Subaru Legacy Forums
-   RalliTEK Performance (http://legacygt.com/forums/forumdisplay.php?f=61)
-   -   RalliTEK Stage3 Kits (http://legacygt.com/forums/showthread.php?t=104656)
Rallitek.com 01-26-2009 06:29 PM
Guys,
The fuel injector supplier is just about ready for us to launch these kits.... Here is a breakdown of the kits:
Here is a breakdown of the kits we have: (assumes you already have stg2, Accessport and turboback exhaust)
-$2450 = Basic - AVO TMIC, 380 Turbo (15psi only, 275whp/275ft lbs)
-$3150 = Standard - AVO TMIC, 380 Turbo, Fuel pump, and Deatschwerks Cobb Spec 750cc injectors. (Includes 3 maps 15psi, 18psi, 20psi(326whp/334ft lbs))
-$3750 = Deluxe - AVO TMIC, 380 Turbo, Fuel pump, Intake, Turbo Inlet tube, and Deatschwerks Cobb spec 850cc injectors. (Includes 4 maps, 15psi, 18psi, 20psi, + E85 biofuel(332whp/367fl lbs))
All components are currently in stock (except injectors).
Please post up any questions!
92 Pump Gas Dyno Charts!
15psi
http://i175.photobucket.com/albums/w...15pump92-1.jpg
19psi
http://i175.photobucket.com/albums/w...s/19pump-1.jpg
21psi
http://i175.photobucket.com/albums/w...s/21pump-1.jpg
The green (boost) shows noise in the dyno system, not a variance in boost level.
I will post the e85 chart tomorrow. I am out of time today...
Thanks!
Sean S.
www.RalliTEK.com
http://i175.photobucket.com/albums/w...ioc-banner.gif
dga 01-28-2009 02:19 PM
I take it; we already have to have a turbo back and an Accessport?
Dang it! Just read the post top to bottom. :lol:
Rallitek.com 01-29-2009 02:08 PM
E85 Dyno Chart
RalliTEK Stage3 Turbo Upgrade Kit: E85 (347whp/367lbft)
http://i175.photobucket.com/albums/w...lee85chart.jpg
All Kits include:
-Thoroughly tuned, dyno tested, Cobb approved mapping.
-Install Instructions
Post for more details or call us @ 1.888.773.1212
Thank you,
www.RalliTEK.com
AGR-LGT 01-31-2009 05:45 PM
MArk ym word, when/if my turbo starts to go this will be my route...
Scooby2.5 02-02-2009 08:17 PM
Just a few questions
Can we get the maps if we already have this setup? I was understanding that Cobb, AVO or rallitek was going to provide them since it was a joint tune effort.
Also if these maps are installed is there any kind of log collect tweaking that can be done?
Last question, will these be AccessTuner race compatible so we can log and tweak on them ourselves?
bnguyenbb6 02-03-2009 08:28 PM
Are there 93oct maps? This could be the summer project I've been looking for...
Scooby2.5 02-04-2009 02:22 PM
Any difference in Cobb Spec 850cc and any other injectors from DW?
itsme 02-04-2009 11:46 PM
Is the TMIC limiting the power of the e85 setup?
apexjapan 02-05-2009 03:02 PM
Yes. I believe it was mentioned in another thread, and we've mentioned it before, the main limitation to power beyond the 320whp mark is the TMIC, not the turbo.
It's a great basemap to plug n' play, but it's nowhere near the limits of the setup.
Cheers,
Paul Hansen
www.avoturboworld.com
sportwagon 02-11-2009 07:32 PM
can I get a basic setup (w/out TMIC which I already have) and run it with the maps sans the fuel upgrades?
JSK05LGT 03-28-2009 10:11 PM
I also have the AVO TMIC currently and am interested in the rest of the standard package... Price differential?
Silverstar 03-29-2009 03:21 PM
Sean,
I'm excited to see that you are including E85 maps. I don't want to start the whole E85 is good or bad arguement here, but I'm curious as to why you have felt that E85 is a safe alternative. The biggest arguement seems to be that the ethanol content varies too greatly to make running it safe.
I posted the same question here:
http://legacygt.com/forums/showthrea...t=rallitek+e85
which is probably a better venue to argue the point.
Thanks!
Rallitek.com 03-30-2009 03:30 PM
We have not collectively decided on releasing just the mapping yet.... We will make announcements once the decisions have been made.
-Sean S.
www.RalliTEK.com
Rallitek.com 03-30-2009 03:31 PM
Yes! Mapping is included in each kit with the standard Cobb format... (91ACN / 91 / 93 / E85)
Sean S.
www.RalliTEK.com
Rallitek.com 03-30-2009 03:32 PM
'Cobb Spec' have tighter tolerances for flow...
Sean S.
www.RalliTEK.com
