrapped CF
  • Side Window Trim Vinyl Wrapped CF
  • B-Pillar Trim Vinyl Wrapped CF
  • Side Skirt Trim Vinyl Wrapped CF
  • OEM Mud Guards Vinyl Wrapped CF
  • Rear Diffuser Vinyl Wrapped CF
  • Carbon Fiber License Plate Frame
  • Cleared and Blacked Out Headlights
  • DRL Delete
  • Windows Tinted to Legal Limit
  • DeBadged All Except Suby Emblems
  • Gorilla Aluminum Tuner Lug Nuts Black Anodized
  • Side Mirror Turn Signals Vinyl Wrapped Smoke
  • Tail Lights Vinyl Wrapped Smoke
  • Rolled Fenders Front and Rear
Started a build thread for my Sti if anyone is interested in following it.
http://forums.nasioc.com/forums/show....php?t=2621089
Links to more pictures:
Some pictures taken through out the build:
http://legacygt.com/forums/album.php?albumid=51
Armin Ausejo Photoshoot September 2010:
http://verdugo.smugmug.com/Cars/Chris-Legacy-GT-Spec-B
vduber 07-30-2009 06:14 PM
Badass period.... Very nice all around car, someone trade me there spec b so I can get rid of my 5eat please please. O yeah question any plans on bigger turbo in the future or this suits your needs?
SubyDude555 07-30-2009 06:20 PM
September 2010 Photoshoot:
http://i596.photobucket.com/albums/t...85_UaDvu-O.jpg
http://i596.photobucket.com/albums/t...58_rhY9Z-O.jpg
http://i596.photobucket.com/albums/t...31_NECyv-O.jpg
http://i596.photobucket.com/albums/t...82_D5pRh-O.jpg
http://i596.photobucket.com/albums/t...90_XEpSt-L.jpg
http://i596.photobucket.com/albums/t...98_hfwPp-O.jpg
More pictures of this photoshoot can be viewed here:
05Boost 07-30-2009 06:35 PM
what was the order of the performance parts? Just wondering why you went sti intake mani with vf52? thought everyone does sti style turbos espically with a front mount.
otherwise very nice!
SubyDude555 07-30-2009 07:28 PM
Exhaust stuff, turbo, gauges, and FMIC where some of the first things done, wheels were last. The turbo is the VF22 off a version 3 STI in Japan its an STI fitment which is why I went with the FMIC so early. The turbo, gauges, boost controller, and turbo timer I brought back from Japan with me they are all off my old car posted below.
http://i596.photobucket.com/albums/t...d555/Front.jpg
http://i596.photobucket.com/albums/t...ud555/Rear.jpg
http://i596.photobucket.com/albums/t...ntheStall2.jpg
N.sane 07-30-2009 07:34 PM
Spec Bad Ass indeed, that's a crazy list of mods, good job! Clean GC too.
05Boost 07-30-2009 07:37 PM
whoops i cant read. i thought that said 52 not 22. All makes sense then awesome!
edssti 07-30-2009 08:27 PM
nice car, not a big fan of the gauges though. I had a similar setup in my STI but it looked really out of place in my spec b
SeattleLGT 07-30-2009 08:59 PM
Very clean!!! Considering your old car and that you live in Lakewood, gonna take a guess you're in the military?
N.sane 07-30-2009 09:10 PM
Are your fenders rolled to fit those wheels? Or did you get away with it from the mild drop?
SubyDude555 07-30-2009 09:10 PM
Used to be, I got out in 06 before I moved here from Misawa, Japan.
GEE-OTTO 07-30-2009 09:30 PM
Nice so many pods and gauges :lol: you should feel accomplished
JrBully 07-30-2009 09:39 PM
I was in Misawa to from 02-07. I had a silver GC8 but I sold it. Wish I could go back.
SubyDude555 07-30-2009 10:02 PM
Just the rears are rolled and pulled a little, yes I could of gotten away with not rolling them but I will probably upgrade to BC Racing Coilovers in the near future and go lower.
SubyDude555 07-30-2009 10:04 PM
If it was a WRX I might remember it, Im sure I saw you around I was there from Nov 02-Feb 07.
