05wagongt Posted January 11, 2013 Share Posted January 11, 2013 on both front doors on my wagon, the handle you grab to shut the door is coming loose from where it connects up to the to part of the door panel. previous owner screwed in handle to door armrest? anyway, how expensive/complicated would it be to just put 2 new door panels on? i have the black panels with silver brushed trim.... Link to comment Share on other sites More sharing options...
JJr Posted January 11, 2013 Share Posted January 11, 2013 Here's the DIY http://legacygt.com/forums/showthread.php/2006-legacy-rear-door-speaker-installation-diy-96930.html?t=96930&highlight=door+panel+removal. Trust what it says I pulled my passenger side off to replace my mirror assembly. While your doing it it's a bit scary because you have to pull a bit harder than you would think. Screwed the handle to armrest?? I'd pull a panel off 1st and see whats going on with it, you'll know more once you do. After you do, if you still think you need a new one check the FS threads for newer panel's I've seen them come up before. GL Sometimes the easiest way to find out info is to Google 2005 Legacy GT and your question, legacygt.com threads will pop-up. Link to comment Share on other sites More sharing options...
05wagongt Posted January 11, 2013 Author Share Posted January 11, 2013 Here's the DIY http://legacygt.com/forums/showthread.php/2006-legacy-rear-door-speaker-installation-diy-96930.html?t=96930&highlight=door+panel+removal. Trust what it says I pulled my passenger side off to replace my mirror assembly. While your doing it it's a bit scary because you have to pull a bit harder than you would think. Screwed the handle to armrest?? I'd pull a panel off 1st and see whats going on with it, you'll know more once you do. After you do, if you still think you need a new one check the FS threads for newer panel's I've seen them come up before. GL Sometimes the easiest way to find out info is to Google 2005 Legacy GT and your question, legacygt.com threads will pop-up. thanks bro Link to comment Share on other sites More sharing options...
