Subaru Legacy Forums
-   Walkthroughs :: Performance Modifications (http://legacygt.com/forums/forumdisplay.php?f=37)
-   -   How to make an STS "Shorty Shifter" (http://legacygt.com/forums/showthread.php?t=11039)
jah64 04-08-2005 11:15 PM
10 Attachment(s)
At the request of PatagonianGT, here is a fairly detailed description on how to shorten the stock subaru STS shifter 35mm. The maximum amount by the way.
Tools:
12mm wrench and 12mm socket and drive for removing linkage.
½ capacity drill (optional)
Belt sander (optional)
Snap ring pliers
12mm x 1.25 rethreading die (P/N 03866811 from MSC direct ~$10.00
Flat mill file (if you want remove the flange by hand) – very doable.
1 1/16 box wrench for driving the rethreading die
CRC or suitable cutting fluid. Don’t use motor oil
Ye olde hacksaw
Petroleum jelly for the repack
Ben Folds Five CD.
Step 1
Make a drawing to illustrate what you want to remove, rethread and shorten. Or use mine:) See jpeg
Step 2
Take shifter out of car- see other threads which describe this in detail. Thanks guys!
Step 3
Remove the forged flange on the shaft. I started with a hand file to make sure it could be done. It is very doable but will take some time and care. I used a ½ inch drill and a belt sander to clean up the shaft.
Step 4
Position shifter in a vice and thread the die down to bottom of existing thread. Then reposition shifter in vise so you are holding on the original thread. Crank down on so it won’t rotate in the vise jaws when you chase the thread down to 30mm above the vibration isolator. The thread you are smashing in the vice gets cut off in the last step anyway. The reason I did this was because the shaft is isolated from the rest of the shifter by a rubber over mold. If you hold on the large isolator tube and start to chase threads, I guarantee you will twist the shaft right out of the rubber isolator –then you’re buying a Kartboy! Chase the new thread down to a height of 30mm above the isolator tube. Use a suitable cutting fluid. I used CRC. I drove the die with a 1 1/16 box end wrench; you could use a crescent wrench in a pinch
Step 5
With the die still on the shaft, cut the shaft to 55mm from the top of the isolator tube and then chamfer the saw cut end. Lastly, back the die off the threads. This will remove any burrs that could mess up the Momo knob threads.
Step 6
Reassemble and Enjoy. The boot will now sit over the larger isolator shaft with just enough room for the rubber cover underneath. One note; when you reattach the linkage, be careful not to over tighten the bolt. I tightened the bolt until there was no play at all and then backed it off ever so slightly.
My observations:
1: Much much better feel. More positive engagement due to less leverage. very solid. I also removed all play from the linkage attachment point.
2: Shorter throw – shorter shifter = shorter arc length
3: Unexpected benefits – better access to the climate control system. No shift knob in the way!!! This one never even occurred to me until I drove the car. Retain the vbration isolation without giving up anything.
4: Better hand position, my wrist rests right on the hand break lever. Hard to explain, it just feels more natural.
5: It looks cool!
And, my wife thought I was nuts until she drove the car. Her reply, why didn’t Subaru do this in the first place? “It feels a lot sportier”
My Kartboy bushings come in tomorrow I will let you all know if there is added benefit.
If you are looking for a sportier shifting experience and don't want to shell out for a shifter. this is a simple and very effective mod.
Andy
suba_rus 05-28-2005 07:58 PM
Just did it. Feels much better now. Highly recommended.
jah64- thanks for taking time and pictures. How did it go with bushings?
jah64 05-28-2005 10:16 PM
Glad you tried it! I have no regrets on cutting the shifter stalk down to a reasonable height. As for the bushings, they are sitting on my work bench waiting to be installed. I just haven't had the time. It is on my short list of things to do. I will update the post when I get the bushings installed.
Andy
jah64 05-28-2005 10:19 PM
So.. I have to ask, has anyone else tried this mod? With ~350 or so hits on the thread, I am amased that only one other person has gotten out the hack saw.
mtenhoven 05-29-2005 04:29 PM
Perfomed this mod on standard shifter about a month ago, just because the standard height was not comfortable.
I would recommend this mod for anyone not happy with the stock shifter height, but does not want to install a shorter shifter.
suba_rus 05-29-2005 10:08 PM
Actually had to buy hack saw just for that. Don't regret it for a second! Took a road trip today ~250 miles and enjoed every shift! Manual tranny rocks!!
Hack sawers of this site unite!! :lol:
Allways had a grate deal of respect for people who aren't affraid to get ther hands dirty with positive outcome. ;)
ChE Outback XT 05-30-2005 10:09 AM
Has anyone combined this mod with a short-throw mechanism? Any leverage problems?
suba_rus 05-30-2005 10:28 AM
I had factory STI short shifter. It only got better after cutting it.
jah64 05-30-2005 06:41 PM
STS stands for Short Throw Shifter, which is what I modified. No problems with leverage what so ever:)
alpinefun 05-31-2005 08:05 PM
mtenhoven:
Did you find the shifter more notchy after you cut it down?
To suba_rus:
Thanks for your link to this mod
mtenhoven 05-31-2005 10:01 PM
alpinefun,
I wouldn't say the shifter is more notchy, maybe just a little more effort when changing gears. It's still easy to change gears with just my thumb and index finger when I'm feeling a bit lazy.
I also changed the shift bushing which seemed to help "clean" the shifter movement up.
suba_rus 06-01-2005 06:31 AM
Bushings will be my next mode, hope that will bring it closer to TSX shifter feeling.
suba_rus 06-01-2005 08:30 AM
To Alpinefun
I am off tomorrow, swing by my place we will cut your shifter. I am in Palisades Park.
jah64 06-01-2005 08:39 AM
Originally Posted by mtenhoven
alpinefun,
Man... you beat me to it:lol:
CRAZY KEN 04-04-2006 05:31 AM
Hhmmmm...
...so you guys cut off 35mm! What is the maximum length you can cut off before you might have problems/discomfort???
CRAZY KEN
