Head unit on legacy 2.5i
Been having problems with my stock head unit on my legacy 2.5i 2008 every time I put a disc in it keeps saying eject disc
Tried ejecting disc same thing even tried another disc same exact thing checked fuses everything is okay radio works just not the CD player
Even tried going out a buying a disc cleaner doesn't seem to help at all
Please someone help me
Sent from my SM-G935V using Tapatalk
  • I Donated Too
Unless it's something mechanical which you can fix and you're inclined to take it apart, your best bet is to try and find a replacement as suggested.
If you're asking on here to find out if there's a magic button sequence to make it work again, unfortunately there isn't. Last ditch attempt you can try is some percussive maintenance but really that needs to be applied from the top down so you still need to remove it from the dash for application.
