06legsleeper Posted February 9, 2013 Share Posted February 9, 2013 just bought these rims in 18x8 40 offset ... im only on h&r springs so im sure the fitment will be fine . going to run 225/40 tires .... ive researched a good bit and seen a few leggys with this offset so . plus im going to roll my lips anyway just for good measure just thought id post and share my excitement lol Link to comment Share on other sites More sharing options...
O.C.D. Posted February 11, 2013 Share Posted February 11, 2013 I am envious of your excitement, lol. Congrats. What do they weigh? Link to comment Share on other sites More sharing options...
Scooby Fan Posted February 11, 2013 Share Posted February 11, 2013 Might like to consider 235/40/18 so the tires will afford some rim strike protection.... I ran 18x8 with 225/40/18 and the rims are actually wider than the tires shoulders. Link to comment Share on other sites More sharing options...
06legsleeper Posted February 11, 2013 Author Share Posted February 11, 2013 scooby only prob is can i fit 235/40 on there im dropped on h&r springs thats about it , im getting the fenders and q panels rolled so im not sure they will fit that tire though .. seeing as i got 18x8 40 offset there still kinda heavy but .... 20 a piece Link to comment Share on other sites More sharing options...
Scooby Fan Posted February 12, 2013 Share Posted February 12, 2013 I can't see that the difference in width (.4" and that is .2" on each side of the wheel) would cause any clearance issues....I see lots of guys running 235's on 8" wheels and lowered too.....Unless you are running Slammed to the ground I can't see an issue..........keep us posted. My issue with the 225 on 8" width was the the rim stuck out past the rubber....when I got them from Tirerack and put them on the floor, on their sides, the rims hit the cement and the tires did NOT....ouch!! I am currently running 235/40/18 on 18X8 rims.....very nice and lots of clearance....but not lowered Link to comment Share on other sites More sharing options...
06legsleeper Posted February 12, 2013 Author Share Posted February 12, 2013 humm guess ill have to check i used that tire calculator thing and running a 235/40 and a 225/40 your right about the .2 on each side on the rim but somehow a 235/40 is also taller Link to comment Share on other sites More sharing options...
Scooby Fan Posted February 12, 2013 Share Posted February 12, 2013 Yes they are taller....by .3" ... or actually .15"above the wheel center and the same under the wheel. I used this size on my '12 Limited because They are the same circumference as the OEM 215/50/17....using OZ 18x8 rims and Kuhmo ASX 235/40/18 I get true speedo readings and a lot more grip with the same weight as the OEM wheels/tires. I would say it is a win-win situation and the 235's protect the rim edges against minor curb rubbing. Link to comment Share on other sites More sharing options...
06legsleeper Posted February 13, 2013 Author Share Posted February 13, 2013 yeah my oem tire size is 215/45/17.. im going to double check everything and see what i can get on there if need be ill get a buddy of mine that has tires he used for other rims .. get 1 of each mounted and see what clears. and what doesnt Link to comment Share on other sites More sharing options...
Jerm Posted February 14, 2013 Share Posted February 14, 2013 Those are going to look good. Link to comment Share on other sites More sharing options...
06legsleeper Posted February 14, 2013 Author Share Posted February 14, 2013 thank ya .. yeah i got tires from one of my buddys for cheap least i can see and try them there 225/40 so if i dont like the look or ride ill by new 235/40.. he sold me a set he had used for like 3 months still have 7/32,s left on them and cant beat 60 bucks for all 4 Link to comment Share on other sites More sharing options...
